Crown Amp DC300A - One channel distirted, other good.
  • petehall347
    • Jan 2015
    • 4426
    #81
    Re: Crown Amp DC300A - One channel distirted, other good.
    hope the outputs are still good ..if not you can sub in a couple of low cost subs for testing . only needs 2 for getting it going .
    • budwich
      • Jul 2015
      • 3097
      sorry but I don't understand what this means... what are you referring to as "subs"... the main capacitors???
      • Agent24
        I see dead caps
        • Oct 2007
        • 4951
        • New Zealand
        #83
        Outputs: Output transistors (usually the most expensive ones)
        Subs: Substitutes
        -David VanHorn
        • petehall347
          • Jan 2015
          • 4426
          #84
          output transistors should be matched for vbe so they all share same current .
          • petehall347
            • Jan 2015
            • 4426
            #85
            from audiokarma .
            Output Transistors 3990 = 2N5631 ~ MJ21194G ~ (or 2N3773 with mods noted in the service manual)
            Driver Transistors 5402 = 2N5804 ~ ( I've also seen 2N6306 used)
            • budwich
              • Jul 2015
              • 3097
              this is likely where the problem lies. I used some replacements (alternatives) for some of the output ones that I found were initially bad at the start of this "exercise" not necessarily understanding the possible impact. The bad ones were all 3990. The replacements that I used (based on reads on the net) was mj15024. Anyway, I am tracking thru the output boards to see where things are there. Initial gross resistance checks of the rails do not show any direct shorts and both channels look the similar.
              • petehall347
                • Jan 2015
                • 4426
                #87
                transistors generally fail shorted b to e and sometimes b to e but not as often .
                • budwich
                  • Jul 2015
                  • 3097
                  Quick checks of the transistor pins to "case mount bolt" show low resistance on channel 2 which was the original failed channel. It will take a bit of desoldering of resistors to isolate which transistor has failed (as all have some form of "parallelism" involved). Channel 1 which was the most recent one to get attention (distorted) appears to be relatively ok resistance check wise. I will hopefully find the bad ones and go from there. I will use the "bulb limiter" to hopefully prevent any initial destruction should I not find everything on this attempt. Thanks again for the hints / help.
                  • budwich
                    • Jul 2015
                    • 3097
                    the "slope appears slippery"... I found two output transistors bad on channel 2. One was previously replaced by me (mj15024) while the other is an original 3990...:-( note: one of the other previously replaced mj15024 does not appear to be bad (meter testing only).... there are two mj15024's on the other channel.
                    It would appear that there is some "science" to this as mentioned which might be an issue or possibly the replacements aren't very good (substandard or "fake"). Probably continue to slice thru this to see if I can get it going again and then wrestle with what to do there after with the loss of 3990 which has been indicated need to be matched (set?)... not sure I can or want to go there at this point.
                    • petehall347
                      • Jan 2015
                      • 4426
                      #90
                      they should all be same and matched for vbe . you can maybe find 4 good ones out of whats there and get the amp running before deciding what to do .
                      • budwich
                        • Jul 2015
                        • 3097
                        I made an error in the previous post, the failed "3990" was actually a mj15024 that I had replaced during the earlier effort. Summary, 2 of 3 on channel two failed while none (there are two there) failed on channel one. I am still doing checks.
                        matching vbe might be difficult and wold require pulling all of them... or at least one to determine the existing "vbe". I would think matching them would require significant stock and / or supply from someone who would indicate the value. As you say, if and when I get it going again, I can perhaps cross the "vbe bridge".
                        • petehall347
                          • Jan 2015
                          • 4426
                          #92
                          all from same batch should be pretty close
                          • budwich
                            • Jul 2015
                            • 3097
                            that would mean 16 need to be replaced. Not sure that is going to be cost effective at this point.
                            • budwich
                              • Jul 2015
                              • 3097
                              Passed the "bulb test" this morning. Then powered up with nothing plugged in and left idling (1/2 hour) to see if anything tipped over. Nothing happened, rails check out. Plugged in preamp and cd player, and now have "clean" sound from both channels. Will let it run at low to medium level for a while and check some areas. Also as a test, I will run at a bit higher level and check things with a thermal imager to see if possibly there is an issue therein (ie. the replacements are running hotter than expected or whatever). I am reluctant to do much more... ie switching input, pushing volume, etc at this point. Hopefully, joy will return and stay a while. :-)
                              • budwich
                                • Jul 2015
                                • 3097
                                Its still running at medium volume. Attached is a thermal shot of the control board. There was not much happening at the output boards so I didn't include those. The control board seems to get pretty "toasty" although I don't know what it should be and whether this is contributing to any subsequent failure there and elsewhere.
                                • petehall347
                                  • Jan 2015
                                  • 4426
                                  #96
                                  just a thought regarding outputs sharing current you could measure voltage across each output transistor emitter resistor .this will maybe be a bit out though because of resistor resistance tolerance .
