Vu meter connection
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    Vu meter connection
    Hi
    For a television series, I have to build copies of some audio tape recorders, the production bought these vu meters which need to be connected to the headphone audio output of mp3 players. Can anyone show me how? connected directly, they do not work. Accuracy is not required just that the instrument needle moves
    • 31214
    Re: Vu meter connection
    what is the resistance of the coil?
    • jasko_jacker
      • Oct 2014
      • 1140
      • italy
      800 ohm
      • jasko_jacker
        • Oct 2014
        • 1140
        • italy
        I found this circuit , could it work ?
        • redwire
          • 3912
          Yes, that circuit looks good for driving the VU meter. Some VU meters have built-in diode rectifiers, some have built-in standard 3k6 resistor for calibration, some have nothing inside. From your pics it looks like just the raw meter (coil) movement.
          You can use a 10k ohm trimpot and actually two resistors to mix left and right channels into mono is probably better.
          The diodes could be Schottky, or ordinary silicon if it's just to move the meter as a TV show prop. The 1N34A is Germanium and harder to find.
          A VU meter needs some power to move the needle, so a headphone output driving it all is best. So using Line Level can work but might cause loading problem and distortion to the audio.
          Adding an LED backlight would be really cool and retro...
          • jasko_jacker
            • Oct 2014
            • 1140
            • italy
            This is the unit under costruction and the original
            • chth96
              Is it possible to test small ceramic disc capacitor with analogue meter?
              by chth96
              I read EBOOK of Testing Electronic Component and found that
              "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
              Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
              It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
              Is it really possible to test small ceramic disc capacitor with analogue...
              03-09-2024, 10:03 PM
              Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
              by sam_sam_sam
              I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
              I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
              12-31-2023, 06:04 AM
            • chazzo
              CH341 programmer advice, including jumpers seemingly reversed
              by chazzo
              I’d appreciate some very basic advice on CH341x programmers. I know this topic comes up from time to time, but stuff changes, so I hope a refresh is in order. In particular, I see some unexpected things happening with jumper positions.
              [My plan is to learn to read and write 24CO2 EEPROMs via I2C. The first target is the one in my Uni-T clamp meter, but before tackling that I have some brand-new EEPROMs to practice on.]
              I have two basic Chinese programmers. One is the blue board with a CH341A and two rows of pin headers. To my untrained eye it looks like all the others....
              10-12-2025, 08:15 AM
            • jorpec
              Changing the scale of an analog meter
              by jorpec
              Hi
              I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
              I wonder how i can accomplish this so the meter would be precise at any temperature ?
              Thnaks
              01-23-2023, 10:37 AM
