Bad caps in Panasonic cq-c1300u car stereo (rubycon)
  • orange4boy
    • Sep 2009
    • 9
    Brand new here and just staring to learn about electronics.
    I was having sound issues with this rig and decided to take it apart before I trashed it. The volume had to be kept very low or clipping of bass would happen along with strange squealy sounds. Sure enough found 3 bulged caps when I took it apart. It is in a hot place in the car and the CDs come out hot so I don't think it's a rubycon quality issue. One was split and the cover was partly melted off.
    2- Rubycon 680uf 16V wxa 10mm x 10mm
    1- 4700uf 16v px
    I'm having a hard time finding a good quality replacement for the 680s because they have to be low profile.(one does at least)
    In the meantime, because I'm really impatient, I replaced the two 680s, which were installed parallel, with one 2200uf 16v (scavenged from a power supply) which I moved into an available space close by.
    It works much better now but still clips the bass and high volumes, so I'm going to get a Panasonic 4700uf 16v to replace the last bulged cap which sits right beside the mosfet.
    So... questions are,
    Should I try to replace the low profile with the closest I can find which may be crappy or should I get one good audio cap of double the capacitance, install in the new location, and be done with it?
    Does someone know where I can get low profile excellent quality 680s?
    Thanks a bunch.
  • orange4boy
    • Sep 2009
    • 9
    Re: Bad caps in Panasonic cq-c1300u car stereo (rubycon)
    Found these low profile caps. Anyone care to weigh in on quality or alternatives?
    low profile xicon 680uf 16v
    • Krankshaft
      • Jan 2007
      • 2328
      I used to use Xicon on adapters and such when I started out I haven't had one fail yet. But their quality is unknown.
      If you can't find the sizing in a reputable brand from Mouser, Digikey, or Newark. Try PMing Topcat.
      If those turn up nothing try the Xicons if they will fit the original caps weren't low ESR so they should be fine. As long as it's their high temp series (the ones coloored radioactive green) . Not their 85C series colored sky blue.
      Do you have any wiggle room on the height or is it a tight fit as it is?
      • orange4boy
        • Sep 2009
        • 9
        About 1 mm wiggle room on one of them. The other could be taller but I think mismatched is probably not a good idea. Turns out the link there is to a tall xicon when I checked the spec sheet.
        I can't find any reference to the originals even on the ruby site: rubycon wxa to find out the specs.
        • Toasty
          • Jul 2007
          • 4171
          Rubycon WXA - 10x9mm - 370ma - 105°C - 7.5mm lead spacing
          veritas odium parit
          • orange4boy
            • Sep 2009
            • 9
            Thx. Toasty.
            If I can't find a suitable mini 680uf should I get one good cap of double the capacitance, install in the new location, and be done with it?
            • Toasty
              • Jul 2007
              • 4171
              I'm sure we could come up with the correct replacement somewhere.
              Moving the caps about can raise its own set of problems. Scavenging parts is okay, if you can test what you scavenged. But blindly putting a cap in another (or 2 others) place, may worsen the problem.
              The caps aren't that expensive. Likely < $10 with shipping.
              Pics of this project please. The area around the caps too. What's nearby?
              Note that this may very well be the output amps are done.
              Toast
              veritas odium parit
              • orange4boy
                • Sep 2009
                • 9
                I'll post some pics this evening.
                Found some 680uf 16v caps that will fit just barely as I only have 12.5mm height. I could cut some of the CD player housing to fit taller ones but would rather not.
                680uf 16v radial leaded 647-UHN1C681MPD mouser part number
                HN series
                10x 12.5
                impedence 18
                ripple 1760
                680uf 16v radial leaded 647-UHM1C681MPD mouser pt#
                HM series
                10x 12.5
                imp 25
                ripple 1540
                Now if only I could find a relpacement for the single 4700uf 16v 13mm x 25mm. The place where it is is so tight so the diameter has to be 14mm max. and that's pushing it. I have found the spec sheet but no supply.
                • orange4boy
                  • Sep 2009
                  • 9
                  Here is the main power board. Bulged cap beside the torroid is a 4700uf 16v rubycon series px 12.5mm x 25mm. There is just about 1mm on each side of it. Above the mofset there is enough room to put something bigger and run wires down to the original mounting holes but I'm not sure that is a good idea. On the right, you can see my temporary solution to the replacement of the two rubycon 680uf 16v wxa series 10mm x 10mm. I have yet to find something close. The only close things I found were 10 x 12.5mm 680s which may just barely fit. I did find some 12.5 x 30mm 4700uf 16v units on ebay but as a lot of 150. I may email the seller for a deal on a couple and see if he bites.
                  Or I could install one of the taller ones on the back and the other in it's original location where there is plenty of headroom.
                  Each of these caps have a low ripple current rating and high impedance probably because they are so small. Everything I have found close is much better in both these areas. So i may see some improvement when I'm done.
                  The CD player takes up 90% of this space with a little left over by the heat sink.
                  I popped one of the bulged 680uf back in for the photo. It's the black one just below the brown nichicon in front of the red component. The plastic cover is half melted off.
                  Below is my temporary solution for the 2 680's. One 2200 of better quality. The stereo works much better now but the big bass still gets clipped (plus noise) when you turn it up too much. I think this has to do with the 4700uf which is also bulged. Please correct me if I'm wrong.
