Onkyo TX-NR363 Check SP Wire
  • ShotwellCoho
    • Aug 2021
    • NZ
    Hey, I have an Onkyo TX-NR636 which briefly turns on, flashes check SP wire and then shuts down.
    I have followed this thread to troubleshoot https://www.badcaps.net/forum/showthread.php?t=42365
    However I have so far been unsuccessful - here is what i have done
    Found shorted main transistors on Right Channel, replaced both. Replaced some shorted 0.22ohm resistors for the same channel. Checked all components on vertical board (pre-amp i think) for this channel, replaced a bunch of resistors and a couple of transistors.
    Put everything back together, it blew the channel again.
    So, desoldered the main transistors for the right channel, plan was to start the amp, see that the Check SP wire goes away...it didn't, further more C5441 on the vertical board was still smoking with the main transistors out of the circuit.
    Remove C5441 and attached fly leads to read what voltage it is getting, reads ~110v....
    Hope someone can help me out here, I have run out of ideas/talent...
  • MegaZAC
    Onkyo TX-SR805 noise in one channel
    by MegaZAC
    Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
    Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
    There's some logic behind it. As soon as I select an input I get only left...
    04-23-2025, 10:09 PM
  • CDNBrewer
    Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
    by CDNBrewer
    Hello Everyone,
    I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
    Symptoms:
    • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
    • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
    • I swapped the Left and Right surround
    08-05-2025, 09:29 PM
  • Francesc V.
    Onkyo A8200 - Not the right voltages in some transistors
    by Francesc V.
    Hi:
    I am trying to repair this amplifier that I've bought as faulty. I've found some transistors damaged, the ones where I am drawing a red circle.
    With the final transistors not yet installed (the expensive ones), I've started to measure some voltages:
    Where I am supposed to have 1.12V (base Q524/Q523) I am reading -42V..................both channels don't seem ok.
    Where I am supposed to have -1.12V (base Q526/Q525) I am reading -44V..................both channels don't seem ok.
    I removed and tested Q514,Q516 & Q513,Q515 but the analyzer...
    04-19-2025, 07:17 AM
  • eccerr0r
    old X58 triple channel board... memtest86 memory speed?
    by eccerr0r
    Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
    Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
    Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
    06-28-2025, 09:06 AM
  • karatzdi
    Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
    by karatzdi
    I know some might say... just buy another one. Sell it as parts..!
    So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
    Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
    Spent some time downloading the Service...
    06-11-2024, 08:38 AM
