audio chopping/freezing on PC
  • paparazzo79
    • Dec 2018
    • 299
    • Bosnia
    Hi guys.
    On one of my PCs with integrated sound card (Asus Formula VIII motherboard) I've noticed that when playing music no matter over speakers or connected headphones I could hear like how can I explain,like music freezes in a split of a second every once and awhile.
    I hear just a tone like bzzzzzz,in a split of a second and back to normal.
    It's like when you listen to music on your PC and it reboots and you hear bzzzzzzzz in a split of a second when PC reboots.
    Now I'm wondering what could cause this issue?
    I know for sure it ain't speakers cuz same happens on headphones.
    master hoarder
    • May 2008
    • 12175
    Re: audio chopping/freezing on PC
    By "chopping/freezing", do you mean like a part of the sound will repeat over and over for a quick moment? (like when a video game freezes or when a CD skips very quickly)
    Or is it more of a burst(s) of parasitic noise on top of the audio, without the audio actually skipping or freezing?
    The 1st could be a driver issue or buggy drivers. Also have a few old systems that do this, and I have not figured out what causes the issue so far.
    The 2nd could be just a matter of your sound card picking up stray noise from the rest of the motherboard circuits. Sometimes, you can fix that by muting inputs that are not used. But other times, it could be just due to poor circuit layout on the motherboard. Given that this is a pretty high-end board, though, I don't think it would be poor circuit layout.
    Perhaps you can make a recording and upload it here?
    I don't know if recording through Stereomix with Audacity would allow you to capture the phenomenon... if the board even lets you record through Stereomix (a good deal of modern boards don't/can't for some reason.) If that's the case, you should be able to record the sounds with a M-M 3.5 mm jack on both ends - simply connect one end in the audio/speakers Out and the other in the audio/Line In. The play some sounds and record audio with Audacity (choose Microphone / Line In for the input and set the volume levels correctly, so that you're not clipping.) Then save file as MP3, Zip it, and upload here, if you do get a chance to capture it.
    • samson7point1@yahoo.com
      Help troubleshooting an audio problem with an RCA SGT-250 CED Player
      by samson7point1@yahoo.com
      The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
      The player processes the audio signal using two different reference frequencies. The "R"...
      04-30-2024, 11:22 AM
    • ChaosLegionnaire
      by ChaosLegionnaire
      09-13-2022, 09:02 AM
    • i_am_patch
      Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
      by i_am_patch
      Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
      04-30-2024, 08:20 PM
    • MOSSEP
      Monitor Audio RSW12 - Green light but no audio
      by MOSSEP
      Hi
      Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
      Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
      The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
      I have already tried replacing all of the...
      01-26-2025, 08:18 AM
    • grimacelord
      MacBook Air 2337 - Right I/O Board Audio IC - Alternative Replacement?
      by grimacelord
      I'm working on a MacBook Air A2337 that had liquid damage on the right I/O board. I ultrasonic cleaned the board and it all functions except the computer has no audio. I tried reballing the audio IC which is TAS5770AC0, but that did not restore audio. I could just replace the entire board, but I wanted to see if replacing the audio IC would fix it first. Mouser has a similar audio IC in stock which is TAS5770LC0YFFR, but I wasn't sure if it is compatible. I was just wondering if anyone knew if I could use the one from mouser as an acceptable replacement or if I need to purchase...
      12-11-2023, 11:13 AM