                  This is a top-down with the CD section installed showing the lack of space. I could install one sideways above it and run wires down or drill a hole in the case and install a larger size same rating on the back.
                  • Krankshaft
                    • Jan 2007
                    • 2328
                    You can just use a larger cap and bend 90 degrees to the PCB.
                    Just heatshrink tube both of the leads so they don't short each other out.
                    Usually I try to avoid this but an extreme situation like this warrants it.
                    • Toasty
                      • Jul 2007
                      • 4171
                      Bad spot for that cap. Right next to amp IC. Hot!
                      4700uF@16v - 12.5mm is likely a custom size. Most manufacturers top-out for that diameter at 3300-3900uF. 4700uF runs 16-18mm and up.
                      Panasonic FM or UCC KZE likely best but 3300uF limit.
                      Polys for the mini's are the best bet.
                      Toast
                      veritas odium parit
                      • orange4boy
                        • Sep 2009
                        • 9
                        If I do this the leads will have to be about 25mm long and the cap will be over the torroid or the mofset. Which is the better bet?
                        Toasty,
                        What specs should I be looking for in a poly to replace the mini's?
                        Thanks for the input.
                        • orange4boy
                          • Sep 2009
                          • 9
                          Got busy and found myself some polymer caps that will fit the original spots:
                          Mouser #: 647-PLG1C471MDO1
                          Mfr. #: PLG1C471MDO1
                          Desc.: Polymer Aluminum Radial Capacitors 470uF 16V 105c Radial Leaded Low
                          RoHS: RoHS Compliant
                          I guess they don't make large polymer caps in the range that would replace my 4700uf 16v. Will have to do the extreme side or under mount fix.
                          Fun with solder.
                          • Toasty
                            • Jul 2007
                            • 4171
                            Well, digging about yielded none that I found acceptable. Plus, I discovered that the leakage current of polymer caps in general is significantly higher than that of the WXA's you're replacing - 1504µA vs. 108µA in the case of the 470uF one you found, which is shy of the 680uF you need.
                            So, I withdraw my recommendation of going to polymers in this unit. I don't know for certain how that much excess leakage current will affect the circuit. It certainly wasn't designed for it.
                            At this point, I'd go with your plan to lay them down.
                            Try Nichicon HE:
                            http://www.mouser.com/ProductDetail/...bwpIiP8A%3d%3d
                            It's a 10x16mm and leakage is < 108µA
                            or an HM if you can't spare the room:
                            http://www.mouser.com/ProductDetail/...4ZITmwUaELcEoA
                            It's a 10x12.5mm and leakage is < 326µA
                            The 12.5, 3300uF should be fine on that amp filter. Get it and try it.
                            Toast
                            veritas odium parit
                            • orange4boy
                              • Sep 2009
                              • 9
                              Finally got it done....almost.
                              Found some gold panasonic FM caps to replace the 680s and replaced the 4700s with elna RE3s which are not the best but very good. I figured an 85° elna is better than a 105°G-Luxon. They will probably not last long. The good news is I can fit a 14mm dia. cap in that spot which opens the horizon to much better caps.
                              The only other caps I could find locally were G-Luxon SMs or 25V "rubycon" YXAs. I used italics there because I think it is a fake ruby. Everything about it seems sloppy. A friend picked it up for me. I'll post a pic if anyone's interested.
                              Anyway it sounds great now.
                              Thanks for your help!
                              Now for project #2: The kenwood amp with one crackling channel and two bulged 71 v 8200uf ELNA's
                              Those, I can find. $10 each from Solen Elecronique
                              • FZG
                                Panasonic AG-1000B VHS player with bad picture quality
                                by FZG
                                Hello!
                                I recently got an old VHS player from Panasonic and just for fun I want to try to repair this device. It is an AG-1000B portable VHS player from 1990 and it has a problem with picture quality in playback mode.
                                Picture in playback mode is very noisy and often loses sync but the still images are nearly perfect.
                                I want to know, is this something that could be solved by recapping or is the video head likely gone?
                                Also, what mechanism is this?
                                Any feedback is appreciated!...
                                05-06-2024, 07:16 AM
                              • Andre Gilbert
                                by Andre Gilbert
                                Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                11-20-2024, 08:52 PM
                              • DXseekerMO
                                Backlight strip quality, Amazon vs Ebay vs ShopJimmy. Is there really a difference?
                                by DXseekerMO
                                Hello everyone!
                                Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
                                I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...
                                Yes
                                0%
                                1
                                All backlight strips are the same quality
                                0%
                                1
                                No
                                0%
                                0
                                12-16-2021, 03:58 PM
                              • AquaMan Ua
                                by AquaMan Ua
                                05-17-2025, 09:40 AM
                              • crosswinds
                                Assistance with identifying replacement caps on ASUS P5VDZ-MX
                                by crosswinds
                                So, pulled a motherboard out from storage, was working when put away, wont post when I took it out of storage today.
                                Since it was working, and it looks to be essentially time that killed it I figured its a good idea to replace the caps before digging further.
                                Looks to be only good quality caps on this board, so might not be the issue. But it is closing in on 20 years now so, wont hurt i guess
                                Its a ASUS P5VDZ-MX board.
                                I would really appreciate some assistance on what the best replacement caps would be for these:
                                Panasonic(M)...
                                04-17-2024, 04:25 PM
