Need help on Akai AT-S61 tuner
  • tmhobadcap
    • Apr 2019
    • 156
    • CANADA
    I got the tuner free from someone. It seems that the tuner is not for my location (north America) because the AM starts from 522 kHz in step of 9 kHz.
    I have downloaded the Operator's manual and could not find any information on how to switch it to starting from 530 kHz in steps of 10 kHz which is for north America.
    I have also downloaded the Service Manual. I found that on P.15 (as attached), under the subject of "Operation" and "Key Matrix", there is information on this. But I am not sure exactly what should be done. Could someone please help by explaining in details what should be done?
  • redwire
    • 3907
    Re: Need help on Akai AT-S61 tuner
    The four diode possibilites set what band/steps the MCU will use.
    You need D25, D26 in and D24, D27 out for North America.
    It seems to have D24 in. So move that to D25 position and add a diode like 1N4148 for D26.
    • tmhobadcap
      • Apr 2019
      • 156
      • CANADA
      Thanks for your reply but sorry, I do not understand what you mean.
      • R_J
        • 9535
        What don't you understand? you need to REMOVE D24 & D27 and ADD D25 and D26 to the circuit Look at page 22 of the service manual for their location.
        So move D24 to D25 location and move D27 to D26 location
        • tmhobadcap
          • Apr 2019
          • 156
          • CANADA
          Thank you very much for your patient and further explanations.
          Why I did not understand was because I could not find all D24, D25, D26 and D27.
          At first, I only looked at the PC boards on P.21 because my tuner model no. is AT-S61. I only could find D25 and D26 at the bottom right corner of the PCB on P.21.
          After you mentioned P.22, then I also checked the PCB on P.22 and P.23 although they are not for my model. Then now I know D24 and D27 are also located at the bottom right corner of the PCB.
          Now based on P.21, 22 and 23, I marked where D24, D25, D26 and D27 should be on my actual PCB as shown on the below photos. If I am wrong, please tell me.
          If I am right, I will have some more questions. I can add diodes to location D25 and D26. But in the actual PCB, there are 4 diodes (in red circle area) and they not shown on P.21, P.22 or P.23. Should I remove them (the 4 diodes) and install just some connections as shown on P.21, P.22 or P.23?
          Also, I think we should follow P.21 instead of P.22 or P.23 because of the model no. and PCB no. Am I correct?
          What does Fig.10 on P.15 mean?
          • R_J
            • 9535
            Those silver components are jumper wires not diodes, install 2 diodes, one at D25 and one at D26 positions and it should work. Any small signal diode should work, DS448, 1N4148 etc.
            • tmhobadcap
              • Apr 2019
              • 156
              • CANADA
              Yes, you are correct. Those are jumper wires not diodes. That was my mistake.
              I used my diodes (PXPR1002) on hand for D25 and D26. The result was nothing shown on the screen/display. Even when I removed D25 and D26, I could not get back the screen/display. Did I damage the tuner because of the PXPR1002?
              • tmhobadcap
                • Apr 2019
                • 156
                • CANADA
                I got it working now. There is no problem with using the PXPR1002 diodes.
                The main reason I got no screen/display was just because I was too lazy and did not pay attention to details. Thanks for petehall347 (from the other forum) reminding me that "maybe a wire off or loose plug". I did not take the whole PCB completely out for adding the diodes. The PCB has to be flipped while still with wires connections in a tight space. Therefore, I checked all the wires connections. The wire connections are okay. In the checking, I found that there are 3 points on the PCB are contacting to the chassis of the tuner (also via those 3 points to fix the PCB to the chassis with screws). With my limited knowledge, they should be the ground. But when I test the continuity among them, I found that one of them is not connected to the other 2. (They use the chassis to make all 3 points to be grounded). In my testing after installing the diodes, I was lazy that I just installed one of the 3 screws. Therefore, that point could not be grounded and so I got no display.
                Now I got the AM tuning correctly. Thank very much for all your effort guiding me through the whole process.
