Viewsonic VX924,912,output transistor advice.
  • Rtech
    • Jul 2010
    • 1095
    I have qty2 of VX 924, each has the same fault .in that the inverter driver transistors need replacing.They have DK QP on them, are SOT89,and I understand they are NPN,50v,2A,part code 2SC4672.These are unobtainable in the UK,via Farnell,RS and various others.Has anyone used a suitable equivalent for them,which,hopefully,can be obtained.Many thanks for any ideas.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Viewsonic VX924,912,output transistor advice.
    First, a correction. It appears the Rohm part is rated for 3A, better use the higher spec in your search.
    Before I found the link to the Rohm part I tried to find parts in the SOT89 package with specs similar to the 2SC5707 used in the Benq monitors. I don't remember what I came up with, but it did successfully repair one monitor. I just tried searching on Digikey for an NPN BJT with a current rating of 3A, 50V, SOT89, and looking for an hFE of 200 or greater. I got half a dozen hits. Obviously, Digikey won't work as a supplier for you, but if your suppliers do not have an equivalent search engine, follow my path and start checking if any of those parts are available form your suppliers.
    The parts were also available on eBay from a seller who ships worldwide (at an impressive markup). Search for DK transistor.
    Or of course, there is always the classic approach of having someone order them and reship to you. Sorry, I'm not volunteering. I've got too many things undone as it is.
    PlainBill
    • lostone
      Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
      by lostone
      Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
      First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
      When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
      05-19-2024, 11:40 AM
    • magneh
      Behringer Eurolive B205D repair - help identifying transistor
      by magneh
      Hello
      Got this speaker from a friend , defective. Power led comes on and off , in a loop.
      Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
      After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
      I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
      Still, I need to replace this transistor....
      06-18-2025, 02:34 AM
    • elsomer
      help to identify transistor msi ms-15ck1
      by elsomer
      hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
      02-17-2025, 05:30 PM
    • rddube
      Help with blowing transistor NAD T752 receiver
      by rddube
      I guess I need help from the masters to try and find what is frying a 2SC5669 transistor on the left channel of this front center Amp for a NAD T752.
      Was working perfectly and all of a sudden I heard a pop, and then a glow from the amp. Not only did the 2SC5669 burn a leg, but R520 which is a 220 ohm resistor partially burned - it now measures 110 ohms.
      I bought this amp second hand fairly cheap as it was not working, it went into protection mode. I finally traced it down to the same transistor Q510, the one that just popped. It was shorted...
      09-01-2022, 05:19 AM
    • amigo744
      xbox series x u82 5 pin transistor voltages ?
      by amigo744
      hello there,
      xbox series x hdmi u82 transistor 5 pin,
      can anybody tell me voltages of this transistor in standby and power on mode ???
      on which pin of this transistor are the voltages ?
      regards
      08-16-2023, 08:05 AM
