Denon PMA-1560 other channel dead
  • OniJon
    Computer Expert
    • 82
    • Finland
    One burnt main transistor, with a blown leg, TR525 blown leg, resistor R551 blown.
    I'm a second owner of this amp, somebody "tried" to repair it already. I've removed few carbonfilm resistors because they showed nothing on DMM. Also metallized paper caps went out the window. Total recap is in order of course and I'll change the carbon resistors for something better.
    Question is, when I get to it, what are the pre-transistors that affect the sound the most? I've read that these need to be gain matched if it comes to that, how to do that the easy way?
    Power transistors gotta go also because original SanKen's are hard to get and crappy anyway. Good subtitutes (what I've read and heard): 2SA1492 -> 2SC5242 or 2SC1962 and 2SC3856 -> 2SC2723
    That's a problem for another time, but any tips and tricks how to proceed after changing all the crap from the board and repairing some damage, are welcome.
  • OniJon
    Computer Expert
    • 82
    • Finland
    Re: Denon PMA-1560 other channel dead
    I've measured most of the carbon resistor in megaohms, so they're definitely goners. Somehow the bias resistor 3DR18R18, ceramic type, is also changed to inductive type frankenstein. Should I just try to get 2 normal non-inductive ceramic type resistors that are over 2W?
    I've tried to find something from Farnell (element14) but can't find anything suitable. How about something like this? How accurate this resistors value needs to be?
    http://www.ebay.com/itm/153123183757
    http://www.ebay.com/itm/184191408413
    This is spot on, but I don't need 25pcs
    http://www.ebay.com/itm/153434145384
    Also, what possible replacements are there for J79 (TR521) and K216 (TR519)? I've found several but all with wrong leg order. These little weirdos made by Hitachi, have source as center leg, where as all that I've found have gate in the middle. Of course I could just snap the legs short and cross these two with a pieces of wire.
    • CapLeaker
      Leaking Member
      • 8263
      sometimes you cant get around the leg order. if i cant get the right leg order, i try to get one that has a backward leg order. then i just have to solder the transistor in backwards, not having to deal with crossed legs.
      • OniJon
        Computer Expert
        • 82
        • Finland
        I've been soldering in new metalfilm resistors to replace carbon ones, wima's for plastic caps and few(most) bad electrolytics have been replaced with Panasonic/Nichicon/NCC. Now I'm wondering about the transistors. I need to replace TR525 which is 2SD2004 but it needs complimentary pair or I need to buy original which is kinda expensive. Any thoughts?
        As for the power transistors I've chosen to replace Sanken 2SA1492 + Sanken 2SC3856 with Toshiba 2SA1986+ 2SC5358. Any thoughts on this?
        • falcontech
          Denon Mc6000 channel 1 completely non-functional
          by falcontech
          Hello
          I need your help with a non-functioning channel on this Denon controller. I noticed the problem because, with the mixing software, the channel appears completely off and none of its controls work. At the top of the channel, like the others, there's a selector switch that moves between MIDI and external audio inputs. I also tried connecting an audio source (since it's also a standalone mixer) and I got no input. The flat cable connecting this panel to the sound card is fine. I'm attaching a photo and the service manual. I hope someone can help me resolve the issue. Thanks....
          09-04-2025, 09:03 AM
        • karatzdi
          Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
          by karatzdi
          I know some might say... just buy another one. Sell it as parts..!
          So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
          Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
          Spent some time downloading the Service...
          06-11-2024, 08:38 AM
        • eccerr0r
          old X58 triple channel board... memtest86 memory speed?
          by eccerr0r
          Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
          Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
          Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
          06-28-2025, 09:06 AM
        • TinkerTron
          Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
          by TinkerTron
          Hey everyone,
          I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
          Instead, here's what's been bugging me so far:
          The schematic...
          03-06-2025, 02:03 PM
        • mikey5791
          Help on car amplifier only one channel works
          by mikey5791
          Hi all forum members,
          Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
          My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
          08-06-2025, 10:36 PM
