hello everyone I have a problem with the receiver of this microphone which is a sennheiser ew100 / G2, attached the photo of the main board and the service manual of the receiver, and I'll put the youtube link for the video of the problem I don't know if it is a power problem, for the moment I realized that the power supply should bring out 13VDC but almost 19 come out, it is not a display problem, because when it starts doing this problem (after a few seconds) the transmitter stops working. I await your advice thank you
Sennheiser Ew100/G2 Wireless Mic Receiver
Tags: None
Re: Sennheiser Ew100/G2 Wireless Mic Receiver
So your AC adapter is putting out 19VDC instead of 13V?hello everyone I have a problem with the receiver of this microphone which is a sennheiser ew100 / G2, attached the photo of the main board and the service manual of the receiver, and I'll put the youtube link for the video of the problem I don't know if it is a power problem, for the moment I realized that the power supply should bring out 13VDC but almost 19 come out, it is not a display problem, because when it starts doing this problem (after a few seconds) the transmitter stops working. I await your advice thank you
The service manual page 5 shows DC input jack rating of 10.5 ~ 16V 200mA, nominal is 12V.
Show us the pictures of the AC adapter you are using.Last edited by budm; 07-27-2020, 10:52 PM.Never stop learning
in a while I attach the photo, however it is the original of the sennheiser NT2, I tried with another power supply but the problem remains, surely some component is gone and I thought about the voltage regulator 78m08Comment
Re: Ricevitore microfono wireless Sennheiser Ew100/G2
it can be opened but at the moment the power supply is not the problem, because it will be replaced, but the receiver that gives that problem, look at the video that I put on youtubeComment
It is not regulated power supply so the output will be higher than 13V without load, it will be 13V with 250mA load.
What Voltage do you get at the dc jack when the unit is turned on?
There are many power supplies on that receiver unit, look at page 14, 15, 19, 20 of the service manual, it shows you the Voltage test points that you need to check. Did you check them?Never stop learning
I disassembled the 78m08 voltage regulator, and I am waiting for the new one to be replaced to replace it, I keep you updatedComment
I'm waiting for you to come to assemble it and then I'll tell you, with what I took apart I only remember the output voltage which was about 6 voltsComment
You should be able to test the input and output Voltage easily, you should also check the resistance of the output to see if it shows very low Ohms or not, nothing special or hard about doing simple test.Never stop learning
I tested the voltages, I realized that at the input of this resettable fuse I have 16 volts at the input and then at the output I have 8.5 volts do you think this could be the problem?Attached Filesif you find these attachements useful please consider making a small donation to the site
What is the P/N printed on it, I see XD75????, 24V
Unplug the DC jack and let the fuse cool down then check the resistance of the fuse.
Also check the resistance of that black cylinder device connected to that fuse also.Last edited by budm; 08-05-2020, 03:54 PM.Never stop learning
on the fuse the acronym is x075f 24v, that cylindrical part I did not understand what component it is if you can give me a hand through service manual I would be gratefulComment
[QUOTE=falcontech;979358]on the fuse the acronym is x075f 24v, that cylindrical part I did not understand what component it is if you can give me a hand through service manual I would be grateful[/QUOTE]
1) That black component is a protection diode D210 (SM4007) in case the unit is connected to the wrong polarity of the AC/DC adapter. So check the RESISTANCE as I requested.
2) Fuse F210 (X075F 24V) is rated at 0.75A per schematic. Did you check the resistance (no power applied to the unit for at least 10 minutes) as I requested?
3) You must follow my instructions when I request you to do the measurement otherwise we are just wasting times here.Attached Filesif you find these attachements useful please consider making a small donation to the site
by wolf1976hi i have a receiver that is destroyed from the overvoltage i guess
my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
the motor fan has not label
i have an other receiver operational
In your opinion can i measure the voltage at the output ?
what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
thanks in advance... -
by theone111I have an LG Plasma TV 60PM6700 for the past ~12 years.
In the last ~3-4 months I have been having some issues.- Problem: It started with random picture disappearing (sound still worked).
Solution: Had to turn off TV wait a few seconds before turning it on again. - Problem: Then it got worse and the TV started to shut down and when turning on the no picture just sound.
Solution: Had to turn off TV wait about 10-20 seconds and turn it on again to solve. - Problem: TV shuts down
1 Photo - Problem: It started with random picture disappearing (sound still worked).
by litsnsirnI have an Alienware Aurora R12 desktop and I recently just started reloading the hard drive after replacing one that failed. After reloading the wireless will not work. It comes up in the Device Manager as Intel AX201 and has the warning symbol and if you click into it, it says ‘Code 10 Cannot start’. I’ve tried uninstalling everything that seems related in the software center and the driver, and have tried reloading with two of the different files that I sourced from Dell and a driver package directly from Intel and after reinstalling, it winds up in the same condition that it started....11-19-2024, 11:14 AM
This specification for the HP ProBook 430 G6 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Backpack & Wireless Premium Mouse boardview and 430 G6 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-06-2024, 03:30 PM
This specification for the HP ProBook 650 G5 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 650 G5 + Backpack & Wireless Premium Mouse boardview and 650 G5 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-06-2024, 03:30 PM
- Loading...
