Onkyo TX-NR636 Protection Mode - thermal issue?
  • curiousgeorge1
    • Mar 2020
    • 3
    Hi folks,
    I have a Onkyo TX-NR636 that goes into Protect mode (the display lights up upon pressing on/standby, but 'clicks' off within 2-3 seconds).
    Using the Service Information Mode (in the service manual attached, page 11), the service information display shows: T -42C 17 04
    This indicates the power off cause is 'Thermal Protect' and the temperature reading is negative 42 degrees celcius.
    Using the instructions for 'Confirmation of output voltage and thermal sensor' on p 12 of the service manual, the display shows: >00 -47 F:x S:H
    Does anyone know what might cause the temperature reading to be so low?
    Any tips, suggestions or even resources that I could use to fix this would be much appreciated. I am a beginner and keen to learn more.
    Thanks for your time.
  • tibimakai
    • Jan 2012
    • 3680
    Re: Onkyo TX-NR636 Protection Mode - thermal issue?
    I have repaired quite a few of these, and I have never even check that service information.
    Every time I had blown components, at the amp.
    I open them, and go right away at the final transistors on the heatsink, to check for short.
    • R_J
      • 9515
      That seems like an odd temperature (-47) it could be a data error, Have you tried a master reset on the amp?
      • redwire
        • 3900
        Q6300 (LM61) is the analog temperature sensor on the little board, I would check the cables, mounting, it's output voltage to the MCU. At 25°C it would give 0.850VDC. If the MCU got 0V that might be -42°C.
        I found Onkyo's don't work properly with the back panel removed, many of the boards rely on it to provide proper grounding. I had one always going into PROTECT mode even after I'd fixed everything until I noticed one board was not grounded, when taking voltage measurements. The RCA/HDMI connectors ground the boards to the case.
        So using jumpers between the RCA's/HDMI on the board stack and main amp ground allowed me to keep going.
        • curiousgeorge1
          • Mar 2020
          • 3
          Thanks for your comments above and for your contributions to other Onkyo threads in this forum - it gave me some good context diving into this.
          To give you an update, I have some progress (I'm saying that tentatively, not having used speakers for an extended period yet).
          I checked the transistors on the heat sink and the adjacent resistors on the main board, as recommended in here and other threads. I couldn't find any fault with these.
          However, I removed the thermal sensor (Q6300) that attaches at a right angle to the heatsink. I think the issue was a solder that correlates to the 'Thermal' line represented in the diagram attached.
          The solder had two 'tips', one of which was very fine and was in contact with the (plastic?) casing that attaches the 3 leads to the small board. It appeared they had melted together ever so slightly. There was no discoloration on the board that I could see. I filed the solder down so that they were no longer in contact and reassembled. Apologies for my poor terminology, but that's my best description without having a picture.
          The receiver turned on, no safety mode was activated and the temperature reading in the service information mode is now 27°C.
          Any ideas why this might have happened or how I might avoid this in the future?
          Thanks again for your responses.
          • redwire
            • 3900
            It sounds like a manufacturing defect. Those little boards are are usually hand assembled and the soldering can be poor quality or things melted a bit if they did use wave soldering.
            Melting things (after soldering) would need heat over say 120°C which is above what the transistors can take, so not likely to happen in real use. The Onkyo's can't do club/dance duty for more than a song or two.
            • gurj1979
              MSI GP62MVR-7RF - weird fan / thermal issue
              by gurj1979
              Hey guys, I need help with my personal MSI GP62MVR-7RF. Annoying fan / thermal issue.
              Machine Idle. Fan will spin medium speed for 4 seconds, then off for 1 second. Repeat forever.
              CPU and GPU are cold. No load, just sitting doing nothing.
              It's clean inside, nothing blocked. New MX4 paste.
              Updated BIOS, EC, and VBIOS but nothing's helped.
              Schematic shows 2 thermal resistors, but they're OK.
              All thermal signals are good, inc PCH.
              Has anyone ever come across this ? Any idea what to do ?
              Could it be a faulty CPU / PCH / KBC ? I REALLY don't want...
              09-16-2024, 02:14 PM
            • Bartoloni
              Bypass Sony SVE151E11M thermal protection? (schematics provided)
              by Bartoloni
              Hi, lastweek i received a Sony SVE151E11M, that after a liquid damage was not starting, after removing oxide and reworking IC and SMD component thet laptop was able to start and was working for 2 DAYS...
              after the 2nd day, the screen become black (no backlight), there is HDD activity (OS is loading) but no screen on internal panel, VGA and HDMI.
              After 25/38 seconds the computer shut down by itself. (i know that is probably not the cause of the blackscreen but a thermal protection of some kind.. but i'm interested on how the shutdown is performed)
              BTW... 2 ICs related to thermal...
              08-12-2022, 05:21 AM
            • Gcnewbie
              Dell Latitude 5570 Ambient thermal sensor reading -127 Degrees C
              by Gcnewbie
              Forgive me this is my first request for help on this forum, so if i've screwed up or not followed the rules i should have i apologise profusely.
              I have a Dell Latitude 5570 that was randomly shutting down, on further investigation i found that the machine had been shutting down due to thermal events as noted by windows event viewer.
              My investigations lead me to the dell diagnostics screen, where i found that there were two sensors out of range which had been causing the shutdowns, one of which was the GPU thermal sensor and the other the ambient sensor.
              I opened the...
              03-29-2024, 06:55 AM
            • Veyron7887
              Laptop overheating after replacement thermal paste
              by Veyron7887
              Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
              11-24-2024, 05:08 AM
            • SolomonMan
              Electric Button Breaker Thermal Overload Protection
              by SolomonMan
              All,
              I have two 120V compressors that I have been working on. Both are getting new Capacitors.
              As I am replacing the capacitors I am looking over the other electrical components.
              One compressor is a Harbor Freight 21 Gallon Vertical . The other is Horizontal Craftsman which is roughly the same size. The one Harbor Freight Capacitor was fried and the other looks like it may have opened. The Craftsman Starting Capacitor was/or has been leaking badly.
              The Harbor Freight Thermal Overload protector was lost over the past 10 years after the unit was originally...
              10-17-2022, 07:52 AM
