A 9010 o n k y o amp , schematics & help please
  • zen
    • 511
    Hi all
    This amp has no audio .
    Output transistors check out good .
    No DC getting to speaker terminals .
    80 V measured across bridge rectifier D 901 , therefore assume the + & - 40 V also present .
    + & - 12 V supplies at I C 01 & I C 02 respectively , also present .
    No speaker protection relays on this model .
    Audio present when taken from line out port , then through another amp , therefore assume at least part of the
    p r e amp circuitry is working , depending on circuit layout .
  • budwich
    • Jul 2015
    • 3097
    Re: A 9010 o n k y o amp , schematics & help please
    is there sound at the headphone jack?
    hopefully the attached will help.
    • zen
      • 511
      Hi & thanks
      No audio via headphones .
      Checked pins at CONNECTOR 07 , which is a ribbon type from main to front panel .
      Not sure how to extrapolate some of the reading . Maybe someone could help .
      THERMAL - P = 2.7 V
      P - FAIL = 3.2 V
      D 12 V = SLIGHTLY HIGH AT 15 V
      DC 3.3 V = OK
      VOL - LATCH = 2.7 V ALWAYS , REGARDLESS OF VOLUME ADJUSTMENT .
      V PROTECT = 0 V
      I PROTECT = 0 V
      HP - DETECT = 0 V WITHOUT HEADPHONES CONNECTED & 3.2 V , WITH HEADPHONES IN
      S P K A - R L = STANDBY 3.3 V , ON = 0 V
      P - MUTE = 3.2 V
      F - LATCH = 3.3 V
      LINE 5 - L = APPROXIMATELY 2 VOLTS PEAK TO PEAK AUDIO SIGNAL . AMPLITUDE DOESN'T ALTER WITH VOLUME ADJUSTMENT .
      LINE 5 -R = SAME AS ABOVE .
      Note LINE 5 port is at front of unit , therefore i'm scoping audio from front unit coming back onto the main board .
      HP MUTE = MINUS 10.8 V regardless of whether headphones connected or not .
      A - MUTE = PLUS 4.2 V IN STANDBY , MINUS 10.8 V WITH UNIT ON
      VOL - DATA = 2.7 V , but nothing via scope , except a slight jump if source changed
      VOL - CLOCK = same as above .
      SIGNAL - DETECT = VARIES 1.6 V TO 2.3 V
      • zen
        • 511
        Not sure why i tried this but glad i did .
        Disconnected the volume control board , powered on and now have audio .
        Might be control itself , or one of the surface mount components on the underside .
        • petehall347
          • Jan 2015
          • 4427
          • United Kingdom
          strange as it seems maybe input selector ic fault .
          i say this as had same thing a few years back with a similar amp .
          hot swapping inputs can blow up the ic . well not visibly blown .
          • zens electronics
            • Jan 2021
            • 31
            Hi , thanks
            That's IC04 & i did check , but seems ok .
            I suspect it may be that useless grease that's used within the volume encoders.
            Had it before on other units , but never like this , with no volume at all.
            Will strip it down tomorrow & give it a clean .
            • budwich
              • Jul 2015
              • 3097
              not knowing much past my recent learning around my onkyo 919, but also from general electronics travels, I would say you have a "shut down" issue (thermal) based on the "high" outputs of the two fail lines. I would trace back those areas to see where that gets triggered to be set.
              a "quick look" of the schematics appear to indicate IC181 and IC182 are "thermal detectors" of sorts which can set the "protect high". They may be bad or otherwise.
              • zen
                • 511
                Hi & thanks again for your input .
                Unit is not going into protect mode .
                With volume board disconnected unit works fine , which should mean all amplification stages good .
                I will focus on the volume board for now , then update .Obviously the volume level is set , with PCB out of circuit .
                I try to keep an open mind with these sorts of repairs , as i have been caught out so many times .
                Regards Zen
                • budwich
                  • Jul 2015
                  • 3097
                  I see by looking further at the temp sensors that they aren't "binary" but are analog outputs which indicates they are fine and the unit is not in protection. sorry for the "misdirection". More looking and less posting... :-)
                  • zen
                    • 511
                    Yes your correct .
                    Stripped volume control , which is analogue type , to clean track , but same results .
                    Checked all surface mount components on audio board , but found no issues .
                    If i disconnect the volume in on pin 4 of connector on audio board , sound returns , obviously set to one level .
                    I'm now convinced there's a logic issue on the front board somewhere .
                    Also notice a small non volatile memory chip , & wondering if data has corrupted .
                    Also with volume module disconnected , if i try to measure or scope volume in test point on front board , the sound level reduce to zero .
