Dell E177FPf No Power
  • billy66
    • Mar 2010
    • 124
    #41
    Re: Dell E177FPf No Power
    Good board: 806
    Bad board: 574
    Note: good board currently doesn't have transformer T850 connected. Also I850 and U850 are removed. I've placed these on the bad board... just wanted to state that in case it affects the readings (not sure how it would, but just to be safe).
    • retiredcaps
      • Apr 2010
      • 9271
      #42
      Originally posted by billy66
      Here is what I've done:
      - Recapped entire secondary side... no changes
      Does this include recapping C857?
      --- begin sig file ---
      --- end sig file ---
      • billy66
        • Mar 2010
        • 124
        #43
        Yes. C857 is a 10uf50V. Replaced with Panasonic FC.
        • retiredcaps
          • Apr 2010
          • 9271
          #44
          Good board: 806
          Bad board: 574
          And if you reverse the probes to test the other direction, do you get "1" or OL?
          That is, put your multimeter on diode test function. Put red probe on one side of diode and black probe on the other. Record measurement. Now put switch the probes and record the measurement.
          • billy66
            • Mar 2010
            • 124
            #45
            On both boards, if you put the probes the other way, you get 1... OL
            • retiredcaps
              • Apr 2010
              • 9271
              #46
              Okay, looking at
              page 12 shows a reference circuit.
              Pin 3 is VIN. It is "fronted" by R5 and R7 which are 750K ohm 1/4W resistors.
              R5 and R7 correspond to R854 and R853 (marked 754) on your board (I think). Measure both on the ohm scale to see if you get around 750K ohms.
              • billy66
                • Mar 2010
                • 124
                #47
                Bad board: 700K ohm each
                Good board: 750K ohm each
                The bad board took a long time to read. When I first put the probes on the resistor, it would climb up slowly till it stopped around 700K ohms +/- 5k ohm
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #48
                  Risking a from PlainBill, R854 and R853 form a voltage divider. They drop the voltage from the bridge rectifier (120V x 1.4) to something that feeds into the VIN pin 3.
                  edit: I should point out reading and intrepreting schematics is still a learning process for me. I still have the chicken and egg conundrum when following all the various circuit paths.
                  edit2: I don't know if 700K versus 750K is enough of a variance to say the SMD resistors are bad. 50k/750K is 6.67% variance.
                  edit3: The max for VIN is 30V according to the datasheet. So 25V on pin 3 is within spec.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #49
                    From my still learning schematic reading, all the components that feed into pin 7 VDD are as follows.
                    It looks like D856 is D4, R887 is R12 (reference to page 12 of SG5841 circuit). R887 is 0 (zero) ohm resistor so it should read close to that on your multimeter.
                    C9, I think, is C856 (Panasonic FC 10uF, 50V).
                    You say the U850 replacement is a known good one as well.
                    I'm out of ideas right now.
                    • alexanna
                      • Mar 2010
                      • 1346
                      #50
                      Well it doesn't happen often but it is possible to receive parts that are packaged wrong
                      Did you verify with your eye ball that C857 was indeed 10uf and not something else?
                      Al.
                      • billy66
                        • Mar 2010
                        • 124
                        #51
                        Al. Yeah, I doubled checked after retiredcaps asked. It is so easy to mess those up.
                        Retiredcaps.... the U850 is from the known good board. At risk of sounding like a moron, it is possible I mixed up the two chips when swapping? And put the bad one back on? It's a chance... I'll have to remove and replace again. This will take a bit, as desoldering those and removing SUCK...
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #52
                          I can't think of anything else. So if you want to change U850, go ahead. Use a sharpie and mark the U850 chip so you don't get them mixed up.
                          These videos from CuriousInventor + ChipQuik make soldering/desoldering SMD easy.
                          http://www.youtube.com/user/CuriousI...33/3NN7UGWYmBY
                          • billy66
                            • Mar 2010
                            • 124
                            #53
                            Excellent video. The ChipQuik solder is nice... I'll need to pick some up, as desoldering was a royal pain in the a&&! I've managed to slightly lift one of the connections on the good board when removing the chip... not enough to ruin the board, but I knew if I continued on that path, it would eventually ruin it. I'll hold off on swapping the U850 until I can pick some up...
                            Thanks for the tip. I've read on here before how people suggest ChipQuik to other people, but I've never needed it so I never looked it up. I honestly thought it was going to be some piece of equipment like a special soldering iron.
                            Thanks again.
                            • billy66
                              • Mar 2010
                              • 124
                              #54
                              I swapped out U850 with the other one. Same readings... So both U850s give same readings. I marked them this time, so no possible mix up.
                              Any other ideas?
                              • Bowline
                                by Bowline
                                06-11-2025, 10:13 AM
                              • Akhlz001
                                by Akhlz001
                                09-20-2025, 07:15 PM
                              • master3112
                                by master3112
                                07-29-2025, 01:55 PM
                                Dell Thunderbolt Firmware
                                by SMDFlea
                                Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                                Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                                The SKU is in brackets (****)
                                EDIT: NVM65...
                                01-26-2025, 06:22 AM
                              • F R 2568
                                Dell Latitude 5420 does not start (no post) need help to find the reason why
                                by F R 2568
                                Hello all,
                                this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                If the laptop is only connected to the AC adapter (battery removed):
                                When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                The power/battery...
                                01-08-2025, 05:45 AM
