Help Dell E173fpb 17inch monitor
  • mastercare
    • Sep 2010
    • 5
    Hi all just joined the forum after some help if anyone knows what this problem may be...
    i aquired this monitor about a year ago from our local landfil site it was dead anyway thanks to the internet found that the 2 pairs of invertors can go short so i repl all 4 ...bingo all worked fine...component ref q740 q760 q739 q759..
    problem now very different it will switch on fine and work some times for 10 mins sometimes for hours but then it just goes off. we found if we unplug the mains for a short while it then powers up again fine. there is no standby light its just as if you have pulled the mains. i am checking caps for bulges etc but no luck there has anyone had these symptons or could suggest a fix,,
    many thanks agn
  • seanc
    • Nov 2008
    • 1319
    Re: Help Dell E173fpb 17inch monitor
    Do the standby and power led work correctly during the time the monitor is working?
    Sounds like the PSU is shutting down because it's detecting a short or you have bad solder joints.
    • mastercare
      • Sep 2010
      • 5
      hi thanks for reply..
      yes power etc works fine while monitor is behaving...at mo just soldered some joints and dell test logo is bouncing around the screen..
      i will leave it on and see what happens..
      thanks again..
      • retiredcaps
        • Apr 2010
        • 9271
        You *must* resolder all the inverter transformer (the 4 yellow boxes that start with a "T") pins for Benq power/inverter boards. If you don't, it will cause the c5707 transistors and the picofuse to possibly go bad or cause symptoms like what you are seeing.
        --- begin sig file ---
        --- end sig file ---
        • mastercare
          • Sep 2010
          • 5
          thanks for the information, i have soldered all the pins on the transformers and so far so good, its been running now for about 4 hours so i will see how it goes..
          many thanks guys.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            resolder the grey box caps and the 5707's too
            • Borse2008
              by Borse2008
              • There’s
              07-15-2025, 04:55 AM
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • DanPoka
              by DanPoka
              02-15-2025, 05:05 AM
              by momaka
              03-15-2023, 10:17 PM
            • Jesus Coder
              Issues Reviving Old Dell 2408WFPb Monitor
              by Jesus Coder
              I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
              06-25-2023, 02:33 PM
