Powered Speaker Hum When Plugged In
  • craftech
    • Mar 2006
    • 45
    Re: Powered Speaker Hum When Plugged In
    Originally posted by budwich
    The first post indicated that the sound can be hear at the headphones. This makes it less likely that the transformer is cause a vibration that is producing the electric hum. You need to see if you can follow the input area towards some capacitors and test those. In my limit experience with a "humming" guitar amp, there was a bad capacitor. It did not visually look bad but tested bad.
    Would a capacitor cause a hum with the unit powered off, but merely plugged in? I know it gets louder when the amp is turned on and the volume of the hum is constant when it is turned on, but it is present (but low volume) with the on-off / volume switch off when you put it up to your ear as soon as you plug the unit in.
    John
    • budwich
      • Jul 2015
      • 3097
      hmmm... don't know. But are you saying that IF you leave the unit off for a "long time", you can still here some sort of noise thereafter? also in the headphones?
      the other place to check is the ground "plane" for the entire board. Locate the ground and follow it around especially towards the input area looking for cracks / cold joints.
      I thought about your previous post, so I take it you are saying the transformer is humming with the unit plugged in but off?
      • petehall347
        • Jan 2015
        • 4426
        way i read it is its not turning off .i thought the noise might be keeping it on and asked to short inputs to see if noise went away ..if it is the transformer its likely loose laminations or its drawing too much power or maybe there is dc riding on the mains power .
        • craftech
          • Mar 2006
          • 45
          Yes. Plug in the power cord. Put it close to your ear. It hums. Turn it on. Hum is louder and does not vary with volume knob.
          John
          • craftech
            • Mar 2006
            • 45
            I thought about unsoldering the two 15vAC transformer secondary leads from the PCB and connecting the 16vAC output of a doorbell transformer to the PCB to see if it hums. I also have a Lionel transformer that puts out around the same amount of AC volts from fixed terminals on it.
            If that works, they sell AC to AC wall wart adapters that are 1A 15vAC.
            Thoughts?
            John
              • 30979
              15-0-15 transformers are common enough.
              • budwich
                • Jul 2015
                • 3097
                Thoughts?
                John
                that will work fine for a test to see if you notice any difference. Any "brick" adapter or otherwise will work also as long as its 15v AC or there about on the output and has some form of adequate power output.
                • craftech
                  • Mar 2006
                  • 45
                  #28
                  There are only two leads coming out of the secondary. Decal says 15v 1A Red - Red
                  John
                  • craftech
                    • Mar 2006
                    • 45
                    #29
                    Tried the external transformer. Same hum.
                    I don't know what to try next. Replace the smaller caps around the larger one?
                    By pass the on-off switch / volume control (defective)?
                    John
                    • budwich
                      • Jul 2015
                      • 3097
                      it basically indicates that it is not a transformer issue. Most times "hum" is a grounding issue... usually lacking. Look / check the "grounding / common" planes on the board for cracks or poor continuity.
                      • mark97564
                        • Aug 2023
                        Try a different outlet, I had a powered sub do the same exact thing when plugged in to this 1 certain outlet, but when it was plugged in any place else it wouldn't hum at all. A year later it developed a heartbeat they the subwoofer when it was on or off, didn't matter but it always played sound. In order to stop the heart beat sound I had to replace 2 caps. So it's possible those 2 caps were starting to fail when it would him plugged in to that certain outlet in my home.. so maybe replace the caps on the amplifier.. it cost me about $2 to replace all of them on my sub, after they were all replaced I tested the caps I removed and 2 of the medium sized ones were bad.. no issues since replacing the caps
                        • petehall347
                          • Jan 2015
                          • 4426
                          #32
                          wondering if it still needs fixing after 2 years
                          • MobileXT
                            Yamaha DXR15 Powered Speaker Fault LED On
                            by MobileXT
                            Hello Everyone! I have a Yamaha powered speaker DXR15. The problem was the RED LED Fault indicator is steady on when I power the speaker. I did open the module and I don't see any burnt component. I Downloaded the Schematic but I don't know where to start the diagnostic. Any help would be greatly appreciated. I also attached the schematic here...
                            01-17-2025, 12:43 AM
                          • sukaht
                            Yamaha MSR400 - Powered PA Speaker
                            by sukaht
                            Hello everyone.
                            I need help with my Yamaha MSR400 - Powered PA Speaker that I bought it used recently.
                            It is power on, and sounding good / working perfectly fine. However after 3 - 5 minutes, the heatsink is starting to get warm, and it smells burning a little bit.
                            I did tried multiple times on different day, event the speaker is not playing any song (input does not connect to any source, and the volume level is zero), after it turns ON, 5 minutes later, the heatsink is starting to get warm, and it smells burning a little bit. I am afraid keeping it ON longer than 5 minutes...
                            11-02-2024, 07:55 PM
                          • GerryT
                            Electro Voice SXA series 100 or 250 powered PA speaker Schematic needed
                            by GerryT
                            Does anyone happen to have a schematic for the amplifier for an Electro Voice SXA series 100 or 250 powered PA speaker?
                            09-17-2023, 10:12 PM
                            HP ProDesk 600 G5 + Bluetooth Speaker 400 ProDesk 600 i7-9700 Specification for Upgrade or Repair
                            This specification for the HP ProDesk 600 G5 + Bluetooth Speaker 400 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Bluetooth Speaker 400 boardview and ProDesk 600 G5 + Bluetooth Speaker 400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                            09-12-2024, 02:30 PM
                            HP EliteBook 840 G6 + Bluetooth Speaker 400 Notebook 800 Specification for Upgrade or Repair
                            This specification for the HP EliteBook 840 G6 + Bluetooth Speaker 400 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + Bluetooth Speaker 400 boardview and 840 G6 + Bluetooth Speaker 400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                            09-06-2024, 06:00 PM