                                  • R_J
                                    • Jun 2012
                                    • 9535
                                    Check and monitor the DC offset for that channel, it needs to be near 0 volts and if it is not or starts to go in the positive or negative, you still have a problem.
                                    • redwire
                                      • Dec 2010
                                      • 3907
                                      When you replace a transistor in a power amp, you also replace the one upstream or ahead of it as well because although it tests OK, it is likely damaged. This is from Sony service and I've followed it for many years.
                                      You can see this (damaged transistor) with the diode-test E-B, C-B voltages being slightly off and leakage current present (on ohms).
                                      This would be for the driver stage, pre-driver etc. as well as the VBE multiplier transistor.
                                      Also, when a power amp transistor fails, the electrolytic capacitors (especially feedback and input ones) can see reverse-polarity and then they get damaged too. So check those capacitors as well, they make all kinds of noise and thumps as well.
                                      You can also put the amp on light bulb power and heat or cool (freeze spray) transistors to find the dud.
                                      • budwich
                                        • Jul 2015
                                        • 3097
                                        Thanks for the "upstream transistor" hint. On the failure this last time, the second one in the "line" failed (was previously replaced along with its upstream one which had also failed) but the upstream "appeared" to be good ... although some form of leakage seemed present as the resistance checks across the various "modes" (ie. be,ec,bc) was "less than infinite" compared to a "new one". Currently, it is running with this one still in place but I will go back and replace it. Having said that, on some pre-checks of the "new ones", I have seen them present a similar "less than infinite" resistance on some of the modes of the testing so they may have an issue to start with.
                                        I do use the "bulb limiter" as a "pre check" to help and prevent "significant happenings" as I can't guaranty my work is stellar... :-)
                                        • budwich
                                          • Jul 2015
                                          • 3097
                                          A new "symptom" showed up when I went to try the system this morning. I powered up the amp and there was a large hum coming from channel one (I think... speakers are pretty close together and I was wasn't paying close attention to sides). Somewhat scary. Power off, unplugged all inputs. The hum was still there. Connected in the bulb limiter and did some checks, the "expected" voltages seemed to be present on both sides (albeit reduced because of the limit). With a bit of time... a couple of turn on and off sequence just from doing multiple checks, the hum went away. Reconnected things. At this point, the hum was basically reduced / gone. Audio played normal from both channels.
                                          Not sure if this was there from the start of this latest revival effort as I don't recall necessarily having speakers connected at initial start up points along the way (fear of blowing either the speaker or amp). So it might have always been there since this repair phase. It would appear to be some form of cold joint / ground issue maybe or possibly a failing capacitor somewhere (as suggested).
                                          • eccerr0r
                                            old X58 triple channel board... memtest86 memory speed?
                                            by eccerr0r
                                            Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                            Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                            Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                            06-28-2025, 09:06 AM
                                          • quickname
                                            Cyberpower 1500AVR UPS repair
                                            by quickname
                                            I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                                            I decided to verify that the batteries were...
                                            11-12-2023, 09:57 AM
                                          • dicky96
                                            Hitachi V19B01922 Channel Tune problem
                                            by dicky96
                                            Hi Guys
                                            I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                                            He also has an LG TV, so three screens in the bar
                                            I installed three Satlink ST-6503 DVB-T Modulators
                                            This model https://www.aliexpress.com/item/32916553905.html
                                            These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                                            02-09-2023, 09:20 AM
                                          • sima112
                                            Marantz pm 6005 right channel not worknig
                                            by sima112
                                            Hi guys,
                                            I need a help with my Marantz pm6005. It started to have weaker the right channel a few months ago, than it got back to normal and now it has lost sound completely on the right channel. At the final stage it was loosing the channel for a while and than it returned. After it has disappeared completely I could forced it back by unplugging the source form CD (which I normally use) to phone and back. It would then work for a few minutes and died again. Now it is possible power up and all function works normally (apart the right channel ) on all inputs, except the phone both channel...
                                            01-30-2023, 12:11 PM
                                          • Logistics
                                            Supermicro X10DAX and Quad Channel
                                            by Logistics
                                            So my dilemma is that I can't seem to get my board to run in Quad Channel. I have an X10DAX with Dual E5 2690 v3's and originally it had four 16GB sticks of Samsung ECC. Figuring I needed to have a stick for each DIMM1 slot I purchased four more identical sticks of Samsung M393A2G40DB0-CPB. So, now I have eight 16GB sticks for a total of 128GB of RAM. When I install the ram so that Each DIMM1 slots is populated the system will not post even if I clear the CMOS, remove the battery, what-have-you. But according to what I'm reading in the Manual, which is admittedly not very clear, populating each...
                                            09-10-2023, 05:12 PM
