Planar PE191M function board
  • uligli
    • Aug 2006
    • 139
    I got this monitor last week and it doesn't have the function board (front buttons pcb), any idea how can i power on this monitor without the function board?
  • Toasty
    • Jul 2007
    • 4171
    Re: Planar PE191M function board
    You actually mean to say it's missing or was removed by someone.
    Use a 1KΩ resistor from ground (black wire) to each of the colored wires and see if you can trigger it. If that doesn't work, try a 470Ω. Keep dividing the value by 2 until you find a value that works.
    Using the resistor method prevents you from dead-shorting a power supply lead, as one of those wires feeds the power-on LED.
    Toast
    veritas odium parit
    • uligli
      • Aug 2006
      • 139
      It was removed by someone. Thanks for the advice, will try the resistor trick.
      • uligli
        • Aug 2006
        • 139
        I tried with 1k ohms resistor today, it did work!!! Thank you Toasty
        Any hint to make the others buttons work? Btw those transformers are pretty hot when the monitor is on, i'm a little worried about that.
        • Toasty
          • Jul 2007
          • 4171
          Well, I would think that one is constant power to run the LED(s) on the power switch or other indicators. One is probably for bringing up the OSD menu. The buttons could use power to the line to cause function, or ground the line like you have done. Depends on how the missing board was set up.
          My monitor has [+] & [-] buttons. Then a [M] menu button which doubles as a [select] button when the OSD is up. The last button selects one of 4 signal source connectors - D-SUB, DVI-D, S-VIDEO, COMPOSITE.
          Hot transformers could be failing tubes, or the caps are starting to go. What are on that board, or have you recapped it already?
          Toast
          EDIT: Manual -
          It shows 5 buttons and 1 indicator light for power. That accounts for all 6 wires plus the ground makes 7.
          veritas odium parit
          • bonney
            • Oct 2008
            • 74
            That monitor looks the same as Proview and Mag
            • Rtech
              • Jul 2010
              • 1095
              Have had a lot to do with some Proview monitors,and the 900P are virtually the same as at least one Mag one,but this is certainly not 900P or 700P.
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • ugamazing
                Assistance with identifying resistor value on 820-02918 A2992 board?
                by ugamazing
                Working on a 2023 M3 A2992 unit with 820-02918 board, and it uses a new USB-C power architecture, with rectangular controllers. I do not have a perfect-matching board, so have been repairing this one the old-fashioned way (slowly).
                I managed to blow-away a single resistor that I can't find and can't determine the value of. It connects to ground, so I went ahead and stuffed it with a 100K resistor in case it's a simple pull-up. But, I'm now having issues with that side of the board, and am curious if it's possibly related to this resistor! I have no schematics and no board view, so...
                09-06-2024, 08:33 AM
              • penangit
                Hp v193 monitor power supply board
                by penangit
                Hey everyone,hope everyone is fine, I got an issue hoping you guys can help me,
                I got a HP V193 monitor it has a E59670 now i got a few of these, been using them for long time now, however this particular monitor was blacking out for a few times then after unplugging and plugging it back in it gets back to normal until now its dead.
                I tried switching the power supply board with another similar monitor and it works,so I'm trying to fix this power supply board I got some basic in electronics as a hobbyist.
                Steps taken so far:
                Checked all...
                02-21-2023, 04:00 AM
                by momaka
                03-15-2023, 10:17 PM
