Re: Help with blowing transistor NAD T752 receiver
While I remove the board, I'll remove R518 and check it out of circuit just to make sure.
My test meter is a Fluke 87V, so I think it is ok. Tried it with another one I have a Uni-T and it does the same thing - as soon as I connect both probes from the meter, it goes into protection mode. R518 measures 3.275K so I think it is ok.
The hole near C572 is the hole to insert the screw that holds the transistors to the heat sink, it is a pass throught hole.
So the only thing left, is a flaky Q506 because I didn't short my probes again. When I do the same type of reading on Q518 it doesn't do this - it gives a reading and stays on green light.
So I guess I'll replace Q506 and try it again. Will report back later.Last edited by rddube; 09-18-2022, 02:24 PM.Leave a comment:
A good test meter should not cause going into protection mode. Maybe you have a flaky Q506 or shorted your probes to something again?
Perhaps a broken R518 would also cause the device to go into protection.
BTW that hole near C572/R528 looks very suspicious, if there is a screw there, is it shorting C572 with that jumper J48?Last edited by eccerr0r; 09-18-2022, 12:12 PM.Leave a comment:
How weird can you get, as soon as I attach my probes across Q506 and try and start it, it gives me no voltage reading and goes immediately into protection mode (red light). If I detach my probes, it starts up with green light ??? I tried to take a reading across Q518 and got -3.35V and the amp started normally (green light)...what's going on?Leave a comment:
As in previous messages still would like to know the voltage at Q504-E (or voltage at R513) and what happens to the voltage across Q506 as you change R522. Yes the spread is wrong compared to the other channels, but I'm at a loss as why all the transistors are good except that it burns the finals. Again the closer the voltages are together on Q506, the safer for the downstream transistors, but it produces odd-order harmonics in your music when playing which may be unacceptable to your ears.
Will do measurements across Q506 as I change R522 and report back in a few minutesLeave a comment:
As in previous messages still would like to know the voltage at Q504-E (or voltage at R513) and what happens to the voltage across Q506 as you change R522. Yes the spread is wrong compared to the other channels, but I'm at a loss as why all the transistors are good except that it burns the finals. Again the closer the voltages are together on Q506, the safer for the downstream transistors, but it produces odd-order harmonics in your music when playing which may be unacceptable to your ears.Leave a comment:
Eccer0r and Petehall347, do these readings look ok to you? The only one that is close to 600mv is the left channel (Q506), in fact it is below, but it is positive on C and on E, and also on each side of the resistor, whereas the other two channels have positive and negative on each side but are more in the 1.7V area. Not sure how to interpret this, is there something wrong with the negative side of the left channel? Many thanks for your input!Leave a comment:
So here are my latest measurements with the .22 ohm resistor changed and after having removed and checked Q506, Q507, Q508, Q562 and Q563 to be good:
Q506 C to gnd +0.465V
E to gnd +0.389V
Q518 C to gnd +1.7V
E to gnd -1.57V
Q530 C to gnd +1.785V
E to gnd -1.63V
Looking at board such as the photo I uploaded:
R5143 from left to gnd +0.365V
from right to gnd +0.386V
R5146 from left to gnd -1.04V
from right to gnd -1.05V
R5149 from left to gnd -1.052V
from right to gnd -1.053V
Q504 B to gnd -62.7VLeave a comment:
Whenever you measure a resistor, it needs to be measured out of circuit. Too many side paths will affect your measurement. I kind of expected that emitter resistor to affect your reading and there was never a "short" on the right channel.
So it looks like the fried transistors fried the resistor too.
and yes, the skewed in-circuit measurement of the resistors with that hack added would affect reading, my calculation resulted in around 198Ω which matches up quite well within about 1% of 196Ω.Leave a comment:
just so you know those double resistors also known as emitter resistors in this case are 0.22 ohms . the k is tolerance .Leave a comment:
Ok, so I think I finally found the problem in that the .5K measured on the 1K resistors seems to be ok - explanation: right channel was giving .5K on those resistors while the left channel was giving me 1K...searched everywhere only to find out that the .22K double resistor on the left channel R527 was open! Fortunately I had a spare one and replaced it and now both the right and left channel read .5K on the 1K resistors when installed.
