Viewsonic VG191b
  • Lakerat
    • Sep 2010
    • 20
    Re: Viewsonic VG191b
    The lights test OK..... I put a meter across the ends of each transformers and get no readings but with power off I get the same Ohm readings for both.
    So I think something that provides power to them is not working...
    Where can I get a drawing on This board?
    • Lakerat
      • Sep 2010
      • 20
      OK with ohm meter on power side (input side ) of transformers I get 1 volt for the split second lights turn on when power switch is turned on
      • retiredcaps
        • Apr 2010
        • 9271
        Originally posted by Lakerat
        The lights test OK.
        How did you test the lights to conclude they are ok?
        --- begin sig file ---
        --- end sig file ---
        • Lakerat
          • Sep 2010
          • 20
          I opened up my main monitor and A Viewsonic and made jumpers to try them.
          I also noticed that I should recap my main before trouble happens it is 5 years old
          • Rtech
            • Jul 2010
            • 1095
            You will be very lucky to get a schematic for this,and suspect you are at the stage where to get the thing to work, you will have to replace the Inverter board with a good one.
            • Lakerat
              • Sep 2010
              • 20
              #26
              I just bought a case light and tested the lights with the power supply it came with.The power supply runs off a plug from the computers power supply and has 2 plugs for lights (was 5.99 at Frys).
              Could I take 2 of these power supplys and run the 4 lights for the monitor off them would the monitor work if I did this?I would use the power that goes to inveter board to run both power supplys and they look to be the right size to go where the orignal inveter board goes. would this work?
              Thx
              P.S. link http://www.frys.com/product/5948774?...H:MAIN_RSLT_PG
              • Lakerat
                • Sep 2010
                • 20
                #27
                I made my home made inverter and can see the the screen change shades and see lights in back of screen (did not reapply tape yet).
                But no picture when when computer turned on but a steady green power light on front of panel... any idea on this?
                • Lakerat
                  • Sep 2010
                  • 20
                  #28
                  UPDATE
                  I built my inverter and got the screen to work just meed to insulate it good
                  Total cost less than 15.00
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #29
                    UPDATE
                    Great Ingenuity! Congratulations!
                    • bohaboha
                      Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
                      by bohaboha
                      Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
                      anyhow i couldn't t read anything else
                      the backlight is on strong and the screen does not get dark or very dark but no pictures
                      the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
                      01-02-2025, 08:04 PM
                    • valvashon
                      LG 55UH6150- trouble powering up, then half lit screen (pictures!)
                      by valvashon
                      The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
                      Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
                      11-24-2024, 12:08 PM
                      Electronic Goldmine has replacement Irons for the ZD-978 or similar model number this the one that has the sleep function
                      by sam_sam_sam
                      This is a new item at Electronic GoldMine that has arrived within the last few weeks
                      Here is the link for them I know for sure that it works because ( I tried it on mine soldering station ) I bought two of them and I just bought two more of them so I have some extra replacement ones in my parts bin
                      Stahl Tools DDDS Replacement Iron for DSDS Stahl Solder Station
                      https://theelectronicgoldmine.com/products/g28392
                      One note it will not work for the ZD-917 or similar model number that does not have the sleep function that are the same iron but the plug only...
                      11-24-2024, 01:25 AM
                    • lostone
                      Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                      by lostone
                      Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                      First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                      When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                      05-19-2024, 11:40 AM
                    • 2elw
                      SVOD4 PCB pictures + parts
                      by 2elw
                      Hey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
                      STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
                      GW1N-UV9UG169C6/I5 FPGA - Its a...
                      07-04-2025, 12:23 PM
