Crest CKS400 Amp - Buzzing Relay
  • Baldrick
    • Apr 2014
    • 19
    Hi all. I've got a Crest CKS400 amp that's got a buzzing power relay.
    Originally, the relay would buzz until the unit was turned off. Now, it buzzes for a second and stops. The relay also shows a blue spark when first powered.
    My question is, is it likely this is just a bad relay (Potter & Brumfield K10P-11A15-120) or do you thing it's something else making the relay lose it's mind?
    Thanks!
  • R_J
    • 9623
    Re: Crest CKS400 Amp - Buzzing Relay
    I assume you are talking about the ac input relav. The relay is driven from the ac line so It should not be coil voltage problem, so it is likey a bad relay
    • Baldrick
      • Apr 2014
      • 19
      Thanks for taking the time!
      I've got a new relay ordered and I'll post the results.
        Is that relay coil driven by the OPTO MOC3041? May be the OPTO is getting weak,
        • R_J
          • 9623
          I believe the opto is for remote turn on/off (STO)
          I like the names on the connections on the power switch: YES, NO, MAYBE? I believe it is Remote
            Some EE guy with humor.
            • clearchris
              • Dec 2013
              • 687
              Relays have a limited lifespan, it's a wear part, and if it's buzzing and arcing, the contacts are already hosed. Can't go wrong replacing it. It's true as budm said, to directly answer your question, it could be something else. But it's not likely.
              When fixing things, I play the odds first, then if that doesn't work, time to dig deeper. I wouldn't sweat it. But then again, I'm just an electronics hack.
              • CoinCoin88
                Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                by CoinCoin88
                I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                09-15-2025, 03:36 AM
              • jm1234
                9V relay temperature 40C
                by jm1234
                Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                05-09-2024, 03:03 AM
              • edugimeno
                Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
                by edugimeno
                Hi everyone!
                I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
                I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
                This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
                To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
                I respected the polarity, positive to cathode of protecting diode
                So provided all...
                04-18-2024, 01:15 PM
                Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                by sam_sam_sam
                I was working on this CNC machine today found no keyboard functioning no control relay powering on
                The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                Found shorted diodes on main controller relays there are 3 of them that...
                01-07-2023, 05:43 PM
              • fadi90
                PILZ PNOZ X4 Safety Relay
                by fadi90
                I'm working on repairing a Pilz PNOZ X4 safety relay module. When I opened it up, I found some of the connector pins detached from their pads. I replaced the connector with individual wires, but the issue remains.
                The module is set to dual-channel mode with manual start. In this mode:
                • Y36-Y37 and Y1-Y2 are bridged.
                • 24VDC is applied across A1-A2.
                • It monitors two emergency circuits (S11→S12 and S11→S52).
                • When both are closed (24V present on S12 and S52) and the start button is pressed (S33 connected to S34), the NO contacts (13-14, 23-24, 33-34)
                06-07-2025, 01:21 AM
