Yamaha RX-V571 No Power, no screen
  • bermo96
    • Jan 2019
    • 45
    • Belgique
    Re: Yamaha RX-V571 No Power, no screen
    Ok so now with my meter, PS1 is between 1.1v and 2v and PS2 is changing between 0.3 and 2.8v. It's kind like if the voltages is changing with the relays clicking or not.
    And Q3703 is a stable 3.3v.
    • R_J
      • Jun 2012
      • 9594
      So the reset looks ok and not constantly reseting. Are you sure it is just the speaker relays that are turning on and off? there are a lot of relays in this unit.
      It's like chasing your tail working on these amps.
      On page 95 there are a couple regulators, make sure +3.3S and +3.3M are stable
      • bermo96
        • Jan 2019
        • 45
        • Belgique
        3.3S and 3.3M are good and stable, as for the relays it is hard to tell.
        • R_J
          • Jun 2012
          • 9594
          On page 95, there are a few relay drive lines, TRANS_RY, drives the relay for switching output voltage, SPRY_5CH and SPRY_SB drive the speaker relays, you could check those points to see which relays are being driven to click on/off
          You should be able to unplug CB103, plug from the transformer to the outputs, this should isolate the complete output section as a cause of the problem.
          • wazzadj@hotmail.com
            Wazza
            • Nov 2017
            • 57
            check all the voltage regulators
            12v 13v 5v 3v are all stable
            • bermo96
              • Jan 2019
              • 45
              • Belgique
              #26
              Thank you for the reply, but I've alreadfy checked all the voltages and they are fine. I gave up on this amplifier
              • Sojke
                • Apr 2017
                • 131
                • Serbia
                #27
                Anyone got the DSP firmware for it?
                • PantherDave
                  by PantherDave
                  Hi all!
                  05-29-2024, 02:01 PM
                • grimacelord
                  HP 15-EH1070wm - Black Screen With Power LED.
                  by grimacelord
                  I have an HP 15-eh1070wm laptop that came to me for the same reasons I am starting this thread. The charging LED appears when the laptop power adapter is connected and the power LED appears when pressing the power button, but nothing appears on screen.
                  First thing I did was take off the bottom panel and remove the battery and then press and hold the power button for 30 seconds and then reinstall the battery and power on. The fan spins and this time, the back light illuminates and a brief message appears on the screen for about 1 second saying something along like,...
                  01-28-2023, 10:50 AM
                • joaquinmjuan
                  Canon TS8350 Screen Freezes on Power On
                  by joaquinmjuan
                  Hello, I have a Canon TS8350 printer. The problem is that when I turn it on, "CANON" appears on the screen, but it never goes away. You can leave it on for a whole day, and it doesn't go away. Does anyone know how to fix this? I've tried unplugging it, but nothing. I've also tried holding down POWER, but nothing. In fact, once it turns on, it can't be turned off with the Power button. I've also held down Power and then plugged it into the Power supply, and the power light flashes once and doesn't turn on, but then when I press Power again, it turns on. Currently, it's a nearly new paperweight,...
                  05-07-2025, 12:26 AM
                • Alicat
                  Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                  by Alicat
                  Stopped by this site trying to fix my parents Panasonic Plasma TV.
                  Model number is TH-50PZ85U
                  Power comes on and the red power light stays on solid.
                  Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                  I also hear a few clicks.
                  I also think my parents said there was a thunderstorm and the TV failed after that.
                  Section 6 in the service manual talks about power and no screen,...
                  10-30-2024, 10:09 AM
                  03-31-2024, 02:12 PM
