Behringer Europower PMP3000 Mixer - LED Bar Meter sticks at high level
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    I have this faulty mixer here. Basically the owner says it worked fine at one gig, then the next one it didn't
    When I power on, both the L & R LED Meters go to +4 and stay there. This is without any input and with all sliders Level Set knobs set to zero
    Also the LED meter on the 24-bit dual engine DSP goes to red (clip)
    I didn't connect an speakers but if I use headphones I can hear what I can best describe as a purring noise on both channels
    I found a schematic for the PSU There is a 10 way ribbon cable going from the PA/PSU to the mixer section.
    According to the schematic I should have on this cable, from the left hand side:
    Ground
    Right Audio
    Ground
    Left Audio
    + 15V (red wire) - reads 14.79V
    - 15V - reads 15.25V
    Ground
    + 48V - reads 46.6V
    + 5V - reads 4.88V
    I tried connecting an audio source to Channel 9/10. I ca nsee the rare some 8 pin chips on each input channel (see pics) these are marked 4580 and I found a datasheet that says this is a dual op-amp
    With my scope I can trace the audio signal on each output pin of the op-amp chips, up to the row of chips at the top of the PCB (under where the channel numbers are marked on the silk screen - 1,2,3.....9/10, 11/12
    I am getting audio signal as far as here but I don't know where to check after that. I still get the purring noise on the headphones and can't hear the audio signal at all
    There is no audio signal on the 10 way connector feeding to the PA.
    Any suggestions where to check next, and does anyone have a schematic for the mixer PCB.
    Rich
    Follow me on YouTube
    Learn Electronics Repair
  • lotas
    • Jan 2016
    • 4616
    • Russia
    Re: Behringer Europower PMP3000 Mixer - LED Bar Meter sticks at high level
    Maybe something will help
    • petehall347
      • Jan 2015
      • 4427
      • United Kingdom
      - 15V - reads 15.25V are you sure its positive ?
      check for dc voltages on the outlet to amp .
      also turn down pgm .
      also check for anything spilled into it ..drinks often get spilled into mixers
      • dicky96
        Sun Seeker
        • Mar 2017
        • 1825
        • Spain
        @petehall
        sorry no that is a typo
        +15V reads +14.79
        -15V reads -15.25
        @lotas
        Thanks for the PMP3000 rar file - this is the one I already have. From what I can see (unless I am mistaken as I am not so experienced on mixer repair) it contains the schematic for the PSU board, the schematic for the Power Amp, and schematic for a mono input channel.
        But it does not have the schematic for the main mixer section and I pretty much proved I have audio as far as the output on the last op-amp on the input channel I tested so I am pretty sure the fault is somewhere in the main mixer/DSP section.
        Could you confirm that is what the contained schematic is showing?
        • lotas
          • Jan 2016
          • 4616
          • Russia
          Well, first you need to check the power supply for ripple on the power supply 5v, 12v, + -15v (check electrolyte capacitors for capacity and esr), check grounding (gnd) between the power supply and the main boards and all connectors, check volume controls and others using multimeter (the resistive layer is erased and stops working) and disconnect the 48v power from the power amplifier.
          • CapLeaker
            Leaking Member
            • 8179
            The 48v is the phantom power for the mic’s. I am not familiar with that model, but is it possible to bypass the DSP or turn the DSP off? To me the problem is either the DSP itself, or right at the input of the DSP from what you are describing.
            • Longon
              Behringer Pro Mixer DJX-750
              by Longon
              Hi all....I have been using my Behringer mixer quite comfortably for a number of years now and generally it's been trouble free apart from a replacement crossfader. Recently input three channel fader began to bleed a little and causing the mixer to light up like a Christmas tree! I realise the unit is ageing now and although I'd put some hours on it over the years it's not been abused. Following the issue I planned on replacing the faders and ordered the necessary parts. In the meantime whilst awaiting the replacements I continued to use the mixer up until the channel fader started to give feedback...
              08-11-2025, 02:17 PM
            • Thermaltake
              Power button on Behringer Xenyx 1204USB mixer dead ?
              by Thermaltake
              Hi, I got Behringer Xenyx 1204USB mixer, and in the morning mixer was working fine, but when I came home from bike ride I turn it On but nothing happend. Phantom switch is working because red light is On, but other switch no respond.
              I brought mixer to my friend today who is electronic expert and he will tell me if it's the button or something on power supply that died. But I am 90% sure that it's power button. My question is, is it possible to put some better quality switches on that mixer than the ones mixer came with, I found them very cheap and low quality.
              08-16-2022, 03:22 AM
            • Thermaltake
              Behringer xenyx x1204usb mixer
              by Thermaltake
              Hi, I have few questions
              1. few of my pots on mixer are turning so hard, I tried to clean them and spray some DeoxIT Fader spray in it, but it didn't help. Is there any way to put some grease inside that pots whole that is on the side instead of spraing in it ?
              2. Or is it just simpler to replace them all with same ones ? I am not into pots, so am I able to put some better quality ones or it needs to be same one as they were default ?...
              09-17-2024, 10:57 AM
            • chth96
              Is it possible to test small ceramic disc capacitor with analogue meter?
              by chth96
              I read EBOOK of Testing Electronic Component and found that
              "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
              Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
              It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
              Is it really possible to test small ceramic disc capacitor with analogue...
              03-09-2024, 10:03 PM
            • Bektronics
              Schematic Digital Audio mixer RCF type M18
              by Bektronics
              Hello dear audio friends.
              I am feverishly looking for the full electronic schematic (not a block diagram) of the RCF type M18 digital audio mixer.
              The device does not make a WIFI connection with my Apple tablet and yet I have already installed the recent app on it.
              I suspect that there is a problem in the mixer itself with the WIFI card and of course I would like to see this on an extensive schedule before opening the device.
              Thanks in advance if anyone can help me with this schematic.
              Of course, all information about this digital mixer and possibly references...
              07-24-2023, 06:40 AM
