1980s stereo repair time!
    • 31111
    Re: 1980s stereo repair time!
    so draw a schematic,
    that's why eaglecad is free.
    http://www.cadsoft.de
    • Vomitory
      • Aug 2010
      Hi, just a quick question on your SA-TX50. I have had mine since '97 and it is still running strong. The only problem I have is that one of the display backlights has burned out. Have you seen this issue and can the lights be replaced? I know I can turn off the lights, but it looks so nice with them on. Thank You.
        • 31111
        backlight burnout was always common.
        you need to find out 3 things.
        1: how many bulbs.
        2: how big are they - length, width
        3: what voltage is feeding them.
        • cadiman
          • Mar 2010
          • 397
          I had an sx 580 untill I sent it into pepsi syndrome. Pioneer made some good stuff back then. The tuner never was the same.
          I still have the 727 from the 70s A little contact cleaner is all she needs once in a while.
          • Perisphere
            • Feb 2016
            • 3
            Hi! Looks like a great board here, lots of wisdom and all. Am looking forward to looking through the forums to see what I can find out about things I can POOGE or restore.
            BTW--old caps going flaky/bad is hardly new....somewhere I have the RADIO NEWS magazine for January 1940, in which there is an article about how to restore dried-out Mershon electrolytic caps that Philco used in a number of their AC-powered sets in the 1930s....
            • Perisphere
              • Feb 2016
              • 3
              (OOPS, wrong forum!)
              • goontron
                5000!
                • Dec 2011
                • 4108
                • US
                #27
                You weren't about http://antiqueradios.com/ where you?
                Follow the white rabbit.
                • odonono
                  Louis Rossman style repair shop for regular laptops?
                  by odonono
                  I made a post over on reddit about how my windows laptop only works when plugged in now, because I dropped a screw driver on the connector pins where the laptop battery plugs into, causing sparks. I put a brand new battery in but still the same result, so something on the board obviously got fried (however, there's no visible burn marks, so no clue what was affected). I honestly wouldn't care, but my laptop is power throttling even with the internal battery unplugged (turns out this is a common problem on laptops with poor batteries or missing batteries). The GPU won't go above 40W when the TDP...
                  03-06-2024, 07:31 PM
                • DrDos
                  Kenwood KR-6030 vintage stereo ,Old Man Trying to Save a Buck
                  by DrDos
                  Hello all. I'll try to keep this short. I have no knowledge of electronics. I can use a multimeter and am familiar with caps to some extent. I bought a Kenwood KR-6030 vintage stereo. It need work and so I thought I would recap the thing since I get power to the on switch but nothing else is working. No lights, no sound and so forth. I went to Mouser to order caps and I find I am way over my head. I not only do not know the type of capacitors I need but Mouser and digikey do not accept Kenwood part numbers. I have the info such as 220uF 63v and such but no place to put it. I could buy a recap...
                  08-08-2025, 03:16 AM
                • Tarot Superstars
                  Add Stereo Input To Hi-Fi (Sony SONY PMC 107L)
                  by Tarot Superstars
                  Hi.
                  I bought a Cheap HIFI to use as my PC output and speakers and forgot to check if it had an input. It doesn't.
                  Is there any way to add a stereo input. I have a bunch of Phono sockets I am not using.
                  Where in the circuit is the best place to solder the 3 stereo input wires?
                  This is the model and schematics:
                  https://www.manualslib.com/manual/91...7l.html#manual
                  10-31-2023, 03:23 AM
                • ClockChip
                  How long were the displays on consumer-grade 1980s-era LED clocks designed to last?
                  by ClockChip
                  Does anyone know? A recent thread has got me wondering if the folks who designed and built consumer-grade LED clocks in the 1980s ever envisioned them still being used in the 2020s or if they were designed to give out (i.e. planned obsolescence) long before then?
                  Perhaps a better way to phrase this would be: does anyone here still use a 1980s-era clock as a daily timepiece? If so, do you expect to get many more years out of it?
                  (Along those same lines, if it does eventually develop a fault, are you likely to try to fix it?)
                  07-25-2023, 07:50 PM
                • Sik_6ty_Sixx
                  HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                  by Sik_6ty_Sixx
                  So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                  02-18-2025, 05:06 AM