                    Also reset unit to default settings with following procedure , but same results .
                    While the unit is on, press and hold the DIRECT button
                    and press the ON/STANDBY button.
                    • budwich
                      • Jul 2015
                      • 3097
                      OK.... the "volume test" sequence is a good idea / result. On the pin 4 in the board, do a resistance measurement (to ground)... maybe all you have is a shorted cap or maybe the other way around (open cap)... looking at the circuit. :-)
                      • zen
                        • 511
                        No , unfortunately not a low reading to ground issue .
                        On the VOLUME IN line only one cap , which i have checked & one 33 OHM resistor , before line goes to pin 52 of main micro .
                        Regards caps on the audio board , i have checked them all .
                        • budwich
                          • Jul 2015
                          • 3097
                          :-( not necessarily looking for a low reading to ground... looking for some impedance value to compare to as there are resistors in the path. Does the reading make sense?
                          Further, does the reading change as you change the volume control?
                          • budwich
                            • Jul 2015
                            • 3097
                            I think we are talking "two ways"... :-) I was referring to the volume board pin 4 while you were referring to the MCU board pin 4. Measuring toward the micro doesn't give you much other than a good feeling that there is some impedance and not open circuit / grounded. I would think measuring at the volume board to see if you are getting valid impedances / response from the board. Again, just my read.
                            Based on your disconnecting the pin 4 at the MCU getting sound, would appear to indicate a volume control / feed problem. Hope it helps and is not "sideways" again. :-)
                            • redwire
                              • 3910
                              The volume control seems to be an analog control voltage 0-3.3V from the motorized potentiometer, then fed to the MCU A/D converter VOLUME_IN. Then the MCU sends digital volume SPI to IC04, IC05.
                              • zens electronics
                                • Jan 2021
                                • 31
                                Hi , yes IC04 & IC05 both connected to the data bus .
                                Both chips seems to operate well , with volume board disconnected .
                                I can select any of the line inputs and audio goes through ok .
                                Do have a slight suspision that data within SPI chip might be corrupted.
                                • redwire
                                  • 3910
                                  What does the receiver (MCU) do with the IR remote control volume up/down?
                                  I guess it just commands the potentiometer motor to move up/down.
                                  With the volume board disconnected, I just see the MCU A/D input floating and picking up noise.
                                  That just leaves the potentiometer's output voltage VOLTAGE-IN pin4 stuck at zero or something. Or the IR rx module is spitting out noisy packets confusing the MCU.
                                  • zen
                                    • 511
                                    That's a good point , thanks .
                                    I don't have remote control at workshop , but can get customer to pop it in .
                                    I could even remove the IR receiver to prove a point .
                                    Regards Zen
                                    • zen
                                      • 511
                                      Can anyone help with UK spares contact details for this company ?
                                      • budwich
                                        • Jul 2015
                                        • 3097
                                        did you look in the other direction? toward the volume board? You should check to see if the board it "outputting" something in response to volume changes.
                                          RCA WHP141 wireless headphones wired up
                                          by momaka
                                          OK, this one dates back to 2015! I thought I had posted this, but realized I didn’t when I posted a picture of something else. So here it goes…
                                          Back in 2015, I bought a pair of RCA WHP141 wireless headphones at Micro Center for $2. I even mentioned it in the best cheap/free scores thread right here. Just forgot to follow up with that.
                                          As mentioned back then, these are (were) 900 MHz FM wireless headphones. No modern day Blutooth or anything like that. I knew they wouldn’t be great headphones or even that good… but the price was right! So let’s take...
                                          02-22-2023, 06:28 PM
                                        • cubytus
                                          Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                                          by cubytus
                                          Hi to all,
                                          I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                                          I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                                          Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                                          01-10-2024, 01:26 AM
                                        • otaku_nut
                                          Vizio E701i-A3 fixed but now has red vertical line
                                          by otaku_nut
                                          Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
                                          Yesterday, 06:11 PM
                                        • TrueSword88
                                          Kogan - KALED65XU9220STB - Blue Vertical Line
                                          by TrueSword88
                                          Hi all.
                                          I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                                          The line just happens to coincide with the end of COF and start of the next COF (attached).
                                          The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                                          Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                                          Hoping to fix...
                                          05-05-2023, 04:28 PM
                                        • FALKLAN
                                          Running Line Voltage and Integrating LED Pods - Automotive
                                          by FALKLAN
                                          Howdy everyone! I hope all is well where ever you are!
                                          I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
                                          I am uncertain how to convert this line into a switched 12v output line for the LED pods....
                                          02-05-2025, 12:30 AM
