Denon PMA-510
  • Nawual
    • Jul 2016
    • 65
    • Spain
    Denon PMA-510
    Hello.
    I have this amplifier with the problem that the right channel sounds a little less than the left, both through the speaker outputs and the headphones.
    I leave the service manual.
    Thanks!
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Denon PMA-510
    Do the measurement/adjustment on the bottom of page 3 top of page 4.
    • Nawual
      • Jul 2016
      • 65
      • Spain
      Re: Denon PMA-510
      Hello again and apologizes for delay this post.
      I have used a product in contact clean spray on all buttons and reviewed the welds and has returned to work properly.
      Thanks everybody
      • mikey5791
        Help on car amplifier only one channel works
        by mikey5791
        Hi all forum members,
        Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
        My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
        08-06-2025, 10:36 PM
        RCA WHP141 wireless headphones wired up
        by momaka
        OK, this one dates back to 2015! I thought I had posted this, but realized I didn’t when I posted a picture of something else. So here it goes…
        Back in 2015, I bought a pair of RCA WHP141 wireless headphones at Micro Center for $2. I even mentioned it in the best cheap/free scores thread right here. Just forgot to follow up with that.
        As mentioned back then, these are (were) 900 MHz FM wireless headphones. No modern day Blutooth or anything like that. I knew they wouldn’t be great headphones or even that good… but the price was right! So let’s take...
        02-22-2023, 06:28 PM
      • Francesc V.
        Rotel RSX-1056 amplifier. Troubleshoot a noisy channel
        by Francesc V.
        Hi:
        I've realized that one of the channels of this amplifier has no proper sound.
        This is the signal at the speakers output.
        As long as the audio coming in to the amplifier board (blue) looks ok although with some noise due to the wire, I think that there's nothing to look at the preamp section.
        Now, I could start looking at components to see whether I find the guilty one.......but I would rather prefer to ask for advice. Here there is the amp. schema. Which points would you check with the oscilloscope to gather...
        07-15-2025, 01:33 AM
      • Sik_6ty_Sixx
        HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
        by Sik_6ty_Sixx
        So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
        02-18-2025, 05:06 AM
      • eccerr0r
        old X58 triple channel board... memtest86 memory speed?
        by eccerr0r
        Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
        Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
        Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
        06-28-2025, 09:06 AM
