Sony STR-KM7 Not Powering On
  • mojos911
    • Aug 2018
    • 25
    So I have a Sony STR-KM7 with mains power - confirmed 240v - has no standby.
    The relay RY901 - standby relay for allowing 240v to main transformer is not switching. No clicking sounds at all when mains power is supplied. No display and no illumination of any LED lights - nothing completely dead.
    I have tested mains power circuit at mains connector on power avideo board - which is where the mains power comes into this unit and this tests good.
    Tested Secondary side of T902 Power Transformer (sub) across terminals - 10.5v
    Tested each secondary winding to ground is 5.25v.
    Tested D904 on diode mode with DMM - .566v
    Tested out of circuit - Q902 - B to E .725v - B to C .725v
    Tested out of circuit - Q901 - B to E .725v - B to C .725v
    Tested RY901 DC coil - 5v - with external power supply - working.
    Now I am completely out of my depth as I cant seem to move forward from here as I believe all these tests are ok. Does anyone know of the operating startup proceedure that can help or even where I should check next.
    I have attached a photo of the power avideo board and the schematic I am usng for reference.
    Re: Sony STR-KM7 Not Powering On
    Can you please upload the service manual/schematic?
    • R_J
      • 9535
      You should have standby voltage on CN271 pin 5, or across C904, Is it there?
      • mojos911
        • Aug 2018
        • 25
        Here is the full schematic Budm.
        • mojos911
          • Aug 2018
          • 25
          I will check those R J and get back to you.
          • Purge98
            • Aug 2023
            • 3
            Did you ever solve the problem?
            I have exactly the same issue and would welcome any advice.
            (I know this thread is old).
            • Purge98
              • Aug 2023
              • 3
              I have 13.2 v across C904
              and 12.7 v at CL214 (pin 5 on CN271).
              Any ideas?
              • Purge98
                • Aug 2023
                • 3
                Any ideas?
                UPDATE.................................
                I shorted out the relay RY901 output terminals and it works.
                There must be a problem with the signal to the base of transistor Q901 which drives the relay coil. I couldn't be bothered to find out what it was.
                This solution may help mojos911
                • Carlos#2003%
                  Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                  by Carlos#2003%
                  Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                  02-15-2024, 07:52 PM
                • blake.s
                  Sony XR-65X90J & Sony KD-55X80J Not Powering On
                  by blake.s
                  I have two separate tv's that are having the exact same symptoms. A Sony XR-65X90J and a Sony KD-55X80J. They both are not powering on at all and do not show any led light status. I am having issues with getting the backs off because both sets are the screwless type. Not sure if anybody has any ideas on if it is indeed a power supply issue or these types are known to have other issues.
                  Also, any ideas on how to get the sets backs off?
                  09-16-2021, 01:03 PM
                • davidebaldini
                  ATX power supply keeps blowing PFC mosfets — Cooler Master RS-550-ACAA-E3
                  by davidebaldini
                  This is an ATX PSU rated for 550W powering 24/7 a computer load of about 200W, fed by a line-interactive 1500VA UPS. Mains is 230V.
                  1. First issue: the PSU blew a mosfet on what I think is the active PFC boost converter, shorting its G D S pins together causing a short across the + and - lines produced by the rectifier on the 230V mains. The surge protector of the house tripped. When this happened I found that the UPS was unexpectedly disconnected from the wires of its battery. The UPS wasn't damaged, but I suspect this spontaneous detachment of a battery wire caused a condition that blew
                  01-25-2023, 02:23 PM
                • dkneyle
                  Sony KDL-46HX850 Can't upgrade/update firmware
                  by dkneyle
                  Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                  Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                  09-25-2024, 10:44 PM
                  Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                  This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                  09-06-2024, 05:27 AM
