Sennheiser Ew100/G2 Wireless Mic Receiver
  • falcontech
    • Oct 2013
    • 470
    • italy
    #41
    Re: Sennheiser Ew100/G2 Wireless Mic Receiver
    without fuse on the board I have a variation only on TP209 = 0 and on TP229 = 43.7
    • falcontech
      • Oct 2013
      • 470
      • italy
      #42
      the original fuse has not yet arrived, and I don't have a classic fuse with that amperage to be able to test, if I try with a 2.0 ampere one, can I do some damage?
        Originally posted by falcontech
        Tp209=28,1 kohm
        tp208=00,5 ohm This is circuit GND, BM.
        tp226=17,47 kohm
        tp229=44,6 kohm
        tp233=7,19 kohm
        tp231=12,96 kohm
        TP208 is GND.
        Those test points look OK, no really low Ohms readings.
        • falcontech
          • Oct 2013
          • 470
          • italy
          #44
          Re: Ricevitore microfono wireless Sennheiser Ew100/G2
          Originally posted by budm
          TP208 is GND.
          So what do I do? Am I waiting for the original replacement of the fuse or can I try in the meantime with the classic 2 amp fuse?
            You do not have 1A fuse?
            • falcontech
              • Oct 2013
              • 470
              • italy
              #46
              i don't know should i look, in case it would be better by 1 amp?
                The bad fuse is rated at 3/4A so using 1A fuse is close enough, 2A will be too high in case we may have active shorts when does not show up when we did the static test on those power supply test points.
                So get 1A fuse to try.
                • falcontech
                  • Oct 2013
                  • 470
                  • italy
                  #48
                  paradoxically I don't have a 1 amp fuse I have to wait for Monday to buy it
                  • falcontech
                    • Oct 2013
                    • 470
                    • italy
                    #49
                    I put the fuse he indicated to me and everything seems ok, the receiver has been on for about an hour and shows no signs of problems, I tried with a non-original power supply, because its original supplies 19 volts instead of 13,5 as the label states and it worries me a little, do you advise me to buy a new original power supply?
                      Is'n this the power supply you are using?
                      https://www.badcaps.net/forum/attach...8&d=1595935465
                      It is just a simple AC -DC power supply, non-regulated. It will put out 13VDC at 0.250A, at lower current draw the Voltage will be higher. You see 19V when there is no load connected, the output will also vary with the AC line Voltage.
                      If you want to be safe you can use AC-DC linear power supply that will regulate the output Voltage, you do not want to use Regulated switching power supply since it is noisy.
                      So when is the Voltage at the DC jack on the fuse when the unit is off (minimum load), is it still within the safe operating range of the unit?
                      • falcontech
                        • Oct 2013
                        • 470
                        • italy
                        #51
                        As I told you I used another power supply for safety which is Ac / Dc 13.5 stabilized 800mA, and not the original one that is in the picture, I understood that the original power supply when it has no load delivers 19V, for the rest if could you explain me better why I did not understand, it is a bit difficult to understand when I use the translator thanks
                          Right now it is best for you to buy the original power supply that was made for this unit.
                          BTW, I did not see the picture of the 13V 800mA power supply you are using, I only see the Sennheiser one you show here. https://www.badcaps.net/forum/newrep...reply&p=977380
                            BTW, did you do this test in my post #50?
                            "So what is the Voltage at the DC jack on the fuse when the unit is off (minimum load), is it still within the safe operating range of the unit?"
                            What is the Voltage at the fuse (with ref. to Ground of course) when the unit is turned on?
                            According to the spec sheet of the unit, the operating Voltage range is from 10.5V to 16V.
                            So the bottom line is that when the unit is OFF (power supply will see little load) the Voltage at the fuse should not be higher than 16VDC, when the unit is turned on (power supply will see heavier load), the Voltage should not be below 10.50V.
                            https://www.repairfaq.org/sam/aapsfaq.htm
                            • falcontech
                              • Oct 2013
                              • 470
                              • italy
                              #54
                              Power supply connected to the jack without load = 17V
                              With load = 14.50V
                                So you are on the border line, 17V instead of 16V maximum per unit safe operating Voltage. That Voltage can go even higher that 17V if your AC line Voltage goes even higher.
                                I would get the correct power supply for the unit.
                                Is the original one expensive?
                                • falcontech
                                  • Oct 2013
                                  • 470
                                  • italy
                                  #56
                                  The original costs 28 euros with shipping
                                  • falcontech
                                    • Oct 2013
                                    • 470
                                    • italy
                                    #57
                                    Thank you all for your assistance and patience, the wireless microphone has been tried out in public and works perfectly, thank you very much
                                      Thanks for the follow-up.
                                      28 Euro for a simple power supply? Expensive!
                                      • wolf1976
                                        wireless receiver for 6 speeds fan control with remote control
                                        by wolf1976
                                        hi i have a receiver that is destroyed from the overvoltage i guess
                                        my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
                                        the motor fan has not label
                                        i have an other receiver operational
                                        In your opinion can i measure the voltage at the output ?
                                        what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
                                        thanks in advance...
                                        07-23-2025, 03:12 PM
                                      • theone111
                                        by theone111
                                        3. Problem: TV shuts down
                                        07-22-2024, 10:36 AM
                                      • litsnsirn
                                        Alienware Aurora R12 with AX1650 wireless adapter problem
                                        by litsnsirn
                                        I have an Alienware Aurora R12 desktop and I recently just started reloading the hard drive after replacing one that failed. After reloading the wireless will not work. It comes up in the Device Manager as Intel AX201 and has the warning symbol and if you click into it, it says ‘Code 10 Cannot start’. I’ve tried uninstalling everything that seems related in the software center and the driver, and have tried reloading with two of the different files that I sourced from Dell and a driver package directly from Intel and after reinstalling, it winds up in the same condition that it started....
                                        11-19-2024, 11:14 AM
                                      • pulper111
                                        Pioneer VSX-1123 Receiver - weird voltage problem
                                        by pulper111
                                        Hello. My receiver "seems" to be working fine. It functions as it should. the receiver is the Pioneer vsx-1123. However, while doing some work in the house, I noticed that my HDMI cable from the receiver was registering as "hot" using my fluke non-contact voltage tester.
                                        I've done some troubleshooting to try to narrow down the problem, and all wires (speaker/hdmi/subwoofer) coming from the receiver, whether it's powered on or stand-by, register as "hot". none of my other receivers are experiencing this issue, so it doesn't seem to be an issue with...
                                        09-02-2020, 11:12 AM
                                        HP EliteBook 840 G6 + Backpack & Wireless Premium Mouse Notebook 800 Specification for Upgrade or Repair
                                        This specification for the HP EliteBook 840 G6 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + Backpack & Wireless Premium Mouse boardview and 840 G6 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                        09-06-2024, 03:30 PM
