Sae R-102
  • mbates14
    • May 2005
    • 169
    Sae R-102
    Anyone have a schematic for an SAE R-102 receiver? i have one that someone mucked up the tuner section and a couple resistors burned, transistors shorted that dont look like the right ones, etc....
  • Agent24
    I see dead caps
    • Oct 2007
    • 5097
    • New Zealand
    Re: Sae R-102
    Have you tried any schematics websites?
    -David VanHorn
    • SluggerB
      Help diagnosing Pyle Receiver PTA66BT with burned resistors
      by SluggerB
      Spoiler alert: I am a total noob at this, just getting into the hobby
      My buddy has an audio receiver that stopped worked, everything turns on and functions but no sound comes out of any output (Speaker, AV, or Headphone) So I said I would take a look at it. I popped the cover off, and saw an obvious issue: One of the resistors on the board had burned up.
      Photos:
      08-03-2020, 07:50 PM
    • mikey5791
      by mikey5791
      Hi to all forum members,
      12-26-2024, 04:55 AM
    • DXseekerMO
      Samsung PN51F8500AFXZA broke off the tuner's F connector, can't get tuner de-soldered
      by DXseekerMO
      I can hear Fred Sanford now...."YOU BIG DUMMY".....I pulled the "F" connector out of the tuner by accident. The tuner number is BN40-00248B. Low and behold I had a scrap board with tuner number BN40-00248A. Although the tuner is different (according to Encompass.com) it's footprint on the board is exactly the same as the 248B so I decided to de-solder the tuner off the scrap board to see what I was getting in to.
      As you can see in the picture the terminals and solder pads are super small. No matter what I tried I could not get either the terminals or support...
      09-15-2021, 05:15 PM
    • CDNBrewer
      Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
      by CDNBrewer
      Hello Everyone,
      I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
      Symptoms:
      • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
      • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
      • I swapped the Left and Right surround
      08-05-2025, 09:29 PM
    • wolf1976
      wireless receiver for 6 speeds fan control with remote control
      by wolf1976
      hi i have a receiver that is destroyed from the overvoltage i guess
      my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
      the motor fan has not label
      i have an other receiver operational
      In your opinion can i measure the voltage at the output ?
      what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
      thanks in advance...
      07-23-2025, 03:12 PM
