Yamaha RX-v767 will not turn on
  • samtron123
    • Dec 2012
    • 77
    • germany
    Hello everybody,
    My Yamaha RX-V767 can not be turned on as described in the title.
    He does not make a fuss. The micro-fuse installed on the AC-DC converter I have checked, is intact.
    many thanks
  • madan1
    • Nov 2016
    • 659
    • Bulgaria
    Re: Yamaha RX-v767 will not turn on
    Watch this https://www.youtube.com/watch?v=MwvjAtSr5t8
    • samtron786
      • Aug 2016
      • 154
      • germany
      Hello and thank you very much
      but unfortunately I did not find that, further help please
      • samtron786
        • Aug 2016
        • 154
        • germany
        Hi
        the problem that I have 3.96 volts and not 5.5V here?
        where is the problem exactly
        • R_J
          • 9514
          That video is for a different model, for the rx-V767, with low standby +5v check C3708, C3707, C3712, C3713, C3716, C3710 & C3711
          • redwire
            • 3900
            RX-V767 standby PSU schematic for reference
            • samtron786
              • Aug 2016
              • 154
              • germany
              Hello, Ok, I'll do that right away and the red light will also appear on me
              it does not begin
              • samtron123
                • Dec 2012
                • 77
                • germany
                after I exchanged the TOP254PN IC, now 5.5 volts measurable but still the same problem no red light
                • samtron786
                  • Aug 2016
                  • 154
                  • germany
                  Snubber capacitor
                  Snubber resistors
                  • samtron123
                    • Dec 2012
                    • 77
                    • germany
                    can someone please write to me why the red LED does not work ??
                    many thanks
                    • samtron123
                      • Dec 2012
                      • 77
                      • germany
                      Hi
                      I wanted to write these values too
                      Electrolytic capacitor
                      400 V 68uF ESR=0,38 ohm Vloss=0,6% 67,65uF
                      1te 35 V 1000uF ESR=0,06 ohm Vloss=0,6% 1075uF
                      2te 35 V 1000uF ESR=0,04 ohm Vloss=0,6% 1071uF
                      • samtron123
                        • Dec 2012
                        • 77
                        • germany
                        C3708 11,19 v
                        c3707 5,92 v
                        c3712 5,53 v
                        c3713 5,53 v
                        c3716 5,53 v
                        c3710 4,86 v
                        c3711 3,75 v
                        • samtron123
                          • Dec 2012
                          • 77
                          • germany
                          Originally posted by samtron786
                          Snubber capacitor
                          Snubber resistors
                          I also exchanged it, still the same problems
                          • pajdek
                            Lenovo Y700-17ISK turn on and off
                            by pajdek
                            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                            09-20-2023, 02:49 AM
                          • daigs
                            Yamaha P-115 turn on but No sound - Doesn't turn off
                            by daigs
                            I need to repair a P-115 yamaha digital piano with a strange behaviour.
                            When I power on the piano from the dedicated on/off switch, the power led go to ON (red led), but the keyboard doesn't produce any sound, nor in the speakers nor in the headphones.
                            When I try to power off (pressing the switch for at least 1 second), the keyboard doesn't power off, the red led remains ON. I need to unplug the adapter cable to switch off the keyboard.
                            I checked the 12V voltage rail on the input PCB, after the power plug and it is OK.
                            I checked also the...
                            07-18-2023, 03:47 PM
                          • RdeveLabs
                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                            by RdeveLabs
                            To all the members here...
                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                            05-05-2025, 04:59 AM
                          • robante15
                            Acer Aspire 4520 won't turn on after reboot
                            by robante15
                            Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                            It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                            The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                            If I remove the...
                            04-06-2024, 06:50 PM
                          • masoksian
                            Dell latitude e7470 not turn on .power buton on off and Run Power problem
                            by masoksian
                            I am dealing with the problem of turning on and off my Dell e7470 notebook.
                            The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                            The system does not turn on, there is no post.
                            I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                            The problem continues in the same way.
                            I tried to turn on the Fn key, nothing came to the screen....
                            02-15-2025, 12:08 PM
