Sony HCD-SH2000 No sound
  • Rusenga
    • Feb 2017
    • 19
    • South Africa
    Hi techs, I have a Sony hcd-sh2000 sound system which has very faint sound output behind a loud humming noise. I have tested all semiconductors voltages against ones in the schematic and all seem to be ok except mute output from system controller IC which is a 3.3v but is appearing and disappearing. I have isolated this leg but still the 3.3v is on and off. Anyone ever come across this fault please help.
    See attached the schematic and the main and amp boards.
  • Jolly62
    • Nov 2021
    • 13
    • Italy
    Re: Sony HCD-SH2000 No sound
    Did you check Q207? It seems to be the common component to mute all the amplifiers.
    • Rusenga
      • Feb 2017
      • 19
      • South Africa
      Thank you for your reply. I did check Q207 it has -3v on the collector, 3.3v on the emitter and 3.2v on the base. However pin 51 on IC100 has a 3.2v out of the IC which is coming on and off every 3s or so. I isolated the pin and there is no change the 3.2v is still going on and off. With pin 51 on IC100 isolated, the voltages on Q207 are stable. I am suspecting IC100 might be faulty but I may be wrong.
      • Jolly62
        • Nov 2021
        • 13
        • Italy
        If IC100 was faulty, I think the system would not switch on at all.
        Have you checked all the power lines?
        What about pins 63, 71 and 72 on IC100?
        Considering the "pulsing" of pin 51, I would check all the pin values arriving at IC100.
        • R_J
          • 9540
          I would suspect a bad audio output, either a bad ic406~409 or a bad output transistor Q1418~1425.
          I would check if there was any DC voltage on any of the speaker connections, it could be that there is dc on the outputs and the protection circuit on page 41, is detecting this and telling ic100 to mute any audio.
          • ChaosLegionnaire
            by ChaosLegionnaire
            09-13-2022, 09:02 AM
          • Akuanka
            Sony SLV-E780 Power Supply Issue – Clicking Sound, Need Help Identifying Faulty Component
            by Akuanka
            I'm troubleshooting a power supply issue with a Sony SLV-E780 VCR. The device clicks repeatedly but doesn't power up completely. I've already replaced five capacitors, but the problem persists.
            Here's a video link https://photos.app.goo.gl/3Xki6yvCLn67gLX78​ showcasing the sound. Based on your experience, could this be due to a transformer, diode, or another component? Any guidance on what to test or replace next would be greatly appreciated.
            Thanks in advance for your help!
            11-23-2024, 01:12 PM
          • KYBOSH
            Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
            by KYBOSH
            Previous owner said TV just went blank one day.
            They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
            Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
            The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
            There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
            I just downloaded the Sony KD-75X7800F Service Manual and...
            11-19-2024, 10:12 AM
          • x_orange90_x
            Sony Bravia KD-50X690E NO SOUND
            by x_orange90_x
            Finally got my KD-50X690E up and running after replacing the power supply. Upon testing it I noticed the lack of sound from the speakers. At first I just ignored it thinking it was set to external speakers or some other kind of audio setting. However, after actually going into settings and looking around I see nothing of this sort. I looked it up on Google and apparently a lot of people have disappearing audio on a variety of Sony TVs 🙄. I'm going to see if a firmware or software update will resolve it, if available.
            Has anyone else had this happen to their tv?
            10-05-2024, 05:01 AM
          • Audeze
            Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
            by Audeze
            I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
            Does...
            10-06-2024, 08:54 PM
