Philips HTS 9800 problem
  • houls69
    Hi, i have a Philips HTS 9800 entertainment system for the past 3 years and it was working fine up until last week. I had it playing full blast for nearly a whole weekend and since then it only works fine on low volumes but if i try to bring the volume past half way it gets distorted and wont go any louder. The speakers are all fine, i have tested them on another system so I think its the amp. I opened it up earlier today to see if I could see any bulging/damaged capacitors inside but they all look to be ok. Has anyone ever come across this type of problem before? What should I be looking out for? There are two capacitors on the board that have a very slight bulge, by that I mean almost un-noticable. Before I go buying the capacitors and changing them out I just thought I'd check on the net to see if anyone has any suggestions. Any help would be much appreciated!
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Philips HTS 9800 problem
    When it comes to caps and bulges slight is too much.
    That doesn't mean it's the only problem though.
    Mann-Made Global Warming.
    - Dr Seuss
    • hardwareguy
      • Jun 2006
      • 405
      How large are these caps?
      The size will give me an idea of what they do.
      Is this just a receiver (amp and tuner) or does it also have a DVD player inside?
      Good pics of the insides will help me determine what you need and if it might be other things. In the pic, note the location of the bad caps.
      • janos6662000
        Philips 47PFS7509/12 LCD TV problem
        by janos6662000
        Hi
        I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
        When i applied cable signal to check image, i had normal picture, but TV was restarting.
        I downloaded original firmware and applied the update, but the problem remained.
        From a colleague i received a "factory package software" which is a lot bigger.
        I made another firmware update, but still did not solve the problem.
        Somewhere on the way the error got worse, because at the moment the...
        08-12-2025, 12:54 PM
      • courtcircuit
        Philips HTS8000 home cinema noise problem
        by courtcircuit
        Hello
        I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
        Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
        Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
        I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
        Removed each of tyhe boards
        02-08-2025, 08:22 AM
      • theone111
        by theone111
        3. Problem: TV shuts down
        07-22-2024, 10:36 AM
      • bohaboha
        PHILIPS 32pfl3403d Flat-panel TV Upgrade Assistant problem
        by bohaboha
        Hi trying to update my Philips cause in retail mode not possible to get out from it i get this message in update site : Error message: no data exception. Your reference: Request ID (server_1930105)
        how to fix it thanks
        02-05-2025, 09:23 PM
      • atkallu
        Philips 58PUS8545 t-con problem or something else ?
        by atkallu
        Hello
        I have a Philips 58PUS8545 which have a vertical moving lines on screen and it is flashing white vertical lines like a every 3-4 seconds.
        See the attached image.
        I removed left side flex-cable from the t-con and then there was half screen sharp and correct image and other half was white.
        But when I removed the right side flex-cable then half of the screen was white but other half was white and above the white there was vertical lines on half of the screen.
        T-con two flex-cables have been changed to cross but nothing changed, so it is not due those...
        01-13-2025, 11:23 AM
