Aiwa mx-z9400m sound issue
  • Stormforce
    • Feb 2021
    • 5
    • United Kingdom
    Hi all
    I have recently acquired an Aiwa mx-z9400m system, there is a sound issue that affects the right channel only (both speakers and headphones)
    The issue is present no matter what input is selected.
    The sound is similar to say a bag being scrunched up and the occasional popping sound to.
    I have had a visual inspection of the board and there is nothing glaringly obvious all the caps look OK with no obvious leaking or swelling etc.
    Hoping someone may be able to point me in the direction of what maybe the cause of this.
    • 31013
    Re: Aiwa mx-z9400m sound issue
    sounds like you should start with the soldering of any pots on the front.
    that type of thing.
    • R_J
      • 9535
      It is likely a bad audio output ic, It might be a STK4182-MK2 . Also the headphone signal comes from the audio output ic same as the speakers
      • Stormforce
        • Feb 2021
        • 5
        • United Kingdom
        Thanks the info, is there a way to test the existing one? Or just get a new one and see if it fixes it.
        Here is a photo of the board for info, which IC would it be?
          • 31013
          given the cost, i would test them by swapping them over first!
          • Stormforce
            • Feb 2021
            • 5
            • United Kingdom
            Hi All
            Managed to hold of the service manual and replaced the STK-419-120 as this goes to the speakers and headphones, unfortunately it hasn't made any difference at all.
            Symptoms still persist on the right channel (cracking/popping and lower volume than the left channel)
            So just looking at any other possible causes?
            • CapLeaker
              Leaking Member
              • 8146
              the headphone jack and the balance pot.
              • jasonr2000
                Advance Tech
                • Nov 2013
                • 209
                hi @Stormforce you wouldn't happen to have the service manual by any chance ?
                as ive got the same unit but my symptoms are different slightly.
                Samsung UE46D6530
                Samsung BD-F7500
                Samsung HT-ES6200
                • benspawn02
                  Anthem MRX500 - no sound. R2A15218FP issue??
                  by benspawn02
                  Dear Electronics Experts:
                  I have the following problem I am trying to troubleshoot. Unfortunately, I have contacted Anthem themselves and even a local distributer but I am not having much luck. Also, I have scoured the internet and unable to obtain a service manual. The Anthem service rep has also replied that he is unable to provide me with any service documentation. I have performed numerous searches on the internet and cross-referenced a few other AV receiver makers (Denon, Marantz, Onkyo) and found certain similarities to block diagram...
                  08-12-2023, 04:46 AM
                • ChaosLegionnaire
                  by ChaosLegionnaire
                  09-13-2022, 09:02 AM
                • ex250
                  Kenwood SW-505D no sound issue and pops from time to time when it works
                  by ex250
                  Hello mates,
                  I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
                  It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
                  12-29-2024, 03:27 PM
                • saisoni20
                  MacBook Air A2337 820-02016-07 No sound ISSUE
                  by saisoni20
                  I have A2337 MacBook Air no sound issue.
                  I have replaced new Audio Board but still same issue. I went through repair wiki and checked critical voltages.
                  In terms of voltages, I have following voltages,
                  1 PP1V25_AWAKE_IO - 1.2V
                  2 PP1V25_AWAKE_IO - 1.8V
                  3 SPKRAMP_A_OUTP_R - 0V
                  ​4 SPKRAMP_A_OUTN_R - 0V
                  Am I missing any other critical voltages?
                  07-28-2024, 05:53 PM
                • Akuanka
                  Sony SLV-E780 Power Supply Issue – Clicking Sound, Need Help Identifying Faulty Component
                  by Akuanka
                  I'm troubleshooting a power supply issue with a Sony SLV-E780 VCR. The device clicks repeatedly but doesn't power up completely. I've already replaced five capacitors, but the problem persists.
                  Here's a video link https://photos.app.goo.gl/3Xki6yvCLn67gLX78​ showcasing the sound. Based on your experience, could this be due to a transformer, diode, or another component? Any guidance on what to test or replace next would be greatly appreciated.
                  Thanks in advance for your help!
                  11-23-2024, 01:12 PM
