PMA980R Denon amp, subsonic filter function advice.
  • zen
    • 511
    Hi all
    Subsonic filter doesn't seem to have any effect, whether on or off.
    Can anyone help?
    Manual might shed some light.
  • spiros.p
    • Dec 2020
    • 89
    • Greece
    Re: PMA980R Denon amp, subsonic filter function advice.
    what filter is this? 20-30-40 hz?under 40hz you don't listen nothing.only in heavy bass track and volume up you can see the bass woofer lose some movement when you careffuly looking.subsonic filter is allways good thing speakers and amps work more acurate and relaxing.other way if the amp + sub is designed for very low frequencies or you heard music in low comfortable level you left the filter in the off position.
    • zen
      • 511
      Thanks Spiros
      Not sure on frequency.
      Will need to check user manual.
      • zen
        • 511
        Discovered a very useful low frequency test on You Tube, from around 4HZ TO 20HZ.
        Subsonic filter definitely makes a difference, taking the edge off the bass response, but to be honest with most music you wouldn't even notice it.
        https://www.youtube.com/watch?v=n5visUIa2MY
        • petehall347
          • Jan 2015
          • 4440
          its for when you are using a turntable
          • zen
            • 511
            Hi Peter, can you give more detail please.
            • petehall347
              • Jan 2015
              • 4440
              its to stop any rumble .or so i was led to believe
              • diif
                • Feb 2014
                • 6978
                • England
                Vinyl can warp and this can cause woofer pumping where the warps cause undesirable sub 20Hz frequencies.
                https://support.arendalsound.com/hc/...ubsonic-Filter
                • zen
                  • 511
                  Ah that makes sense, cheers guys, therefore function seems to be working then.
                  • madan1
                    Modding HPF filter
                    by madan1
                    Hi everyone.
                    Recently scored a dead amp from a mackie srm1801 subwoofer and after fixing it, now I'm thinking about a home cinema/party subwoofer project.
                    Most likely I will use a 15" JBL woofer, which I already have and a diy box.
                    After reading the mackie user manual, I noticed that it has a 40hz HPF (labeled as "36Hz BUTTERWORTH HPF" in the SM) to protect the speaker from low frequencies. Indeed this seems to be good idea for the intended usage - professional music subwoofer, but bad for movies, where one would expect to "feel" the SUBwoofer....
                    09-24-2025, 02:06 PM
                  • Califauna
                    Help with boom box modification
                    by Califauna
                    Hi, this is more of a project help request than a troubleshooting question. I hope I can post it here.
                    I have a W-King D8 Bluetooth boom box which I'd like to modify with some external speaker output jacks and some buttons to switch the internal speakers on and off.
                    From factory the specs of the boom box are:
                    -Power Input: DC 5V
                    -Speaker Output Power: 2 x 25W ( confirmed by Youtube channel Hartdegen review as 12.5W RMS per channel)
                    -Drivers:
                    -2 x Woofer, 70mm, 10Ω, 70mm,15W
                    -2 X Tweeter, 8Ω, 30mm,10W x 2
                    -Frequency...
                    12-04-2021, 01:53 PM
                    Electronic Goldmine has replacement Irons for the ZD-978 or similar model number this the one that has the sleep function
                    This is a new item at Electronic GoldMine that has arrived within the last few weeks
                    Here is the link for them I know for sure that it works because ( I tried it on mine soldering station ) I bought two of them and I just bought two more of them so I have some extra replacement ones in my parts bin
                    Stahl Tools DDDS Replacement Iron for DSDS Stahl Solder Station
                    https://theelectronicgoldmine.com/products/g28392
                    One note it will not work for the ZD-917 or similar model number that does not have the sleep function that are the same iron but the plug only...
                    11-24-2024, 01:25 AM
                  • eduaqa
                    Amplifier - bad sound when loud sound on bass
                    by eduaqa
                    I'n trying to fix a M&S SYSTEM DMC-1which have following problem:
                    I'm using FM station to do this fix, I works perfect if volume below around 8 or if bass is set to zero, the sound can go to 20 without problem, but if I set bass to maximum and try to go over 10 the sound comes distorted ... I saw a video on YouTube the person saying about the main capacitors on the power portion, but I disconnect the main transformer and inject direct to the capacitors PINs my bench power supply -23v 0v +23v, but still distorted so I think the problem is not the capacitor neither the transformer...
                    08-06-2022, 11:28 AM
                  • Salvador Pérez
                    Help identifying the function of these two coils - MSI Delta 15 (MS-15CK1)
                    by Salvador Pérez
                    Hello everyone, I'm troubleshooting an MSI Delta 15 (MS-15CK1) motherboard, and I need help identifying the function of the two coils marked in the attached image. The laptop powers on and responds to the keyboard, but the screen does not turn on-neither the LCD nor the backlight. I've checked the main power rails, and all other coils seem to have the expected voltages:
                    • 0.91V for the GPU
                    • 1.7V for VRAM
                    • 3.3V and 5V rails 1.8V for the BIOS
                    • 0.9V for the CPU and iGPU 1.2V for the RAM
                    However, these two coils are not showing any voltage....
                    03-10-2025, 11:50 AM
