Onkyo SKW-591 subwoofer is dead
  • tibimakai
    • Jan 2012
    • 3680
    Re: Onkyo SKW-591 subwoofer is dead
    I will solder in the final IC, and I will measure the speaker output and I will let you know. Most likely tomorrow.
    • tibimakai
      • Jan 2012
      • 3680
      OK, I have soldered in Q502 and it is still not OK.
      +2V in stand by and -38V, with signal.
      I can't imagine why it is so hard to diagnose this amp. There are just a few components.
      +/-5V and 12V, from 7805/7905/7812 are there.
      • R_J
        • 9535
        I would suspect the fet on the negative supply is being turned on, thats why I suggested checking the voltage from q501
        I would leave q502 out, and check the voltages on q501, look at the pdf for the ic. It has two drive circuits, HO & LO, I suspect there is a problem with the LO side. You need to check each resistor in that output circuit and make sure they are not open, Then check q501, look at the pdf of the ic and check that the internal fets are not shorted. If all 4 are not shorted.
        Check the voltage between VS & VB, then between VS & HO.
        Check the voltage between COM and VCC, then between COM & LO
        • tibimakai
          • Jan 2012
          • 3680
          The fet is a brand new one.
          • R_J
            • 9535
            What fet are you talking about?
            • tibimakai
              • Jan 2012
              • 3680
              Q502, that I have soldered in, is a brand new one.
              • tibimakai
                • Jan 2012
                • 3680
                Also, the Q501 I have solder in a few days ago, is brand new.
                • andy1
                  • Apr 2019
                  • 9
                  If you have a scope, you can take Q502 out of the circuit and compare the output wave forms on Q501 pins 11/14. They should be opposite in phase. If there is any DC across D515 or D516, that is what you will see on the speaker terminals. You will then know which half (LO or HO) of the IC is causing the DC voltage on the speaker terminals.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    Thanks Andy, I have one but I'm a beginner. I will try that as well.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      I have looked under the microscope, and I have found two broken traces. Middle pin(GND) of the Q502, and C503.
                      Now it's working great.
                      Thank you all for your help, it is very much appreciated.
                      Now I have to go back to the receiver. It just clicking on and off the relay.
                      It used to work, but HDMI did not work and it was overheating.
                      After replacement of that IC it does not turn on anymore, it just clicks.
                      • andy1
                        • Apr 2019
                        • 9
                        Great to hear that the sub is working now. As for the HDMI issue, I think you are more experienced than me. I am yet to try re-flowing the 609 board I discussed on the other forum!
                        • tibimakai
                          • Jan 2012
                          • 3680
                          Unfortunately, is not the DSP issue. This DSP has legs.
                          • redbaron1007
                            Onkyo SKW-791 subwoofer
                            by redbaron1007
                            I've got an Onkyo SKW-791 subwoofer in right now that isn't powering on. Or at least the indicator light isn't coming on and the system it goes to can't detect/connect to it. It's drawing 0.7W from the wall when plugged in according to my kill a watt. It has a hissing noise constantly whenever it's plugged in, but the hiss isn't coming from the speakers this is when the board is pulled out of the housing and sitting on my bench. The hissing nose is still present even when the speaker is plugged in, but nothing comes out of the speaker.
                            The first thing I did was replace the audio...
                            12-20-2022, 08:08 PM
                          • rustinjust
                            Please help, subwoofer connected to tv, read description below
                            by rustinjust
                            I've got a subwoofer that I've had for nearly 20 years, it did come with a basic remote which I've lost. It's a generic make of subwoofer, I can't see a brand sticker on it. It comes with 2 speakers.
                            Question recently I've connected it up to my tv which has greatly improved the sound on my tv, however I'd like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                            Is there a way of...
                            10-28-2023, 07:09 AM
                          • rustinjust
                            Please help, where can I get a remote for my subwoofer?
                            by rustinjust
                            I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
                            Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                            Is there...
                            10-28-2023, 03:43 AM
                          • Fripacks
                            Onkyo model SKW780 Subwoofer
                            by Fripacks
                            Hi guys, I have a subwoofer Onkyo model SKW780, one zener diode is short, I don't know the value, the location is D920 in the Power Supply Board, someone know the value of this zener?
                            12-21-2021, 03:19 PM
                          • double_DD
                            How can I be sure that my EC chip is dead?
                            by double_DD
                            As the title suggests, how can I be sure that my EC chip is really dead?
                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                            03-12-2025, 07:47 AM
