troubleshooting definitive technology prosub 60
  • R_J
    replied
    Re: troubleshooting definitive technology prosub 60
    R7 is a ntc thermistor, it gets hot and the resistance goes down, thats how it works. it will not be the problem. The cold temperature is 20Ω It is just for inrush protection. they can fail open but this one is working. The bridge rectifier is also likley ok, check if you have + & - 170 volts, this voltage is likely lower with the lamp in line. but both + & - voltages should be close to equal.
    I see Q1 and Q4 (or should that be Q7) and R19 are quite hot, it could be that the mosfets are turned on hard.
    What is the voltage on the speaker line? that needs to be near 0 volts
  • khajr
    replied
    Attached is the IR image of the board. Nothing blew. R7 is hot. The camera was set to auto scale temp range based on field of view. so it was 169 degrees F but it got as high as 200 degrees F when looking at it for a few more seconds before I turned the power off. Is it supposed to be that hot? I will have to order one but I am not sure what to order to replace it. The markings are SCK 202 and on the schematic it says 20 NTC SL20002 US Sensor. But I can't seem to find anything on mouser that matches that. D1 shows hot but it is directly down stream from R7. I will also buy another D1 (DF08) and I have plenty of 1 ohm 1/2 watt resistors for R19. I think Q4 and Q 1 are fine but I will get a couple more. C14 showed warm when I took this pic (lower right of image) but that was errant. It never showed warm again.
    Badcaps thanks so much for your suggestion for the dim bulb tester.
  • khajr
    replied
    I don't have a variac so I am going to use the lamp....I had all the parts in my garage to build one. I hope it stays on long enough to get a good thermal image of the board so I can pin point a problem.
  • R_J
    replied
    If you have a variac, that would work the best so you could increase the a/c voltage slowly. If you don't have one then you can use a lamp, but the wattage of the lamp is not that critical. It is NOT the lamp that is drawing the current, it is the unit under test. If there is a short in the amp, the lamp will light up full brightness, if the amp is not drawing a lot of current, the lamp will usually light for a second (as caps charge etc.) then dim.
    Just a note that if you used a very low wattage lamp (25watt) even a working amp may not operate so you might assume a problem when there was none.
  • khajr
    replied
    Originally posted by khajr
    I had to look that up. That is a great idea. I have access to a flir camera can I use this in conjunction with the flir and identify hotspots...or am I supposed to unplug the sub when I notice the light doesn't go out?
    Let me rephrase this...I understand that the bulb is drawing the current but if use a 100 watt bulb will it still be safe enough to leave on long enough to get a good thermal image w/o compromising any parts?
  • khajr
    replied
    Originally posted by R_J
    You can use a 60~100 watt incandescent lamp in series with the a/c input, this will limit the current and may help prevent the amp from blowing up during troubleshooting.
  • R_J
    replied
    Thanks BadCaps. The new Q1 and Q7 are shorted source to gate. All pins were shorted on the ones I took out. I did replace U3d and more zener diodes are on order. I will check Q3, Q4, and Q5.
  • khajr
    replied
    If Q1 & Q7 were shorted and R19 open, it is very likely the gate drive circuit is also damaged, Z1, Z4, R1, R18, Q3, Q4, Q5 etc. Z1&z4 are zener diodes and may check like a diode but zener at the wrong voltage.
    If Q1 or Q7 shorts drain to gate, it applies 170vdc to the gate components, so it may have damaged U3d as well
  • R_J
    replied
  • khajr
    started a topic troubleshooting definitive technology prosub 60
    My prosub 60 is blowing fuses. I bought replacement 1.25 amp 125v/250v slo blo fuses. When I replace the fuse it blows immediately along with a loud buzzing/hum from the sub. Attached are the schematics from definitive technology. There was one bad resistor, R19, and I have replaced this with the correct 1/2watt 1ohm resistor. When I plugged the unit it that resistor pops and the fuse blows. I have also replaced the following: caps C2 and C4, the bridge rectifier D1, op amp U1D, and the power mosfets Q1 and Q7. I have also checked R18, R20, and R21 and they checkout fine (removed from board to check). I have also checked power thermistor R7 and it came back 17 ohms. I removed Z1 and Z4 and checked them and they read a 0.7 drop. I have also verified the subwoofer is viable per def tech by checking the resistance across + and - and it reads 59 ohms. It is supposed to be +/- 15% from 64 ohms. I have also gently applied even pressure on the sub and it moves without any noises. I am at a loss now. Anyone have any thoughts?
    I should mention that this happens w/o the amp being connected to the receiver.
    Thanks in advance.
  • gica69
    Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
    by gica69
    I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
    Resistor shows orange range silver gold and green lines.
    Thanks in adv...
    07-21-2025, 09:49 PM
  • Baste
    What are the pro's and cons of replacing a 1/4 with a 1/2 resistor same ohms?
    by Baste
    As the title says. I bought a cheap Asus ROG Strix 750-watt PSU, which was posted as defective. Cables are complete, and the entire PSU is in good condition, of course, aside from being faulty. Long story short, upon checking, there is no +5VSB. Looking at the components, I found a blown resistor. I swear, looking at the bands, the color is pink, pink, gold, gold. I dunno if I'm color blind or this is the way resistors are coded.
    Please help, did I decode it correctly at 2.2 ohms (red, red, gold, gold), or what could a pink, pink, gold gold value be? I bought a...
    10-30-2025, 11:51 PM
  • jinu_j
    by jinu_j
    Hi
    05-03-2025, 10:51 PM
  • mikey5791
    Need help to replace burned resistor in 350w atx psu
    by mikey5791
    Hi to all forum members,
    Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
    The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
    Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
    Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
    12-26-2024, 04:55 AM
  • Califauna
    Help with boom box modification
    by Califauna
    Hi, this is more of a project help request than a troubleshooting question. I hope I can post it here.
    I have a W-King D8 Bluetooth boom box which I'd like to modify with some external speaker output jacks and some buttons to switch the internal speakers on and off.
    From factory the specs of the boom box are:
    -Power Input: DC 5V
    -Speaker Output Power: 2 x 25W ( confirmed by Youtube channel Hartdegen review as 12.5W RMS per channel)
    -Drivers:
    -2 x Woofer, 70mm, 10Ω, 70mm,15W
    -2 X Tweeter, 8Ω, 30mm,10W x 2
    -Frequency...
    12-04-2021, 01:53 PM
