Rotel RSDX-02E headphone mode
    Hi!
    I need help to disable headphone mode on this unit!
    Someone played buttons on front panel and now no sound on speakers. When i push the Surround button, only HEADPHONE MODE appear
    Amplifier does not have headphone connector in front, only 3-pin on main board and factory grounded the hpsw line
    i tried all combination on front panel, but no success....
    In sevice manual no info about full reset, only reset speakers settings to default.
    Anyone have info?
    regards
    Tom
    From internet:
    "With the unit unplugged, press and hold the STOP and DVD buttons simultaneously, then reconnect the power cord and release the two buttons.
    The front panel should read 'TEST --', and change to 'TEST JC'. Press and release the PAUSE button.
    The INPUTATT icon on the top right of display should illuminate. Power down the unit using the STANDBY button to complete reset."
      Thanks, but i can not change area code to JC
      After entering TEST mode on the display appears TEST -- and after 1 sec TEST E
        And from the service menu:
        "The methods of initialize the RSDX-02 DVD section:
        1. To set the TEST MODE on the RSDX-02, Press and hold both
        “DVD” and “STOP” keys then connect the power line to RSDX-02
        until appear “TEST xx” in the FL display. “xx” is Area code.
        2. Press “PAUSE” button to initialize the DVD. When an indication of
        “INPUTATT” is displayed. Finish.
        3. Press Standby switch to save.
        4. The TEST mode can be changed by “CHOICE” of remote key to
        show the “Firm version”, “All FL segments”, “Check” of mechanism,
        “Expert” of Front-end."
        It says it is for the DVD section, so not really sure if this will affect the headphone mode.
          Service manual have too, and this info for DVD unit not main micom
          Firmware cd can not download from Rotel
