Sansui G-7700 receiver blows fuse
  • woaimi
    • Sep 2005
    • 94
    • US
    A colleague gave me this Sansui receiver. He mentioned it was still playing until recently (couple weeks ago) lost its power and he thinks it blew the fuse. I brought is home opened up and sure enough the 10A fuse is blown. I found a spare one at home put it in and instantly blew that one too. I'm hoping some experienced users here would direct me in the right direction to bring this nice piece of art back to life. Having read through some posts in the other forum regarding this receiver, I realized this is not an easy task but possessing a nice Sansui G-7700 and learning new skill that what got my commitment.
    there are no burnt marks or burnt components spotted on the board. One suggestion is to check the output transistors, I haven't got to it yet but will do as soon as I got a chance to play with it.
    I'm very much appreciate all of your help and suggestions.
  • petehall347
    • Jan 2015
    • 4450
    • United Kingdom
    Re: Sansui G-7700 receiver blows fuse
    yes check outputs and if shorted check drivers . if they are bad keep checking all other main amp transistors .
    if no outputs or drivers shorted check the power supply for short circuits starting with the main rectifier .
    this amp isnt the best by a long way to learn on . things can jump out and bite you .
    i think there are also fuse resistors that need checking / replacing . find what is blowing the fuse first and dont plug directly into the mains until its fixed ... use a dbt for testing it and initial bias current setting up .
    there are threads over on audiokarma you can read .
    • woaimi
      • Sep 2005
      • 94
      • US
      thanks. I'm following both forums; the more the merrier.
      • woaimi
        • Sep 2005
        • 94
        • US
        finally got sometime for my hobby. I tested all the output transistors. It used a pair of 2SA1170 & 2SC2774. The left channel transistors only had reading on 1 direction. The right channel got readings both directions
        2SC2774
        (+) on B: B-C=127mV, B-E=127mV
        (-) on B: B-C=145mV, B-E=145mV
        C-E shorted
        2SA1170
        (-) on B: B-C=194mV, B-E=194mV
        (+) on B: B-C=196mV, B-E=196mV
        C-E shorted
        i'll go through the others as peterhall347 mentioned. will see . thanks
        • redwire
          • 3912
          If output transistors have shorted, the driver and pre-driver stages can also get damaged. The transistors might test good- but actually be weakened. It is always good to replace those as well, Sony has it in their service policies to always replace one stage ahead of the shorted parts.
          Sometimes you can tell a transistor is damaged if the VBE and VCB readings are way different, they usually are close together, or if the readings are hi or low, such as 400mV or 850mV.
          • CapLeaker
            Leaking Member
            • 8352
            I second what redwire said. I fixed one of these a few years back. After the initial output driver fix and playing music, about 1 minute and 30 seconds the pre driver failed.
            • woaimi
              • Sep 2005
              • 94
              • US
              thanks for the suggestion. In fact, TR17 of the same channel shorted as well. I'm going to remove all of them from the board and test again. There's 1 resistor R17 seems to be cracked but I can still read its value with an ohm meter; it probably safe to replace some or all of them in the same area.
              • BlackScreen_22
                Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
                by BlackScreen_22
                Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
                Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
                I had no problems connecting mosfets and capacitors,...
                08-27-2024, 12:46 PM
              • corrize
                A funny fuse story – Lumix LX100 II
                by corrize
                Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                10-19-2023, 09:58 AM
              • dimis7
                LG 37LS5600 blows main fuse
                by dimis7
                Need some advice to troubleshoot this TV.
                PSU blow the main fuse F100, 3.15A.
                I replace the fuse with another 3A (but not ceramic) and blows it again after few seconds when i plugged in to the wall, with nothing connected to PSU, just the power cord.
                I checked with DMM for dead sorts but didn't found any.
                Checked bridge rectifier and seems ok.
                Also check main filter cap with transistor / cap / esr tester (the usual cheap transistor testers from ebay) and found ok.
                PSU p/n is EAX64405901 (1.6)...
                10-28-2022, 05:15 AM
              • Michale32086
                LG 60LN5400 Blows TCON Fuse
                by Michale32086
                I could have sworn I posted about this before, but I can't seem to find the post..
                To whit..
                I have a 60LN5400 that came in.. Backlights work fine.. No display..
                Traced the problem to the TCON board.. Blown fuse..
                Replaced the fuse.. Blows again.. Replaced the fuse again... This time it fries the marked part on the Main Video board...
                Got a new Main Video Board.. Replaced the fuse on the TCON..
                The fuse is fine and the backlights come on fine if I don't have the cellophane connectors from the TCON to the...
                10-30-2019, 09:21 AM
              • Rictech
                Panasonic SA-MAX770PU SMPSU board fault....
                by Rictech
                Hello everyone. 😀
                As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                There are no devices that have exploded or otherwise show signs...
                08-26-2024, 01:05 AM