Everything seems to balance well, but now R520 and R544 measure 196 ohms, while R573 (the center and good channel) measures 217 ohms, not too sure why but is this normal with 1K resistors instead of finals?Leave a comment:
Hold on gentlemen, I removed the board and checked some components only to find that on the right channel, I have a partial short as the 1K resistors I installed measure .5K instead of 1K. I have to trace it down now.
Don't spend too much time analyzing the left channel (Q510/Q509) as I have to get rid of this short.
Will be back with new measurements once I find it. Sorry for the inconvenience.Leave a comment:
Check your component designators and signs again, you have R5143 listed twice and you have +-4.41V for Q518-C. Assuming you meant -4.41V, the C-E drops all look reasonable now though the "second" R5143 spread looks too close. Again something doesn't look right, when the spread is close the transistors should be safe from destruction.
Now Q504-B is way too high, it should be -65+1.4 = about -63V, but the voltages downstream do not seem to correspond to Q504 being turned on...
Sorry was trying to go too fast, here are the corrections to my voltages that I checked again:
Q506 C to gnd +1.51V
E to gnd -1.451V
Q518 C to gnd -4.41V
E to gnd -7.92V
Q530 C to gnd -3.97V
E to gnd -7.44V
R5143 from left to gnd -6.5V
from right to gnd -5.82V
R5146 from left to gnd -4.4V
from right to gnd -3.2V
R5149 from left to gnd -3.2V
from right to gnd -3.1V
Q504 B to gnd -6.2V
Q504B is -6.2V not -62V.Leave a comment:
Now Q504-B is way too high, it should be -65+1.4 = about -63V, but the voltages downstream do not seem to correspond to Q504 being turned on...Leave a comment:
Ok, so here are my measurements with 1K resistors from Base to Emitter on Q509 Q510 and Q521 and Q522:
E to gnd -1.451V
Q518 C to gnd +-4.41V
E to gnd -7.92V
E to gnd -7.44V
R5143 from left to gnd -3.2V
Q504 B to gnd -6.2V
I double checked again every measurement.Leave a comment:
Okay that is a clue that something's still wrong with the R522 channel unlike the R545 channel. Spread is too low.
Next I'd be curious what the voltages are on R513, hopefully both are way negative... If they are, Q504 is probably bad. If they aren't, R513 is bad.
... but still not quite sure why this would cause final roasting... more data needed...Last edited by eccerr0r; 09-15-2022, 10:27 AM.Leave a comment:
yes base to emitter. don't adjust anything yet .Leave a comment:
by wolf1976hi i have a receiver that is destroyed from the overvoltage i guess
my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
the motor fan has not label
i have an other receiver operational
In your opinion can i measure the voltage at the output ?
what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
thanks in advance...07-23-2025, 03:12 PM -
by CdDvdFlashFor this Dick Smith TV GE6878 (Thompson) I replaced the broken remote with a universal it kinda works though if its more than a few meters away sometimes the buttons register and sometimes they wont so I bought another remote from another brand and it has the same problem, I've had an old TV in the past that the sensor died completely and I replaced it to fix it could this be a similar problem? I tried looking for a service manual, spare parts for a receiver and a parts list but I couldnt find any info. can someone please help me to find the info online for a service manual or where I can buy...
by CornitoHello team,
I've got a new issue with a Denon Avr-2700H.
After several minutes working, receiver stops playing sound with a poc eared in the speakers.
Receiver still work and display video with error message on display.
Seems to me that is the main output relay.
I'm looking for the service manual that I can't find for the moment.
Does somebody have it?
Regards...-
by magnehHello
Got this speaker from a friend , defective. Power led comes on and off , in a loop.
Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
Still, I need to replace this transistor.... -
by JayPoorJayHello All... Grateful for this site!
I just repaired a 70inch Sharp flat screen I found on the curb in NYC (there are 1000s) thanks to the good folks on this site
I have a question about an audio signal from a TV that only has a headphone jack as a audio output source. I have it hooked up now with a headphone style adapter that converts the headphone plug to an RCA. I plug this into my PHONO input on the receiver. To play it this way I need to turn volume waaaay down on TV and volume up higher than I think I should on the receiver. I get undertone hissy sound, blunt...-
- Loading...
