GNV34DBE2 intermittent snow, looking for Mainboard. Need a mainboard for this. Made in China, so possibly no hope to find just a mainboard. Monitor is btanded Viotek. Thanks!
by MireniaHi everyone,
I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled... -
by orcicHello,
I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
Now I have some doubts about how to connect the new mainboard to the old power supply.
First of... -
by protocoldI would like to get some help on a 820-2850 logic board with intermittent charging problem. Sometimes the battery will charge all the way and sometimes magsafe would be cycling between green and orange.
I have already tried replacing dc-in board, swapping good battery, swapping genuine 85w chargers. None of that helps..
when it is not intermittent:
PPVBAT_G3H_CHGR_R is 12.07v
when it is intermittent:
When the light is green, PPVBAT_G3H_CHGR_R is 12.99v
when the light is orange, PPVBAT_G3H_CHGR_R is 11.62v
data line on the battery...07-25-2025, 08:18 PM -
by MalvaHi everyone,
I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
Mainboard model: EAX65684604
PCB marking: EBT62954607
SPI chip: Winbond W25X20CLNIG Problem description:
Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:- I bought another
by DevonavarI have a Vizio M43-C1 stuck in a reboot loop with no backlight.
I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
So, I've ruled out the PSU for now.
The reboot loop... - Loading...
