Logitech Z906 Power Supply
Re: Logitech Z906 Power Supply
Do not replace D22 if it's not shorted and shows conduction one way only (around 450mV measured on diode range). Replace R29 and R45 2Ω resistors, R24 510Ω resistor (they are quite often burnt if Q1 and Q2 are shorted), five 0.330Ω/1206 resistors in parallel, Q1+Q2 and both 2.5A fuses. You may also need to replace the SL12 NTC thermistor as it is sometimes also affected on these PSU boards (you can see a burnt hole on its surface if damaged). The value of NTC is 10Ω. In some cases U1 is affected too and the PNP transistor next to it. The actual marking for this transistor is ZXTP25020CFH so it must be an exact replacement as it is specific 4A transistor in SOT23 case.Comment
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
by Gust zhangI have a 15 - inch Retina MacBook Pro from the mid - 2014 model. Here is the link: https://www.badcaps.net/forum/showth...light=820-3662 . The battery broke some time ago. After I removed the battery and plugged in the original power adapter, the MBP could boot up normally. However, when I checked with IntelPowerGadget, I found that the CPU speed was limited to 0.8 GHz, and it ran very slowly. Later, I found a solution on GitHub. There is an open - source project called cputune that can set the CPU running speed. So I can now run the MBP at full speed. But another problem...
- Loading...
