2007FPb turns off after 0-3 seconds
  • mabrowning
    • Aug 2010
    • 5
    I picked up a Dell 2007FPb from the trash pile at work with the sticky note "BAD; power fails"
    I opened it up and noticed it had a blown fuse. I replaced the fuse, and now it powers on and the LCD displays the Dell startup splash. The backlight works, so the inverter appears to be ok. However, after a seemingly random time (longest I saw was ~3 seconds), it turns off; not just the screen, the power/status LEDs as well.
    I visually inspected the power supply board and there don't appear to be any bad capacitors or other components (although I suspect that a capacitor is indeed the problem).
    Any suggestions on what to try?
  • PlainBill
    • Feb 2009
    • 7034
    Re: 2007FPb turns off after 0-3 seconds
    The second step is to measure the output voltage of the power supply. Often the voltages are labeled.
    The third thing to do is to take pictures of the front and back of both boards. Read just about any thread where retiredcaps made teh second post and you will see suggestions on taking good pictures.
    The first step is to answer the question 'Was this test done with a signal applied?'
    PlainBill
    • mabrowning
      • Aug 2010
      • 5
      I snapped pictures of the front and back of the power supply board. When I listen closely, I do hear a small clicking at approximately 10Hz. The output line is holding steady at 18.9V.
      No signal is applied.
      Looking closer at the board, several inductors (L610, L612, and L701) do appear to be leaking...
      • retiredcaps
        • Apr 2010
        • 9271
        Apply a source and retest. Most monitors will turn off with "no signal" and go into sleep mode without a source. If that still fails, post a picture of all your boards (inverter, and logic).
        That could be glue used in the manufacturing process to hold the inductors in place until soldering or final assembly? It may have been white but turned brown due to age and/or heat?
        --- begin sig file ---
        --- end sig file ---
        • PlainBill
          • Feb 2009
          • 7034
          Excellent pictures.
          18.9 volts is an unusual voltage. I'd like pictures of the logic card - front and back. I'd suggest doing minimal testing; I suspect a regulator on the logic card is shutting down due to overheating.
          That's an illusion. Nothing in an inductor to leak.
          PlainBill
          • mabrowning
            • Aug 2010
            • 5
            Ok, I tried with a source attached, just in case, and it still exhibited the same symptoms. It doesn't look like a sleep mode power-off, it happens mid-startup.
            I was thinking that R615 was shorted, but the resistor code(Br Gr Slv) says its .15 Ohms...
            Hmm... since inductors probably don't have electrolytic fluid in the, you're probably right about the glue.
            I'll post pictures of the other boards, too. I guess since there's a steady ~20V, it might not be the power supply...
            Not sure if this is relevant, but at the positive terminal of D606, at the solid black silkscreen boundary, there is steady AC~0.536V.
            • retiredcaps
              • Apr 2010
              • 9271
              We are talking 18.9 or 20V DC right? Also, on which pins?
              I have a LCD with secondary voltages of 5V and 19V DC.
              If you are getting stable secondary DC voltages your power supply is likely working okay.
              • mabrowning
                • Aug 2010
                • 5
                I was doing testing on it with all the boards connected, but with the panel disconnected. At first, I heard a whine every ~3-4 seconds, corresponding to the previously witnessed power off. Right before the whine, the voltage on the 3.3V secondary line would drop and then recover. The 19V (18.9V) stayed constant the whole time.
                However, while I was testing, this behavior stopped. The 3.3V stayed constant. I tried to get it to repeat by unplugging from mains, draining the big cap, and replugging, but no avail.
                On a hunch, I reconnected the panel, and lo and behold, it works! Its been running for 20 minutes so far, no problem.
                I don't think I did anything... all I was doing was pressing on solder pads testing with the multimeter. Maybe I pressed a loose one back tighter?
                Anyway, thanks a bunch for helping me out. If it starts turning off again, I'll probably come on back.
                • mabrowning
                  • Aug 2010
                  • 5
                  Well, we just had a dip... but it came right back. I guess I'll just "monitor" it(hehe) and see how frequently this happens and decide if its worth the effort to correct.
                  Edit: another one, within a few minutes.... looks like I declared it fixed too soon.
                  Tomorrow I'll get pictures of the logic board and hopefully you can help me pinpoint the regulator(s) and how to test them.
                  • PlainBill
                    • Feb 2009
                    • 7034
                    The symptoms you describe are classic for a bad solder joint. They are easy to fix once found. The problem is finding it....
                    PlainBill
                    • war6763
                      • Jan 2010
                      • 12
                      PlainBill
                      Definitely agree. I was having a similar issue with the same monitor. Went ahead and put the board in my reflow oven and the problem was solved!
                      • zklgfs
                        Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                        by zklgfs
                        I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                        08-11-2025, 02:14 PM
                      • twonk9098
                        Lenovo Legion 5 high fan spin turns off after 34 seconds
                        by twonk9098
                        I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                        I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                        I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                        I have tried a few new bios but exactly...
                        07-14-2024, 11:19 AM
                      • beetle1303
                        Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                        by beetle1303
                        I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                        On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                        01-13-2025, 08:49 PM
                      • Rick_1234
                        LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                        by Rick_1234
                        Good evening, gentlemen.
                        I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                        To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                        https://drive.google.com/file/d/1L6S...ew?usp=sharing
                        Things I tried
                        - Bought a new AC adapter thinking that was the problem but the problem...
                        06-22-2024, 04:44 PM
                      • Kambi13
                        Dell Inspiron 3542 Turns on works for 30 seconds to 1 minute then turns off
                        by Kambi13
                        Hi all need some help, I've got a Dell insprion 15 3542 that turns on works for about 30 seconds or sometimes a minute or two and then turns off and wont turn on again until I remove and replug the power connector
                        Not heat related, everything is ok regarding to that.
                        All voltages are present.
                        Wondering if this as anything to do with one wire circuit, the charger is not original, but it was working fine
                        Motherboard is Cedar 13269-1 F3XMC Rev A00...
                        07-12-2024, 06:10 AM
