Onkyo SKW-791 subwoofer
  • redbaron1007
    • Jun 2021
    • 107
    I've got an Onkyo SKW-791 subwoofer in right now that isn't powering on. Or at least the indicator light isn't coming on and the system it goes to can't detect/connect to it. It's drawing 0.7W from the wall when plugged in according to my kill a watt. It has a hissing noise constantly whenever it's plugged in, but the hiss isn't coming from the speakers this is when the board is pulled out of the housing and sitting on my bench. The hissing nose is still present even when the speaker is plugged in, but nothing comes out of the speaker.
    The first thing I did was replace the audio amp (IRFI4212H)(light blue on the topside picture) because I was not getting diode readings on all the legs when it was out of circuit. I compared the old one to the new one and I was missing readings on two of the pins. I put it in and nothing changed, but the pins are all still reading the same as they were before I put the chip in so I don't think it's blown.
    I got it to "turn on" once by just plugging and unplugging it a bunch of times and it was drawing 7W from the wall and the hiss went away, but I haven't been able to make it do that again. The one time it did draw more power I hit it with my thermal camera and was getting ~150F-160F on the resistors next to the two large caps on the amplifier side of the board (marked in orange on bottom red on top), but they are reading fine in and out of circuit. The other area that was getting warm (130F) was just below the audio transistor (around the two diodes below the black circle on underside of the board.)
    I only found one short on the board and it was on the AC pins of the bridge rectifier on the amplifier side of the board(light orange). When I removed the rectifier the short was still there, but I was only able to trace it back to the primary transformer. when I checked there was no AC present on this bridge. On the DC + leg of the bridge I'm getting 45V and on the - 55V.
    I found 12V on one of the diodes near the secondary side line, but I don't remember which one it was. I have not been able to find 5V or 3.3V anywhere on the board. Most places I check give me 44v-45V or nothing. The 78m12a (dark blue underside) next to the audio IC read 44V on all three pins when I checked using the gnd from the transistor on the bottom circled in red, but 0V when I checked using the gnd of the heatsink (black underside). I got the same readings on everything else when I checked using both gnd points. On the 78m12a when I checked in diode mode none of the pins seemed connected to any gnd point I checked from anywhere on the board, but none of the legs were shorted together.
    I did check all the large caps on both sides and they are charging up to their rated values. When I pulled them out and tested them in my component tester the capacitance and ESR where within spec. I haven't checked every individual capacitor, but I did random sample a couple from around the heat spots and did not have any that were out of spec.
    I'm not really sure where to go from here other than pull all the caps and test them. I'd say throw in the towel is an option, but I'm to stubborn for that.
  • spiros.p
    • Dec 2020
    • 89
    • Greece
    Re: Onkyo SKW-791 subwoofer
    the problem may be between amp and psu.check all smd trans and diodes under board i am not an expert but check and the optocouplers.is god to have the service manual.
    • redbaron1007
      • Jun 2021
      • 107
      I checked all the smd transistors and diodes and none of them were shorted or reading something I would consider to be out of the ordinary. I pulled the optocouplers, but I haven't had a chance to test them yet and won't be able to check them again until next week when I go back to work.
      I wish I could find a schematic, but I haven't had any luck when I've tried looking for one.
      • alfatv
        • Sep 2020
        • 353
        The pins of big transformer look suspicious, you should resolder them.
        • lotas
          • Jan 2016
          • 4611
          • Russia
          Onkyo SKW-791 = Onkyo SKW-591 Service manual
          • redbaron1007
            • Jun 2021
            • 107
            I finally got a chance to go back to my shop after the holidays and I tested out the optocouplers and they're testing fine. Same still goes for all the other transistors and diodes on the underside of the board.
            I tried touching them up and nothing has changed. I did notice the hissing noise is in pulses at the beggining of the board getting power and then becomes constant as the amp draw of the board goes down.
            Thank you for that manual I might actually have a chance of figuring this one out now. I'm going to have to go over it tonight or tomorrow and see if I can't figure out where I'm loosing power. At a cursory glance it looks like the voltages I was getting initially are correct I just need to figure out why they are disappearing and hope that whatever's causing it is something I can actually find a replacement for.
            • R_J
              • 9546
              Replace C963, see if that corrects the problem.
              • redbaron1007
                • Jun 2021
                • 107
                I tried replacing it and nothing has changed. When I get more of a chance tomorrow I'm planning on checking some voltages on the different IC's on the underside of the board. Now that I have the schematic that should help a bunch I'm hoping.
                • AstutePauciloquent
                  Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                  by AstutePauciloquent
                  Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                  I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                  11-23-2023, 11:02 PM
                • rustinjust
                  Please help, subwoofer connected to tv, read description below
                  by rustinjust
                  I've got a subwoofer that I've had for nearly 20 years, it did come with a basic remote which I've lost. It's a generic make of subwoofer, I can't see a brand sticker on it. It comes with 2 speakers.
                  Question recently I've connected it up to my tv which has greatly improved the sound on my tv, however I'd like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                  Is there a way of...
                  10-28-2023, 07:09 AM
                • rustinjust
                  Please help, where can I get a remote for my subwoofer?
                  by rustinjust
                  I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
                  Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                  Is there...
                  10-28-2023, 03:43 AM
                • Fripacks
                  Onkyo model SKW780 Subwoofer
                  by Fripacks
                  Hi guys, I have a subwoofer Onkyo model SKW780, one zener diode is short, I don't know the value, the location is D920 in the Power Supply Board, someone know the value of this zener?
                  12-21-2021, 03:19 PM
                • corrize
                  Where to find a very small fpc connector 0.3mm between 2 pins ?
                  by corrize
                  Hello, I search this connector (oxydated).
                  It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                  I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                  I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                  Do you know how to find this connector please ? What is the exact name for find it ?
                  08-06-2024, 05:25 PM
