Powered Speaker Hum When Plugged In
  • craftech
    • Mar 2006
    • 45
    M-Audio Studiopro 3 Relatively inexpensive powered speaker set.
    Produces 60 HZ hum. Thought it was only when turned on regardless of volume, but it can be heard through headphone jack and when you put the speaker next to your ear as soon as you plug it in. There is one large cap which I replaced. Checked solder joints on bottom of PCB. Re-soldered a few (which actually looked OK).
    Hum still there.
    https://usermanual.wiki/M-Audio/MAud...433470494/html
    Any ideas?
    Thanks,
    John
    • 31111
    Re: Powered Speaker Hum When Plugged In
    need a foto of the insides.
    it sounds like a cap though.
    • craftech
      • Mar 2006
      • 45
      Here is the PCB (Note: the red wire is a mod the guy who wrote the article did to bypass the amp to make then passive}
      https://blog.jonandtina.net/uploads/IMG_0301.png
      External view:
      https://media.guitarcenter.com/is/im...00-500x500.jpg
      My photos: (NOTE: The only large cap is the one I replaced that wasn't blown) None of the caps look like they are bulged or leaking. The brown smears are phenolic glue.
        • 31111
        that's terrible, it could even be radiating between the nest of wires!!
        • craftech
          • Mar 2006
          • 45
          Actually, when I was experimenting to find the cause I disconnected the wires and separated the chassis from the speakers, then ran them to their jacks and the hum was still there. I kind of thought it was the transformer or the transistor (IC) mounted on the heatsink.
          John
          • petehall347
            • Jan 2015
            • 4429
            • United Kingdom
            check the rectifier
            • craftech
              • Mar 2006
              • 45
              check the rectifier
              DMM set to Diode:
              Blk lead of DMM to + of Bridge Rectifier
              Red lead to each AC leg of Bridge Rectifier
              Both read .486 V
              Red lead of DMM to - of Bridge Rectifier
              Blk lead to each AC leg of Bridge Rectifier
              Both read .488 V
              My understanding is that between .4v and .6v are OK
              John
              • petehall347
                • Jan 2015
                • 4429
                • United Kingdom
                you got a scope there ?
                • petehall347
                  • Jan 2015
                  • 4429
                  • United Kingdom
                  do you still get audio playing ?
                  • craftech
                    • Mar 2006
                    • 45
                    I should have indicated that in the OP. (I'll add it in) Sorry can't edit the OP any longer.
                    The powered speaker set plays perfectly. It's just the hum you can hear when there is no music or quiet music and even when it is off but plugged in.
                    But they sound great.
                    Thanks,
                    John
                    • craftech
                      • Mar 2006
                      • 45
                      No
                      • petehall347
                        • Jan 2015
                        • 4429
                        • United Kingdom
                        short the inputs to ground and see if hum goes away
                        • craftech
                          • Mar 2006
                          • 45
                          The positive terminal? I tried grounding all the negative terminals yesterday.
                          • petehall347
                            • Jan 2015
                            • 4429
                            • United Kingdom
                            yep just short to ground .
                            • craftech
                              • Mar 2006
                              • 45
                              No change. Both RCA inputs and the 1/8" input as well.
                              In diagram 4 that I posted the terminal on the right is the 115V / 230V selector slide switch. I don't see any soldering issues. ??
                              • craftech
                                • Mar 2006
                                • 45
                                I am pretty sure the hum is coming from the transformer.
                                Is there a reasonable supplier for a replacement?
                                I don't know the specs. The sticker says BDT-48A002(SP3)
                                Shenzhen Xingyaoda Electronics Not sure if that helps though?
                                Output 15V 1A
                                Two red wires out
                                John
                                  • 31111
                                  so it's a physical hum?
                                  if it's the windings or frame that's loose then epoxy or laquer will fix it.
                                  • craftech
                                    • Mar 2006
                                    • 45
                                    I don't think it is rattling. It is mounted on a piece of gasket material and the screws are covered with a resin. It's not old so I don't think the laminations are loose.
                                    I can hear it with the unit plugged in (but turned off) if I listen close and louder when I turn it on.
                                    John
                                      • 31111
                                      it does sound like the plastic coil-frame may be vibrating against the iron.
                                      • budwich
                                        • Jul 2015
                                        • 3097
                                        The first post indicated that the sound can be hear at the headphones. This makes it less likely that the transformer is cause a vibration that is producing the electric hum. You need to see if you can follow the input area towards some capacitors and test those. In my limit experience with a "humming" guitar amp, there was a bad capacitor. It did not visually look bad but tested bad.
                                        • MobileXT
                                          Yamaha DXR15 Powered Speaker Fault LED On
                                          by MobileXT
                                          Hello Everyone! I have a Yamaha powered speaker DXR15. The problem was the RED LED Fault indicator is steady on when I power the speaker. I did open the module and I don't see any burnt component. I Downloaded the Schematic but I don't know where to start the diagnostic. Any help would be greatly appreciated. I also attached the schematic here...
                                          01-17-2025, 12:43 AM
                                        • sukaht
                                          Yamaha MSR400 - Powered PA Speaker
                                          by sukaht
                                          Hello everyone.
                                          I need help with my Yamaha MSR400 - Powered PA Speaker that I bought it used recently.
                                          It is power on, and sounding good / working perfectly fine. However after 3 - 5 minutes, the heatsink is starting to get warm, and it smells burning a little bit.
                                          I did tried multiple times on different day, event the speaker is not playing any song (input does not connect to any source, and the volume level is zero), after it turns ON, 5 minutes later, the heatsink is starting to get warm, and it smells burning a little bit. I am afraid keeping it ON longer than 5 minutes...
                                          11-02-2024, 07:55 PM
                                        • GerryT
                                          Electro Voice SXA series 100 or 250 powered PA speaker Schematic needed
                                          by GerryT
                                          Does anyone happen to have a schematic for the amplifier for an Electro Voice SXA series 100 or 250 powered PA speaker?
                                          09-17-2023, 10:12 PM
                                          HP ProDesk 600 G5 + Bluetooth Speaker 400 ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + Bluetooth Speaker 400 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Bluetooth Speaker 400 boardview and ProDesk 600 G5 + Bluetooth Speaker 400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-12-2024, 02:30 PM
                                          HP EliteBook 830 G6 + Bluetooth Speaker 400 Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 830 G6 + Bluetooth Speaker 400 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G6 + Bluetooth Speaker 400 boardview and 830 G6 + Bluetooth Speaker 400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-06-2024, 06:00 PM
