Viewsonic VA902b dim lights, then black
  • PlainBill
    replied
    Re: Viewsonic VA902b dim lights, then black
    This sounds like the inverter isn't putting out enough voltage. There is definitely signs of overheating in the region of U501. Assuming something has gone awry, causing low output from the CCFLs is logical.
    I'd pull T502 and look for any signs of overheating at the end nearest to U501. If that looks good, try the ring tester with it out of circuit.
    Next point to test is D513, D514. Then U501 and U502. It might be a good idea to just replace U501 and U502.
    PlainBill
  • sceva
    replied
    Originally posted by smason
    Wait a sec. YOU fix 'em then HE re-sells them? What's wrong with that picture...
    He pays me for fixing... And I am a lousy salesman.
  • smason
    replied
    Originally posted by sceva
    U501 does have a dark area around it. The voltages at U501 and U502 appear to be the same, and nothing is below U501 to get hot... I guess either the U501 or the transformer could have gotten hot.
    This is the only VA902b. A local recycler passes his broken lcd's to me and lets me try and fix them and then he resells them.
  • shovenose
    replied
    Sceva-what store/recycler?
  • lucky13
    replied
    This might help... PlainBill might chime in and help you here (please).
  • lucky13
    replied
    I checked my notes...
    I had also previously replaced C812 1000uF/10V (it was domed).
    If you have 1000/16v, you can lay it down.
  • sceva
    replied
  • lucky13
    replied
    U501 area looked overheated...
    Do you only have this one monitor to fix?
  • sceva
    replied
    Originally posted by alexanna
    Finding a poor solder joint can be very hard sometimes, But reflowing the solder can be done very quickly and it may fix your problem.
    Al.
    I tried resoldering the obvious places, no luck, then I began doing all the joints, a section at a time, and still no luck... Thanks for the idea though. I sometimes forget the obvious, although I usually reflow the transformers and larger transistors on all the boards.
  • alexanna
    replied
    Every monitor is different but somewhat similar .I was just working on a 20” monitor and it was only lighting ½ of the ccfl tubes.I replaced every capacitor on the board with good low ESR caps and nothing changed. The capacitors in the inverter area were 35v caps and checking voltage when back lights were off was 23v as the back lights turned on the voltage dropped to 18v.checking the primary side of the inverter coil when the lamps were on I was reading 9vDc on both pins. I removed the inverter coil and re soldered it and also re soldered the ceramic caps in the inverter area, still no change.
    Next I re soldered all of the jumpers in the inverter area ,and then the very last thing I did was re soldered 2 sot23 diodes that were in the inverter area .well I got lucky and have a bright screen now.
    Al.
  • sceva
    replied
    I can never remember the voltages for bright and dim displays, but you have a point to check there.
    Also check the voltage on J808 when inverter is on, then off.PlainBill
    Removed the dimming wire and got same bad results...
    J808 is 14.8V when inverter on, 15.0V when inverter is off...
  • PlainBill
    replied
    I had seen the 12V 'floating' before, but did not know it was by design.
    The big cap shows163V and drops to 160V when the ccfl's turn on.
    At the two schottky diodes the center pin of one shows 5.1 volts and the other shows 15.1V and drops to 14.76 when the ccfl's turn on.
    The on/off pin from the main board is 0 when off, and 5V when on, and stays at 5V until the monitor goes to standby.
    The brightness pin shows 3.3V all the time. Doesn't that indicate it is dimming?
    PlainBill
  • sceva
    replied
    Have you checked the outputs of the power supply, as well as the voltage across the big cap? The normal SMPS design regulates the 5V supply, and lets the 12V supply 'float'. The result the 12V supply will tend to vary under load. 14.4V isn't unusually high for an unloaded 12V supply, but 7.35V is very low for the supply under load. PlainBill
  • PlainBill
    replied
    This was showing 2 seconds to black. I opened it up and found 3 bulging caps. (the three with black marks on top in the inverter side.) I replaced them with good caps... no change. I then removed the rest of the caps and tested with ESR meter. Found two of the smaller caps near the main transformer reading high, so I replaced them also. Still get 2 sec to black.
    I then did some tests with the power on:
    Primary side of inverter transformers show 14.4V before the ccfl's turn on, and then drop to 7.35V when the lights turn on, then back up to 14.4V when they shut back off.
    I plugged in some good ccfl's and when they come on, all of them only light up about 60% of the tube.
    Setting my meter to 150V AC I tested the ccfl connectors. I put each probe on one of the pins by the ccfl connector. CN501 and CN502 show 75V when they light up. CN503 shows 60V, and CN504 shows 50V.
    I checked the inverter transformers with a ring tester (while still on the board) and the secondary side shows 1 yellow, which should be ok?
    It appears that it isn't getting enough power, but I don't know where to look next...
    PlainBill
  • sceva
    started a topic Viewsonic VA902b dim lights, then black
  • Rauni
    Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
    by Rauni
    Hello, this is my first post on this forum, and my first attempted to repair a TV.
    My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
    Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
    Read also that we should test what happens if we...
    10-01-2023, 12:06 AM
  • Francesc V.
    Christmas lights - Something I am doing wrong
    by Francesc V.
    Hi:
    i am trying to repair this Christmas lights from my parents. They are incandescent lights, no led lights.
    I have tried with 12V a 24V small lights that I found in Aliexpress but is obvious that are not the right ones. They last microseconds connected. Do they blow because of Amps or Volts?
    If I measure the Amps in the string........it's only 90mA. If I measure the Volts in the "green box"......it's between 0 and 190V, but doing a little bit of maths from the number of bulbs in series.......it's only about 6V per lamp.
    Could...
    03-11-2023, 07:38 AM
  • gabrielA7
    IMAC A1418 / MB: 820-00430-a / does not turn on, Lights 3 of the 4 LEDs and turns off.
    by gabrielA7
    Does not turn on, lights 3 of the 4 LEDs and turns off and stays like this, presses the power and repeats.
    I saw that the room LED lights up only when the screen is connected, so quiet.
    We have all the power supplies, even processor, 1.8V
    One thing I found strange, it has a very low resistance in the Vcore is giving 1 Ohm , work with notes and such, I know that this is normal in some processors but with this resistance only take video card so found it strange.
    I suspect that there may be some leak in the processor.
    Anyway, when I press the power, it...
    10-29-2024, 06:48 AM
  • evilkitty
    When your mom is complaining about her new cheap lights
    by evilkitty
    My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
    well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
    lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
    07-23-2024, 01:27 PM