                • petehall347
                  • Jan 2015
                  • 4426
                  • United Kingdom
                  i am here also .. well done again .
                  • tmhobadcap
                    • Apr 2019
                    • 156
                    • CANADA
                    The AM is working perfectly now. But I need help again for the FM as well. I found that the FM cannot have stereo.
                    FM 103.5 is a strong radio channel in my area. When I tune to 103.5, the #4 SIGNAL STRENGTH INDICATORS with 5 leds all light up. When the #15 FM AUTO BUTTON is pressed (the #10 AUTO (FM MUTE) INDICATOR will lights up), I hear nothing. When #14 MONO BUTTON is pressed, the #10 will not light up, and I can hear the radio. And both conditions, the #5 TUNE INDICATOR and #6 STEREO INDICATOR will not light up.
                    But when I increase the frequency to 103.7 on FM AUTO, the #5 lights up, #6 flashes, #4 with only 4 leds light up, and I can hear the radio with a lot of noise. When I further increase the frequency to 103.8, I can hear nothing and #5 and #6 become off again.
                    Could someone please help me on this?
                    • DXseekerMO
                      Samsung PN51F8500AFXZA broke off the tuner's F connector, can't get tuner de-soldered
                      by DXseekerMO
                      I can hear Fred Sanford now...."YOU BIG DUMMY".....I pulled the "F" connector out of the tuner by accident. The tuner number is BN40-00248B. Low and behold I had a scrap board with tuner number BN40-00248A. Although the tuner is different (according to Encompass.com) it's footprint on the board is exactly the same as the 248B so I decided to de-solder the tuner off the scrap board to see what I was getting in to.
                      As you can see in the picture the terminals and solder pads are super small. No matter what I tried I could not get either the terminals or support...
                      09-15-2021, 05:15 PM
                      Lithonia Lighting versus Light of America Compact Fluorescent product quality
                      by sam_sam_sam
                      I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                      I also have back when Light of America had these light bulbs available for yard lights
                      The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                      While the Lithonia lighting fixture has all most certain bulb failure
                      So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                      I have only had this light fixture for not more than a year if it...
                      07-02-2023, 03:45 PM
                    • Mark R
                      Does Changing Out Caps In A Tuner Effect FM Reception
                      by Mark R
                      "TQ" Subject at hand is a Marantz 120 tuner. The tuner lit up but no output. Recapped the entire unit. Before it was working fine tuning in Stereo and Mono. Now it just about tunes Stereo and some of the mono stations are weak. Nothing else was changed. When you do hit a stereo station the stereo lamp will come on but flickers as it's trying to hold the MPX signal.
                      I don't see how bringing the unit back with new caps checked by my Sencore LC103 would effect the FM section. Every Value is as it was from the factory?
                      Any Thoughts?
                      06-11-2024, 07:04 PM
                    • Ierwin
                      55PFL4908K/12 DVB-S tuner not available
                      by Ierwin
                      I have a rather strange problem with this Philips I just repaired.
                      The set came with startup problems, I checked the PSU, found some puffed caps, replaced them and now it is starting perfectly.
                      According to the philips website this tv should be equipped with a tripple tuner.
                      However there is no option to scan for satellite channels in the menu.
                      It only shows the option to search for DVB-T or DVB-C channels.
                      The set is equiped with the F-type connector in the back so to me it looks like it is indeed equipped with a Sat tuner....
                      11-10-2023, 12:05 PM
                    • Mark R
                      Marantz Model 120 Tuner Craziness I am Stumped!
                      by Mark R
                      My Marantz 120 Tuner stopped receiving Stereo signals. It works fine other then Stereo. I have a fully loaded shop here with all test equipment except and RF signal Generator.
                      I get great reception on FM so I have used that signal troubleshoot. I have been all over the MPX board and replaced all caps. Also the entire power supply caps were replaced.
                      All Voltages on the MPX board are good... all Transistors Good...All Diodes Good and other components.
                      The stereo lamp is good as I powered it up and it lights. The signal flow to that lamp is unbelievably...
                      10-20-2023, 01:25 PM
