Harmon BDS280 failed trigger output
  • debruina
    • May 2020
    • 29
    • Nederland
    I am working on a Harman Kardon BDS280 that is not powering up its subwoofer. The subwoofer is connected with a mono 3.5mm plug in the triggerport so when the BDS starts the subwoofer powers up
    Normally the BDS outputs a 12V when powered up but in this case the voltage was missing.
    So i checked the schematics (see image) and found out that Q19 was blown. I replaced it and everything started working again. After that i removed the trigger plug cable and when i checked it again the 12V was missing again. I checked Q19 and found out it was blown again.
    Inserting or removing the 3.5mm plug from the sub causes a temp short in the circuit depending the angle. I first thought the 3.5 mount was bad but others have the same problem. Now i know you should not remove cables when its powered up but i can't believe it's this easy to kill a BDS280
    Anyway, what am i missing here? The only thing that should protect this circuit is the F201 sell healing fuse.
  • budwich
    • Jul 2015
    • 3097
    Re: Harmon BDS280 failed trigger output
    maybe the "self healing fuse" is "fully healed"... meaning it isn't tripping any more (or isn't tripping fast enough) and basically the q19 is protecting it from further "damage". :-) try testing the fuse with a 9v battery (and small resistor - 2-3 ohm). since it is "resettable", it shouldn't harm it assuming you keep the current under the rating which is quite high so it shouldn't be a problem.
      • 31305
      jack plugs have that problem as you withdraw them the tip and any rings drag across the ground contact.
      thats why they should never be used for power.
      • debruina
        • May 2020
        • 29
        • Nederland
        I tested the fuse and it looks okay, Put 5 volts on it, 5 Ohm resistor in serie and the current drops to about 0.100mA. Removed power and the fuse resets. I dont see how the transisor Q19 gets damaged. It can handle 2A and the fuse should trip at 0.7A.
        I am going to replace the fuse anyway, maybe its not fast enough.
        • budwich
          • Jul 2015
          • 3097
          As your testing suggests, the fuse seems to work but of course, speed is of the essence. As your "findings" on the "plug pull" show, it is more likely a momentary ground which causes the "spike"... which does mean that the current could rise to a larger than rated current for Q19. The spec on the fuse speed seems to suggest its reaction is in the area of .1 seconds which seems pretty fast but semis may not even like that sort of "pulse" of over current.
          • debruina
            • May 2020
            • 29
            • Nederland
            I measured the normal operating current between the receiver and the sub. It's only 5 mA so i put a 1K ohm in serie of the trigger line. This will prefent damage to the transistor. I don't understand why it is made like this. The supply voltage comes directly from the powersuppler (+12V_D). Btw it only happens on the side of the sub. The sub had a stereo jack with one side for audio and the otherside the trigger. The receiver however only has a mono jack. So you can remove the plugi from the receiver while powerup without a problem.
            Anyway I modified the board a bit. Cut wire 5 (trigger output) and put a 1K resister in between. Works like charm.
            1ste image Q19 with a hole in it :P
            2th image: modification
            • kotel studios
              Lantec PULSE 386 subwoofer - no audio output
              by kotel studios
              Hi
              I have this Lantec PULSE 386 subwoofer I got a while back laying around awating repair for quite some time. Sadly it's missing it's original speakers which it came with.
              After plugging in the mains, the LED on the volume controller lights up. When I plug in the 3.5" jack cable to my soundcard (confirmed to work), I get no audio on the subwoofer (nor the speaker jack at the back).
              The PCB is quite simple. There is a UTC4558 amp and two D6282 audio amps. When I put my finger on the UTC4558 I can see and hear the speaker "fart". Although, the left...
              11-29-2025, 04:15 AM
            • FrancescoV
              Onkyo HT-R390 no sound output, video output ok
              by FrancescoV
              Good morning everyone,
              I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
              The firmware reported is the following:
              M:1.00/11107BLP
              D:?.??/????????
              O:1.00/11107AL
              The DSP firmware given the question marks seems corrupt.
              On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
              05-11-2025, 02:59 AM
            • nath1977
              Wier WA505 SMPSU output failed
              by nath1977
              Im about to repair a failed Wier WA505 power supply which hasn't been used for many years. It was working for 30 mins or so, then started to smell bad so switched it off quick.
              On closer inspection a 1500uF cap across the 5v output has swollen. Adjacent to this is an overheated (open circuit) resistor.
              Ive removed the electrolytic cap and resistor - the cap replacement is straightforward and will replace the adjacent ones at the same time. The resistor looks like it sits across the output. Any ideas what value this is likely to be? Was thinking 100R 1/2watt would be suitable....
              10-01-2023, 06:05 AM
            • ahmedtou
              HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
              by ahmedtou
              help me please
              I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
              When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
              I will share all the details with you, including the disc information.
              Code:
              HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
              Current Profile: BD-R
              Disc Information:
              Status: Empty
              State of Last Session: Empty
              Erasable: No
              Free Sectors: 12,219,392
              Free Space: 25,025,314,816 bytes
              Free Time: 2715:27:17 (MM:SS:FF)
              Next
              08-27-2025, 08:49 AM
              NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
              by sam_sam_sam
              I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
              I bought this from an eBay seller but unfortunately they only had one
              I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
              I bought three of from them to also make battery packs with this output power limit in mind
              I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
              04-23-2025, 05:50 AM
