electrovoice_zlx_15p up in smoke
  • DukeWadd
    • Apr 2022
    • 11
    one of electrovoice speaker stopped working the other day pulled it apart and found a whole section burnt up. replaced q1(mosfet) and a bunch of resistors around it. turned it on and it worked all voltages are there (+12 +15 -15) but then it started smoking again in a different area resistors R57 and R37. cant find anything else shorted but if i replace those burnt resistors they just get smoking hot and burn not sure why. added the schematic with whats bin done any help would be appreciated about to throw in the towel on this one
  • CapLeaker
    Leaking Member
    • 7991
    Re: electrovoice_zlx_15p up in smoke
    Check the gate drives, maybe one is stuck on. What is VCC doing on the 3845? If the FET was totally short on all pins, it dumped full power to the gate drive.
    • DukeWadd
      • Apr 2022
      • 11
      finally had time to look at this again
      the 3845 vcc was 8.3vdc
      • check12
        • Nov 2012
        • 103
        I repaired two of these with similar problems a few months ago.
        As well as replacing all the burned resistors & Q1 I also checked all components around the TL3845 and ended up replacing:
        I2 = Gate driver IC TL3845
        R62 - R71 = 1ohm resistors (replaced with single 3W 0.1ohm)
        Q1 = Mosfet 17N80C3 replaced with Toshiba TK31E60X,S1X
        R26 = 100ohm
        C48 = 100nF
        R120 = 180ohm fusible
        C49 = 0.1uF
        R28 = 150ohm
        R100 = 100ohm
        R121 = 680ohm
        D10 = Bat54 (replaced with Bat54C)
        Q8 = 6B = BC817 (2N3904)
        One also had problems on the pre-amp board that was sorted with some new MC33178 op-amps and a new gain pot.
        Both speakers back in service again ... one last thing to watch for is I found that one of the TDA8953 woofer amp chips was not making good contact with the raised heatsink platform for it (check with a torch from several angles when bolted down) ... I sorted this by replacing the original 1mm thermal pad with a 2mm pad.
        • DukeWadd
          • Apr 2022
          • 11
          Finely got the TL3845 in mail and that fixed it, stopped R57 and R37 from burning up.
          • CapLeaker
            Leaking Member
            • 7991
            Congrats! Another device saved from the bin!
            • TinkerTron
              Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
              by TinkerTron
              Hey everyone,
              I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
              Instead, here's what's been bugging me so far:
              The schematic...
              03-06-2025, 02:03 PM
            • brightest_z
              Hot Air Blew Away Resistors Near Bios
              by brightest_z
              Hi All - I'm in the midst or reprogramming the bios on my gen1 Surface Laptop Studio and I accidentally blew away 2 resistors nearby the bios. I don't have another board to measure values of the missing resistors and schematics aren't available, bbut the bios is a 6x5mm Winbond WSON8, W25R256JWPQ model. The traces are conductive to Pins 3 and 7 (IO2 & IO3 respectively) so I have reason to believe they are 10k pull up resistors since IO2&3 pins are used for Quad SPI instructions.
              Does anyone with more knowledge, and experience than I, know if this is the case?
              12-11-2024, 08:34 PM
            • karatzdi
              Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
              by karatzdi
              I know some might say... just buy another one. Sell it as parts..!
              So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
              Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
              Spent some time downloading the Service...
              06-11-2024, 08:38 AM
            • jinu_j
              LED driver circuit. Burnt Resistors
              by jinu_j
              Hi Folks
              This has to do with a LED light driver rated for Output - DC36-65V 300mA. This is used to drive a 15W LED panel light.
              Now this does not work so opened up and found 2 resistors burnt to crisp. Sensing a learning moment, i looked around the circuit to figure out that it is built around the OB2538 chip. The circuit to a large extent follows the sample application circuit mentioned in the data sheet. I have traced the actual circuit and the same is also attached for reference.
              But i have some queries on this circuit
              1. The resistors that burnt to crisp...
              08-26-2020, 01:24 AM
            • repair-it
              Pioneer VSX-40 ,Trying to ID these resistors
              by repair-it
              I am trying to determine why these two resistors are the colors that they are. This is a Pioneer amp. The ones I am concerned about are the RED & GREEN colored resistors. I need to replace them and want to be sure to use the properly rated component....
              12-16-2024, 02:08 PM
