Westinghouse Monitor Fading Colors
+ More Options
Posts
  • DavidTomen
    • Sep 2010
    • 17
    Re: Westinghouse Monitor Fading Colors
    A little more info since my last post. I finally found the manual for this monitor online. I was able to reset the monitor to factory default settings (which is what I used when I first got the monitor).
    The display went almost completely white. Does anyone have any inclination as to what is going on here? Is this an electronic component issue, or is the LCD panel itself failing? I spent an hour searching for symptoms of a failing LCD panel with no luck. And I'm a pretty damn good researcher.
    Cheers,
    David
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      Logic board, ribbon cable to panel, or worst case, the panel itself. Try the ribbon cable first.
      A working TV? How boring!
      • DavidTomen
        • Sep 2010
        • 17
        Any idea where I can get a replacement ribbon cable? And better yet ... what exactly am I looking for? There are two ribbon cables in this monitor. One I think is 50 pins going to the LCD panel from the logic board (32-D021705). The other is 15 pins going from the logic board to the control buttons (32-D021698). The model numbers are on sticky tape on the cable, and I don't know if that is proprietary to that monitor or is some standard numbering system used for ribbon cables.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          Well since the problem manifests itself in the panel, you should check the one that goes to the panel. If you got the patience, grab a multimeter and check each line for continuity.
          • DavidTomen
            • Sep 2010
            • 17
            I haven't got the patience nor a steady enough hand. I'd like to just replace the cable if I knew where to find one:-)
            • DavidTomen
              • Sep 2010
              • 17
              #26
              Well, I am aware that this forum is mostly about bad caps. But now that I've replaced them I am convinced that I have a bad LVDS cable going to the LCD panel. (it too me two freaking days to figure out what the cable was even called).
              Does anyone here know where I can get a replacement LVDS cable? I've spent hours searching eBay, using Google, went to Mouser, etc. There are vendors that will sell individual LVDS cables for specific monitors. Usually in the $40 - 60 price range. But not for Westinghouse who don't even appear to make monitors anymore.
              Can one buy this stuff by the foot and learn how to shave the ends? Any other options that you can think of?
              The LVDS cable to the LCD panel is 55 conductor 5 3/4" X 1 1/8"
              The LVDS cable to the control buttons is 15 conductor: 14" X 5/8"
              There are no connectors at the ends. The cable simply slips into the female connector soldered to the board.
              • jetadm123
                • 2169
                #27
                1) When you did a reset, you say the monitor went almost all white. IF it's all white with no picture, then there is a surface mount fuse on the LCD panel control board (circuit board at the top of the LCD panel that spans almost the entire width of the panel) that could be blown.
                2) I have yet to see anyone successfully use a new ribbon cable with the old connector. VERY difficult to do something like that.
                3) If you are still getting some type of image, one thing I would try is replacing the 3 metal caps on the logic board. One was stamped 100uf @ 16V. I couldn't read the other two. You can use the same type of low-esr caps that you used on the power board. I can't back up what I'm saying, but they are on the video/logic board, which could be the cause of your problems. It's a low cost try before attempting to mess around with the ribbon cable.
                • alexanna
                  • Mar 2010
                  • 1346
                  #28
                  Try Gateway Electronics St. Louis Mo. 800-669 5810.They have bulk ribbon cable.There on line site most likley will not list it,you will have to make the call.
                  • DavidTomen
                    • Sep 2010
                    • 17
                    #29
                    Is this fuse on the inverter board on the panel raised off the panel and round with a "100" on it?
                    BTW, i have no picture now since I started messing with the LVDS cables. All I get are a lot of multi-colored vertical stripes.
                    • jetadm123
                      • 2169
                      #30
                      This is the board that is at the other end of the ribbon cable in question. The fuse should look like a small surface mount resistor and marked FXX on the board. Usually the board will be exposed and covered by a thin sheet of plastic or under a metal cover.
