Samsung SyncMaster 226BW (replacing caps with newer versions?)
  • DemonWatcher
    • Sep 2010
    Hello. Very new to the forum, very new to caps and soldering period.
    I have a Samsung SyncMaster 226BW that started blinking and I narrowed it down to the bad caps like in this POST. I will have to take it apart again jus to double check exactly which caps are bad, but aside from that I have a question about replacing these caps in general.
    My question is can I replace these caps:
    I'm using Panasonic part numbers. Any low ESR caps from the other manufacturers on the 'Good caps list' would also work.
    C107 47uF 50v GL 105 °C C640 VENT 5mm D x 10mm H EEU-FC1H470
    C110 820uF 25v GL 105 °C C646 VENT 10mm D x 20mm H EEU-FM1E821L *
    C111 820uF 25v GL 105 °C C646 VENT 10mm D x 20mm H EEU-FM1E821L *
    C112 330uF 25v GL 105 °C C638 VENT 10mm D x 15mm H EEU-FM1E331
    C301 680uF 25v GL 105 °C C650 VENT 10mm D x 17mm H EEU-FM1E681
    C302 680uF 25v GL 105 °C C650 VENT 10mm D x 17mm H EEU-FM1E681
    * Check the height on these. You might have to use EEU-FC1E821S instead
    This cap has a low failure rate, but if I ignore it Toasty will get on my case.
    C105 150uF 450v GL 105 °C C640 VENT 20mm D x 42mm H EET-ED2W151BA
    with either solid state caps or "Newer Technology" caps that will make it stronger/more powerfull/brigher/longer lasting/?, to get some kind of performance increase in it. I'm not consernered with the price so much at the moment, just with the FACT of weather its possible and what I would use to replace with what kind of increase.
    I understand that I couldn't hold you responcible for the info you give me as I'll be doing it myself, but I would hope to only get resonable/factual responces from those who feel they know a great deal about what they are saying.
  • DemonWatcher
    • Sep 2010
    Re: Samsung SyncMaster 226BW (replacing caps with newer versions?)
    Anyone able to help? or give advice?
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      Leave the 450v cap alone unless it is visibly bulged. Replace all others. Poly caps would be good since the caps are right next to the transformer and heatsinks, and no matter what type of electrolytic you put in there it will still eventually fail.
      A working TV? How boring!
      • DemonWatcher
        • Sep 2010
        Thanks for the info. That is very helpful. I have another question stemmed from that. What are poly caps, and how would I find them vs the ones from the list above. Forgive my ignorance, but the best I could make of the list above was to type in the product codes to google and saw what came up there.
          master hoarder
          • May 2008
          • 12175
          Polymer caps are usually not suitable for power supply use unless the power supply was designed for them specifically. Most aren't. With that said, polymer caps may or may not work in your monitor. If you need this monitor fixed, stick to regular electrolytic caps. Otherwise if you want to just experiment with it, you can try polys. No guarantees that it will work, though, and you may end up damaging other components in the monitor.
          • DemonWatcher
            • Sep 2010
            Thanks for that, that makes sense. Since I'm not a big guru in this field i guess i will stick to the normal suggested. At least get the monitor working again, cause I miss it ;-)
            • vintageibm
              • Oct 2009
              • 15
              I agree stick to normal Electrolytic Caps, If I get another three years out of this display (I just fixed my 226BW) I will be happy, that's three years longer then most LCDs ;-)
              • soopacrucial
                Samsung Syncmaster 740BF repair
                by soopacrucial
                Hi folks,
                I'm new here and was wondering whether you might be kind enough to give me some advice on troubleshooting the following problem:
                Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...
                10-29-2024, 02:40 PM
              • Reintar
                Dell Inspiron 15 7567 (LA-D993P) - No power after replacing blown inductor and shorted mosfet advice needed
                by Reintar
                First of all, I'd like to mention that I'm a novice when it comes to laptop repair, although I do have some experience with soldering.
                One day, my laptop experienced a severe stutter, and after rebooting, it failed to boot into Windows. I decided to disassemble it and found that the PL900 component was blown. Later, I came across a post (https://www.badcaps.net/forum/troubl...error%E2%80%99) with the same problem, where...
                08-30-2024, 06:13 AM
              • amigo744
                LG OLED 55CX9LA SWAP MAINBOARD FROM NEWER MODEL 55CS9LA POSSIBLE???
                by amigo744
                i have an 55cx9la tv fully functional.
                furthermore i have a new mainboard from newer model oled 55cs9la / cs series.
                Both Mainboards look the same and the connectors to the t-con board and psu are also the same.
                Only one connector which leads to the wlan/bluetooth and power led is different.
                Anyone here, who tried to upgrade lg cx series to newer cs series ????
                Is that possible ?
                How to power on the tv for test purposes without plugging in the power on/bluetooth/wlan connector, because it is different and does not fit...
                02-10-2024, 03:05 AM
              • nh2
                Samsung SyncMaster 215TW buzzing / lightning in power board socket
                by nh2
                This is my first post here. I just fixed my first 2 broken displays by replacing broken capacitors (Samsung SyncMaster 226BW, and Samsung SyncMaster 213T). But I have a third one I'm unable to fix, and am eager to fix as well:
                My Samsung SyncMaster 215TW makes a buzzing / hissing sound when turned on.
                The sound is louder the brighter the monitor is, e.g. in the "Game" preset is is even louder than in a softer preset.
                Opening up the monitor and unplugging the small socket cables that run from the power board to the LCD, I can see a small blue...
                08-31-2021, 02:23 AM
              • m1ch43lzm
                Replacing 2xAA / 2xAAA alkaline batteries with Li-Ion / LiPo battery?
                by m1ch43lzm
                Hi, i have this RadioShack IR thermometer Cat. No 22-170 which takes 2xAAA batteriss, I've tried with NiMH AAA rechargeables but it complains about low voltage, it flashes an "empty" battery and doesn't measure anything, even with freshly charged 2xAAA NiMH, so i have to "borrow" the batteries from my multimeter when i want to use it
                I'm thinking abour replacing the 2xAAA batteries with a small LiPo battery that fits inside that space, but the voltage would be too high (4.2v)
                I'm open to suggestions on whether i should use an LDO or another type of voltage...
                05-27-2025, 05:34 PM
