Yamaha P-115 turn on but No sound - Doesn't turn off
  • daigs
    • Nov 2022
    • 18
    • italy
    I need to repair a P-115 yamaha digital piano with a strange behaviour.
    When I power on the piano from the dedicated on/off switch, the power led go to ON (red led), but the keyboard doesn't produce any sound, nor in the speakers nor in the headphones.
    When I try to power off (pressing the switch for at least 1 second), the keyboard doesn't power off, the red led remains ON. I need to unplug the adapter cable to switch off the keyboard.
    I checked the 12V voltage rail on the input PCB, after the power plug and it is OK.
    I checked also the power switch on the dedicated frontal panel pcb with a multimeter and it works fine (when pressed 0 ohm, when released open circuit).
    I tried to enter in test mode as described in the service manual, but the keyboard seems not to enter in that mode (C#2-F2-G#2 pressed at the same time and power on the piano, should follow a sound).
    How do you suggest to proceed?
    Thanks a lot.
  • daigs
    • Nov 2022
    • 18
    • italy
    Re: Yamaha P-115 turn on but No sound - Doesn't turn off
    Up!
    • daigs
      • Nov 2022
      • 18
      • italy
      Up! 2°
      • laidman
        • Nov 2023
        • Costa Rica
        Were you able to get the piano to work? If not, check the capacitors in the vicinity of the 12v input.
        • laidman
          Yamaha psr ew400 piano loses sound
          by laidman
          Yamaha PSR EW400 piano intermittently loses sound and shuts down.
          Youtube people recommend verifying that the DC jack's solder connections aren't broken, and the replacement of a couple of capacitors in the vicinity of the DC jack. While these solutions might work, I'd feel a lot more secure if I had a schematic to help me check the status of the myriad components.
          Schematic and suggestions are welcome.
          11-18-2023, 05:13 PM
        • jjne
          Yamaha RX V675 sound issues
          by jjne
          I have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
          From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
          At first I thought it was either a speaker relay or the DSP, but I don't think...
          06-24-2025, 07:01 AM
        • AlexVG
          YAMAHA CLP-550 without of sound
          by AlexVG
          Hi.
          I have an old YAMAHA CLP-550 without sound. (Some times I can get some kind of noise or distorted sound)
          I have replaced all green marked elements, but it gave me nothing.
          The IC12 chip LC9116A-105 (red marked) remains under suspicion yet.
          But it is custom YAMAHA's chip, and I can't find any information about it.
          Maybe somebody came across with the same issue?
          Any information will be very useful. I will be very appreciated.
          Thank you....
          06-08-2025, 09:29 AM
        • hemant_2222
          Yamaha 2064 No sound but Test audio working
          by hemant_2222
          Hello Guys,
          Greetings!
          Hope you all are doing well.
          I am looking for suggestion on Yamaha 2064. The problem with this receiver is that it has no sound however when the test tones are activated it does outputs from all the speakers. It is working in two channel stereo mode but when you select other sound modes, it doesn't. The last time it had a problem, I had replaced the DAC
          PCM1681DBQR - IC263 and it worked fine.
          Other issue with it is one of the STK ICs is getting more heated then the other one but that can be looked at later.
          11-01-2025, 11:20 PM
        • maleksa
          Yamaha MOX8 boot freeze and distorted sound
          by maleksa
          My Yamaha MOX8 synthesizer recently developed two issues.
          Firstly, after booting up, it operates as normal. However, after about 5 minutes, the sound starts to get distorted (broken up screeching sound) almost like putting it through a guitar distortion pedal. After a while, the distorted sounds will go away for a while and comes back. At times, the synthesizer will also freeze I need to power off and on again.
          Secondly, when powering off and on again, there will be times where the synthesizer will freeze during the boot sequence (freezes at the MOX8 Opening Screen),...
          11-07-2024, 03:28 AM