                      • DavidTomen
                        • Sep 2010
                        • 17
                        #31
                        I'd like to replace the metal capacitors on the logic board as you suggested. There are two marked:
                        100
                        16V
                        L7C
                        and one marked:
                        q3
                        330j
                        WZ
                        Would I replace the first two with regular 100uf16V caps similar to the ones on the power board?
                        I can't find the fuse that you are referring too marked "FXX". I've checked both the inverter board on the LCD panel itself, as well as the logic board.
                        • DavidTomen
                          • Sep 2010
                          • 17
                          #32
                          It jsut occured to me what you mean by "FXX". I've identified the fuse marked "F1". A little white thing with a "3" on it. A continuity check shows that it is good.
                          • jetadm123
                            • 2169
                            #33
                            100
                            16V
                            L7C
                            and one marked:
                            q3
                            330j
                            WZ
                            You could use the same low-esr caps that you used on the power board. The original metal caps are surface mount and are soldered on the top of the board. You'll have to bend the leads of the new caps at a 90 degree angle to get them to fit properly.
                            I believe the 330j cap is 330uf with +/- 5% tolerance. As for voltage rating, maybe also 16V? You can always measure the voltage across that cap before you remove it.
                            • DavidTomen
                              • Sep 2010
                              • 17
                              #34
                              I replaced the two metal caps with ones that I took off an old Dell motherboard. Didn't replace the other one.
                              However, I was testing the DC across the big cap on the power board that I haven't replaced yet. I guess I didn't ground something properly because when the metal part of the VGA connector touched the metal of the housing that the boards sit in - there was a little puff of smoke from the logic board. I can't figure out exactly where because there are no burn marks.
                              I reassembled everything and plugged it in, and now have no power whatsoever. The little LEd light doesn't even come on. Any idea what blew?
                              • jetadm123
                                • 2169
                                #35
                                You can start by checking the fuses. However, the bigger question is how did grounding the vga connector housing, while you were checking the main cap, cause the logic board to short out? I usually don't say this, but you've had problems on top of problems (now it's the logic board) and this may be a good time to stop because this monitor may be beyond repair.
                                  by momaka
                                  03-15-2023, 10:17 PM
                                  Westinghouse L2210NW LCD monitor - bad caps repair
                                  by momaka
                                  Here's another LCD monitor repair: Westinghouse L2210NW.
                                  Quick specs: 22” CCFL backlit LCD, 1680x1050 max resolution (16:10 aspect ratio)
                                  I got it with a bunch of desktops PCs from a repair shop that was trying to free up space a few years ago. It seemed like a cheap monitor, so I didn't really care that much at first when I picked it up (and indeed it is, picture-wise.) But hey, free is free, so I can't complain. Moreover, it looked clean and the screen didn't have any significant scratches or blemishes.
                                  Pictures of the monitor outside/case after a brief...
                                  01-11-2021, 01:14 AM
                                • wattage
                                  AOC AG493UCX 49-inch monitor - Firmware request
                                  by wattage
                                  Hello Badcaps Community,
                                  The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                  07-13-2025, 04:41 PM
                                • ant3202
                                  HP 27es - LED monitor - Monitor Flashing On - Off
                                  by ant3202
                                  Hi Everyone
                                  Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                  https://www.badcaps.net/forum/troubl...lashing-on-off
                                  The monitor is HP 27es LED Monitor
                                  https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                  The monitor will randomly blackout and display no signal and will recover again.
                                  Sometimes need to power and off again to restore the display but...
                                  03-20-2025, 07:30 PM
                                • Rick_1234
                                  LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                                  by Rick_1234
                                  Good evening, gentlemen.
                                  I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                                  To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                                  https://drive.google.com/file/d/1L6S...ew?usp=sharing
                                  Things I tried
                                  - Bought a new AC adapter thinking that was the problem but the problem...
                                  06-22-2024, 04:44 PM
