Behringer DEQ or DCX Noise
  • bgavin
    • Jan 2007
    • 1355
    These are digital EQ and digital crossover boxes. Both have a very frequent noise problem described as "frying eggs". There is a vigorous and active after-market that replaces the clock modules and almost the entire output path in these boxes. It seems kinda silly to invest $1400 into a $300 box.
    Q: has anybody serviced one of these for the above symptom?
    They have a lot of electrolytic craps on the various boards, and are reputed to have ribbon cable problems. I'm curious if a quality recap will directly affect "frying eggs" or if replacing the multitude of 25-cent opamps is actually beneficial.
    Thoughts?
    • 31114
    Re: Behringer DEQ or DCX Noise
    sounds like a job for a scope.
    • bgavin
      • Jan 2007
      • 1355
      Evidently the "frying eggs" problem was corrected some time ago by Behringer. They are now installing an insulation pad between the metal chassis panel and the affected board.
      I've seen a few photos of the DCX-2496 guts, and it looks like a candidate for a quality recap job.
      Very surprising though, the DCX uses high quality ADC, DAC, DSP, same as found in the better DBX boxes. I'm not a component tech, but it appears even the opamps are of good quality.
      Considerin the next step up is a Sabine or Xilica (sabine oem) at 4x the price, perhaps the DCX is worth the gamble.
      • Scenic
        o.O
        • Sep 2007
        • 2642
        a bit off topic, but the behringer mixers i've seen so far (the DX-1000 seems to be a pretty common one) had Jamicon. EVERYWHERE.
        edit: and not just a couple ones here and there.. hundreds of those little b*stards..
        • bgavin
          • Jan 2007
          • 1355
          I have a new DCX2496 on order. The price is about a quarter of what I would pay for a Sabine or Xilica equivalent. When the warranty runs out, I 'll recap it.
          Evidently they decided to use mainstream quality ADC, DAC, DSP and opamps. Same stuff as found in the DBX boxes at a much higher price.
          The factory 'cured' the frying bacon sound some time ago. They installed an insulation pad between the chassis panel and the board to eliminate any contact.
          • tony359
            by tony359
            11-28-2023, 05:18 AM
          • MegaZAC
            Onkyo TX-SR805 noise in one channel
            by MegaZAC
            Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
            Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
            There's some logic behind it. As soon as I select an input I get only left...
            04-23-2025, 10:09 PM
          • courtcircuit
            Philips HTS8000 home cinema noise problem
            by courtcircuit
            Hello
            I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
            Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
            Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
            I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
            Removed each of tyhe boards
            02-08-2025, 08:22 AM
          • karatzdi
            Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
            by karatzdi
            I know some might say... just buy another one. Sell it as parts..!
            So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
            Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
            Spent some time downloading the Service...
            06-11-2024, 08:38 AM
          • Biruslapio
            LG 50PB690 power supply terrible noise
            by Biruslapio
            I bought this TV with really bad oxidation on the power supply and bottom X boards, it was working but during pickup there was a lot of background noise so I don't know if it had this problem before.
            As soon as I could I opened the tv and started working on it, did not test it before since it had back bars on the screen and obvious signs of humidity. The X boards were replaced and the screen now works 100%, but the power supply...
            I washed the board and resoldered almost everything on the primary, the oxidation happened because of constant mains AC current flowing,...
            07-13-2022, 12:46 PM
