Viewsonic VG191b
    Re: Viewsonic VG191b
    The lights test OK..... I put a meter across the ends of each transformers and get no readings but with power off I get the same Ohm readings for both.
    So I think something that provides power to them is not working...
    Where can I get a drawing on This board?
      OK with ohm meter on power side (input side ) of transformers I get 1 volt for the split second lights turn on when power switch is turned on
        Originally posted by Lakerat View Post
        The lights test OK.
        How did you test the lights to conclude they are ok?
        --- begin sig file ---
        --- end sig file ---
          I opened up my main monitor and A Viewsonic and made jumpers to try them.
          I also noticed that I should recap my main before trouble happens it is 5 years old
            You will be very lucky to get a schematic for this,and suspect you are at the stage where to get the thing to work, you will have to replace the Inverter board with a good one.
              I just bought a case light and tested the lights with the power supply it came with.The power supply runs off a plug from the computers power supply and has 2 plugs for lights (was 5.99 at Frys).
              Could I take 2 of these power supplys and run the 4 lights for the monitor off them would the monitor work if I did this?I would use the power that goes to inveter board to run both power supplys and they look to be the right size to go where the orignal inveter board goes. would this work?
              Thx
              P.S. link http://www.frys.com/product/5948774?...H:MAIN_RSLT_PG
                I made my home made inverter and can see the the screen change shades and see lights in back of screen (did not reapply tape yet).
                But no picture when when computer turned on but a steady green power light on front of panel... any idea on this?
                  UPDATE
                  I built my inverter and got the screen to work just meed to insulate it good
                  Total cost less than 15.00
                    UPDATE
                    Great Ingenuity! Congratulations!
