Von Hotpoint 2.1 subwoofer
  • sarry86
    • Jun 2021
    • 90
    • Tanzania
    Hello friends, how are you doing? I have a 2.1 music system that makes scratching sound when I power it up, but after like 2 minutes it comes back to normal, after some minutes of playing musics, its Bluetooth hang and I have to switch it off then on again for it to work. I have checked all the caps none has a problem, please help me out
    • 30919
    Re: Von Hotpoint 2.1 subwoofer
    i would start with replacing those 1n4007 1a diodes with a 4a bridge rectifier!!!
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8662
      "Patent products, counterfeit will investigate"
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Checked the caps with what exactly?
        The board is basically destroyed here, take a look on the bottom, I guess the solder is melted and you have a bad connection:
        As stj said replacing this with a proper rated bridge rectifier would be one way to go.
        Another would be to throw it in the trash where it belongs:
        Whenever I see a silly fuse like that I just know the manufacturer is trying to burn my house down!
        • sarry86
          • Jun 2021
          • 90
          • Tanzania
          I did, all okay now thanks 🙂
          • sarry86
            • Jun 2021
            • 90
            • Tanzania
            Bro, in our developing countries, these types of gadgets are all we can afford. Please don't hurt my feelings 😢
            • sarry86
              • Jun 2021
              • 90
              • Tanzania
              Chong ching things 😁
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                That's not at all what I meant.
                The device would not have been more expensive to design correctly: Use a fuse with the proper distance/length.
                And place the diodes higher off the board with proper spacing, they come with long legs from the factory for a reason...
                The fact that these companies in China makes such rookie mistakes even when they save no money by doing so just shows that they don't know how to design a safe circuit.
                Having your house burn down is no fun no matter where in the world you live!
                • rustinjust
                  Please help, subwoofer connected to tv, read description below
                  by rustinjust
                  I've got a subwoofer that I've had for nearly 20 years, it did come with a basic remote which I've lost. It's a generic make of subwoofer, I can't see a brand sticker on it. It comes with 2 speakers.
                  Question recently I've connected it up to my tv which has greatly improved the sound on my tv, however I'd like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                  Is there a way of...
                  10-28-2023, 07:09 AM
                • rustinjust
                  Please help, where can I get a remote for my subwoofer?
                  by rustinjust
                  I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
                  Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                  Is there...
                  10-28-2023, 03:43 AM
                • Delicieuxz
                  I replaced all electrolytics in subwoofer, still get a hum in speakers - audio clip
                  by Delicieuxz
                  I get a faint, low hum through my PC speakers, which connect to the subwoofer in a 2.1 speaker system. The hum drives me crazy and makes me stressed. When I turn off the subwoofer, everything is quiet and I start to relax, lol.
                  Here's an audio clip of the sound coming from my speakers:
                  https://vocaroo.com/16HaryHwTx78
                  I recorded with my phone's mic right next to the speaker, and the mic picked up a lot of speaker noise over top of the hum. But I don't hear that noise in the room, I just hear the lower-pitched hum that's buried beneath all the other...
                  11-15-2023, 09:50 PM
                • Xan03
                  Klipsch Promedia 2.1 rhythmic subwoofer "pulsing" during standby
                  by Xan03
                  I have this 2.1 Klipsch set where the subwoofer emits a constant whine in standby, in addition to a constant rhythmic pulsing/thumping. Only way to make it stop is to cut power. I think this thread mentions the same issue, though my set is not a BT one: https://community.klipsch.com/index....-bt-subwoofer/
                  I think all this Klipsch gear is using crappy capacitors. Is it worth trying to replace the caps in the subwoofer amp to make this go away?
                  11-17-2024, 06:54 AM
                • jinu_j
                  How to test Subwoofer Amplifier with only a multimeter
                  by jinu_j
                  Hi Folks
                  Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
                  Problem
                  I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
                  Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
                  Any advice would be appreciated...
                  08-29-2024, 02:05 AM
