Technics Transformer question.
  • angelos
    • Dec 2012
    • 568
    • South Africa
    Hi there,
    I have this CD player from a Technics Component unit whose mains transformer is blown. The primary winding is open circuit. This transformer has many secondary windings on its secondary side. This transformer is obviously obsolete.
    I need to know if my trick for a alternative transformer will work. Please check the attachment for explanation.
    I want to use three separate transformers to be equivalent like the original transformer.
    The only thing a bit dodgy is the connection of the 9.6V and 12V outputs of which there is a interconnection between the two windings. As you can see the 12V winding connects to the center winding on the center tap of the 9 - 0 - 9
    I am aware that the three transformers i will use must be similar in VA size.
    Can I do it like I have hand drawn on the attachment?
    Your input would be greatly appreciated.
    Regards
    Angelos
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8696
    Re: Technics Transformer question.
    generally should work...
    the VA ratings are tricky, technically the sum of the VA ratings of each transformer should equal the VA rating of the original, but that's not a real degree of flexibility - it's the downstream circuitry that dictates what the VA ratings need to be.
    • angelos
      • Dec 2012
      • 568
      • South Africa
      Thank you very much, i will proceed carefully.
      • lotas
        • Jan 2016
        • 4555
        • Russia
        Usually transformers have a thermal fuse in the primary winding, sometimes its conclusions are even visible, put a jumper and it will work again.
        • angelos
          • Dec 2012
          • 568
          • South Africa
          Yes, i know about that but this transformers winding exploded and you can see a small black crack through the epoxy on the underside. It was lightning that killed this transformer.
          • Spoonicks
            Samsung 2233SN no CFL backlight
            by Spoonicks
            Have a Samsung 2233SN with no CFL backlight. Testing with a flashlight, I can see the image is displayed, but the backlight fails after some seconds.
            Sometimes, after being off for a while, the backlight will remain on for a couple minutes, but most of the times it fails immediately.
            I tried to follow the guide present in this forum, but so far I haven't de-soldered any components. I need some advice on how to proceed to diagnose this display.
            Following the guide I tested the following:
            The transformer...
            07-01-2023, 11:10 AM
          • ohren
            Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
            by ohren
            Hello!
            I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
            Measured voltages with no load:
            After rectifier diodes
            12V: 6.17 V
            5V: 5.67 V
            Secondary transformer pins AC measurement (really don't know if this says anything)
            12V: 2-2.5 V
            5V: 1.04 V
            I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
            03-18-2023, 10:33 AM
          • mikey5791
            Is it possible for transformer substitution?
            by mikey5791
            Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
            Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
            My questions are
            1. How do i test to see if the transformer is in good working condition?
            2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
            Hope you guys understand what i was asking. My intention is...
            11-03-2022, 02:11 AM
          • dennis_elx33
            3PHASE STEP-DOWN Transformer in Check
            by dennis_elx33
            Hello All,
            i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
            Problem statement: Power tripped Off
            Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
            Action Done:
            1) Replaced the faulty parts with good spare.
            2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
            12-02-2024, 06:52 AM
            ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
            This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-06-2024, 04:40 PM
