Realistic MPA-95 amplifier
  • chris1379
    • Apr 2015
    • 15
    There is a broken PTC thermistor on top of the power transformer. Can someone tell me what the value or part number is? I can't find a schematic anywhere.
  • R_J
    • Jun 2012
    • 9594
    Re: Realistic MPA-95 amplifier
    You need to upload/attach a couple of in focus, pictures of what we are dealing with. Where is the ptc connected?
    • UNITRAX
      Realistic SA-2000 amplifier burning resistor.
      by UNITRAX
      Hello. Can anyone help with the burning resistor?
      Realistic SA-2000 amplifier. The problem is with the resistor R 625b
      I changed it for a new one, but it burned out immediately..
      R 625b is in the Meter Circut, in the diagram page 30 in the upper right corner.
      I checked the diodes D605, D607, D609, D611.
      Variable resistors VR601a and VR601b have almost identical resistances.
      Then I checked all the other diodes on the pcb.
      I changed to new electrolytes C615, C602, C603, C802, C801.
      After switching on for a while...
      01-26-2023, 02:19 PM
    • nmbb
      Can not find Model/Value of Thermistor.
      by nmbb
      Machine: Autoclave.
      Brand/Model: SANYO MLS-3780
      Manual: (Sorry search option not working on this PDF)
      Hello guys, this autoclave running with 2 thermistors already connected TH1 and TH3(on CN1,CN2 sockets). One for the water temperture and second one for chamber temperature. But there is another emtpy socket for optional third thermistor CN2 wich is for TH2 for object temperature. I wanna add the third thermistor TH2 to CN2 socket. But i can't figure what model/brand/value i need to use. In manual document, there is no info about TH1 and TH3 model number...
      06-02-2022, 05:55 PM
    • ohren
      Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
      by ohren
      Hello!
      I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
      Measured voltages with no load:
      After rectifier diodes
      12V: 6.17 V
      5V: 5.67 V
      Secondary transformer pins AC measurement (really don't know if this says anything)
      12V: 2-2.5 V
      5V: 1.04 V
      I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
      03-18-2023, 10:33 AM
    • mikey5791
      Is it possible for transformer substitution?
      by mikey5791
      Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
      Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
      My questions are
      1. How do i test to see if the transformer is in good working condition?
      2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
      Hope you guys understand what i was asking. My intention is...
      11-03-2022, 02:11 AM
    • dennis_elx33
      3PHASE STEP-DOWN Transformer in Check
      by dennis_elx33
      Hello All,
      i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
      Problem statement: Power tripped Off
      Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
      Action Done:
      1) Replaced the faulty parts with good spare.
      2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
      12-02-2024, 06:52 AM
